作品名:[AD 9][2层] 低照度(XC6206P182MR+HT802+NJM3414AV)PCB源文件
2 N/ w+ y- [& D6 _" S ^3 G# h文件描述 1. 作品用途:低照度 2. 软件版本:AD 9 3. 层数:2层板 4. 用到的主要芯片:XC6206P182MR+HT802+NJM3414AV 5. PCB尺寸:115mm*85.5mm 9 @4 Z/ J* c; s$ @, n1 ~" a, h/ c
作品截图如下: 顶层截图:
+ u( O T5 J' S6 g" z( w底层截图: 全层截图:
- l( D5 n, x9 T5 k7 `% W叠层信息截图如下:
# J; g! E8 @4 lBOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C1, C1, C1, C1, C1, C1, C2, C2, C2, C2, C2, C2, C3, C3, C3, C3, C3, C3, C4, C4, C4, C4, C4, C4, C11, C11, C11, C11, C11, C11, C15, C15, C15, C15, C15, C15, C16, C16, C16, C16, C16, C16, C21, C21, C21, C21, C21, C21, C22, C22, C22, C22, C22, C22, C23, C23, C23, C23, C23, C23, C24, C24, C24, C24, C24, C24, C25, C25, C25, C25, C25, C25, C26, C26, C26, C26, C26, C26, C27, C27, C27, C27, C27, C27, C28, C28, C28, C28, C28, C28, C29, C29, C29, C29, C29, C29, C30, C30, C30, C30, C30, C30, C33, C33, C33, C33, C33, C33, C35, C35, C35, C35, C35, C35, C36, C36, C36, C36, C36, C36, C37, C37, C37, C37, C37, C37, C38, C38, C38, C38, C38, C38, C40, C40, C40, C40, C40, C40, C41, C41, C41, C41, C41, C41, C42, C42, C42, C42, C42, C42 | 0402-C | 150 | 106 | C5, C5, C5, C5, C5, C5, C6, C6, C6, C6, C6, C6, C10, C10, C10, C10, C10, C10, C19, C19, C19, C19, C19, C19, C20, C20, C20, C20, C20, C20 | 0603-C | 30 | 105 | C7, C7, C7, C7, C7, C7, C8, C8, C8, C8, C8, C8, C9, C9, C9, C9, C9, C9, C12, C12, C12, C12, C12, C12, C13, C13, C13, C13, C13, C13, C31, C31, C31, C31, C31, C31 | 0402-C | 36 | 222 | C14, C14, C14, C14, C14, C14, C18, C18, C18, C18, C18, C18 | 0402-C | 12 | 101 | C17 | 0402-C | 6 | 33pF | C32, C32, C32, C32, C32, C32, C34, C34, C34, C34, C34, C34 | 0402-C | 12 | 56pF | C39 | 0402-C | 6 | 106/25V | C43, C43, C43, C43, C43, C43, C44, C44, C44, C44, C44, C44 | 0805-C | 12 | 104 | C45 | 0603-C | 6 | 56P | C46 | 0402-C | 6 | 47uF | EC1 | BCASE | 6 | KIA809 | IC1 | SOT-23 | 6 | HT802 | IC2 | LCC77 | 6 | IA171 | IC3 | SOT-23-6 | 6 | NJM3414AV | IC4 | TSSOP-DW8 | 6 | XC6206P182MR | IC5 | SOT-23 | 6 | 24C04 | IC6 | SOIC8 | 6 | GD25Q40 | IC7 | SOIC8 | 6 | MP2359 | IC8 | SOT-23-6 | 6 | BA6208 | IC9 | SOIC8 | 6 | 100M152 | L1, L1, L1, L1, L1, L1, L2, L2, L2, L2, L2, L2, L3, L3, L3, L3, L3, L3, L4, L4, L4, L4, L4, L4, L5, L5, L5, L5, L5, L5, L6, L6, L6, L6, L6, L6 | 0603-L | 36 | 10uH | L7 | 322522CL | 6 | 22uH | L8 | 3D16 | 6 | BG0601 | MCCD1 | BG0601_GSIRCUT2 | 6 | JIG | P1 | JIG | 6 | IRIS | P2 | 1.25CON4 | 6 | DN_EXT | P3 | 1.25CON2 | 6 | MAIN | P4 | 1.5CON3 | 6 | KEY | P5 | 1.25CON6 | 6 | IRCUT | P6 | 1.25CON2 | 6 | 4.7K | PR1 | RP_LTF4 | 6 | 8050 | Q1 | SOT-23 | 6 | 10K | R1, R1, R1, R1, R1, R1, R2, R2, R2, R2, R2, R2, R3, R3, R3, R3, R3, R3, R7, R7, R7, R7, R7, R7, R8, R8, R8, R8, R8, R8, R9, R9, R9, R9, R9, R9, R10, R10, R10, R10, R10, R10, R11, R11, R11, R11, R11, R11, R20, R20, R20, R20, R20, R20 | 0402-R | 54 | 100K | R4, R4, R4, R4, R4, R4, R5, R5, R5, R5, R5, R5, R6, R6, R6, R6, R6, R6, R12, R12, R12, R12, R12, R12, R13, R13, R13, R13, R13, R13, R27, R27, R27, R27, R27, R27 | 0402-R | 36 | 5.6K | R14 | 0402-R | 6 | 470R | R15 | 0402-R | 6 | 75R | R16 | 0805-R | 6 | 47K | R17 | 0402-R | 6 | 1M | R18 | 0402-R | 6 | 330R | R19, R19, R19, R19, R19, R19, R23, R23, R23, R23, R23, R23 | 0402-R | 12 | 3.9K | R21 | 0402-R | 6 | 56R | R22 | 0402-R | 6 | 10R | R24 | 0402-R | 6 | 1K | R25, R25, R25, R25, R25, R25, R26, R26, R26, R26, R26, R26 | 0402-R | 12 | 7.5K | R28 | 0402-R | 6 | 2.4K | R29 | 0402-R | 6 | 100R | R30, R30, R30, R30, R30, R30, R31, R31, R31, R31, R31, R31 | 0402-R | 12 | 68R | R32 | 1206-R | 6 | 27K | R33 | 0402-R | 6 | 6.8K | R34 | 0402-R | 6 | 15K | R35 | 0402-R | 6 | 56K | R36 | 0402-R | 6 | SS26 | SD1 | SMA | 6 | SS0540 | SD2 | SOD-123 | 6 | MCCDSCL | TP1 | TP | 6 | MCCDSDA | TP2 | TP | 6 | GND | TP3 | TP | 6 | ALARM | TP4 | TP | 6 | RS485_RX | TP5 | TP | 6 | BS0080 | TVS1 | SMA | 6 | SMAJ18A | TVS2 | SMA | 6 | 28.375MHz | X1 | CYC-LS382 | 6 |
* I( p9 I! Y& U. z/ ~5 g附件: PCB源文件如下: " K5 T) B) j/ r7 Y3 ~
