查看: 916|回复: 6
[allegro16.3][6层]iMX6SLEVK开发板(MX6SL+ QSH-060+PCI接口+USB)pcb文件
发表于 2019-12-16 17:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
0 B+ B3 v1 E/ J' i0 c3 @: [$ @; H3 z! B; _. U8 m
% f/ E7 T9 d  g( m' E
文件描述:
& ~+ m9 N: c, b8 [2 p! [' D
1. 作品用途:iMX6SLEVK开发板
2. 软件版本:allegro16.3
3. 层数:6层
4. 用到的主要芯片:MX6SL+ QSH-060+PCI接口+USB
5. PCB尺寸:5*6.36mm
& w1 y2 M, l/ M$ a0 K, V
作品截图如下:
! l; H  S' q, s
顶层截图:
+ E& q4 w2 A; R
底层截图:
  w5 P" V$ X& x& z6 r: I( @4 E2 ]6 z
3 e8 {& q- y5 B, v/ Z  a4 T" y
4 O/ v; W- M& U- D1 _" z
全层截图:
) b4 `# J4 Z. T* r% {# O% `* B8 X; B
) @& m) x, N3 c3 N
6$ l$ L# p+ U
$ C; ^" g2 L, k. o( }
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
100MIL_THJUMPER1X2_100MIL_TH_IO_4MM_210-SHORT_100milIO1JP1
0201_CCCAP_NP_0201_CC_DISCRETE_0.33 MM0.22UFDISCRETE22C23; C40; C72; C77; C82; C88; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C406; C407; C412
0201_CCCAP_NP_0201_CC_DISCRETE_0.33MM_0.01uFDISCRETE7C114; C116; C118; C119; C125; C211; C213
0402_CCCAP_NP_0402_CC_DISCRETE_0.635MM0.1UFDISCRETE57C1; C13; C14; C37; C38; C39; C55; C56; C57; C59; C60; C61; C62; C68; C87; C108; C109; C111; C112; C113; C115; C120; C121; C122; C123; C126; C130; C131; C133; C134; C135; C137; C139; C144; C154; C158; C174; C175; C177; C179; C182; C183; C184; C185; C186; C187; C198; C201; C202; C204; C206; C207; C209; C212; C215; C216; C217
0402_CCCAP_NP_0402_CC_DISCRETE_0.6MM_11.0UFDISCRETE15C2; C4; C11; C12; C21; C22; C24; C36; C86; C147; C156; C166; C178; C200; C218
0402_CCCAP_NP_0402_CC_DISCRETE_0.65MM_4.7uFDISCRETE32C17; C29; C30; C31; C33; C34; C35; C129; C132; C136; C140; C157; C161; C162; C164; C165; C176; C199; C208; C389; C390; C394; C396; C397; C398; C399; C400; C401; C402; C403; C404; C405
0402_CCCAP_NP_0402_CC_DISCRETE_0.55 MM0.15uFDISCRETE1C18
0402_CCCAP_NP_0402_CC_DISCRETE_0.55MM_0.22uFDISCRETE3C27; C28; C32
0402_CCCAP_NP_0402_CC_DISCRETE_0.56MM_18pFDISCRETE2C194; C195
0402_CCCAP_NP_0402_CC_DISCRETE_0.56M_10.01UFDISCRETE1C205
0402_CCRES_0402_CC_DISCRETE_470-75557_10KDISCRETE37R3; R4; R5; R24; R25; R36; R115; R123; R124; R125; R204; R205; R206; R207; R270; R375; R381; R386; R387; R388; R390; R391; R393; R395; R396; R397; R398; R399; R410; R411; R413; R414; R416; R424; R425; R426; R432
0402_CCRES_0402_CC_DISCRETE_470-75636_2.2KDISCRETE4R12; R34; R408; R720
0402_CCRES_0402_CC_DISCRETE_470-75597_100KDISCRETE2R22; R23
0402_CCRES_0402_CC_DISCRETE_470-76037_1.0KDISCRETE15R33; R84; R85; R86; R87; R89; R90; R310; R311; R377; R378; R380; R389; R781; R782
0402_CCRES_0402_CC_DISCRETE_0.6MM_470-0DISCRETE68R37; R38; R39; R40; R43; R45; R48; R49; R60; R121; R122; R126; R153; R165; R166; R175; R180; R182; R191; R192; R193; R194; R215; R216; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R244; R245; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R272; R407; R721
0402_CCRES_0402_CC_DISCRETE_470-75613_330DISCRETE7R57; R178; R179; R309; R394; R415; R418
0402_CCRES_0402_CC_DISCRETE_470-75559_47KDISCRETE10R189; R190; R197; R198; R305; R306; R402; R722; R745; R749
0402_CCRES_0402_CC_DISCRETE_470-75634_33DISCRETE1R257
0402_CCRES_0402_CC_DISCRETE_470-76086_20KDISCRETE24R318; R319; R320; R324; R326; R328; R330; R332; R335; R336; R339; R341; R343; R345; R347; R349; R352; R353; R356; R358; R360; R362; R364; R366
0402_CCRES_0402_CC_DISCRETE_470-75626_4.7KDISCRETE25R321; R322; R323; R325; R327; R329; R331; R333; R337; R338; R340; R342; R344; R346; R348; R350; R354; R355; R357; R359; R361; R363; R365; R367; R400
0402_CCRES_0402_CC_DISCRETE_470-75642_1.0MDISCRETE1R373
0402_CCRES_0402_CC_DISCRETE_470-30454_100DISCRETE2R392; R409
0402_CCRES_0402_CC_DISCRETE_470-30956_12.1KDISCRETE1R431
0603_CCCAP_NP_0603_CC_DISCRETE_0.9MM_14.7uFDISCRETE9C41; C46; C47; C48; C58; C63; C66; C159; C160
0603_CCCAP_NP_0603_CC_DISCRETE_1MM_15022UFDISCRETE19C42; C43; C49; C50; C53; C54; C64; C65; C67; C75; C76; C79; C80; C81; C110; C117; C124; C408; C410
0603_CCCAP_NP_0603_CC_DISCRETE_0.87MM_16PFDISCRETE2C196; C197
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHMDISCRETE10L10; L11; L17; L18; L19; L20; L21; L22; L23; L24
0603_CCRES_0603_CC_DISCRETE_470-76077_0.1DISCRETE1R1
0603_CCRES_0603_CC_DISCRETE_470-75455_470KDISCRETE1R9
0603_CCRES_0603_CC_DISCRETE_470-78009_3.0KDISCRETE1R35
0603_CCRES_0603_CC_DISCRETE_470-75407_0DISCRETE16R41; R42; R44; R46; R47; R50; R51; R52; R53; R54; R55; R56; R58; R59; R779; R780
0603_CCRES_0603_CC_DISCRETE_470-75432_49.9DISCRETE4R403; R404; R405; R406
0603_CCRES_0603_CC_DISCRETE_470-78219_2.21MDISCRETE1R778
0603_CCTHERMISTOR_0603_CC_DISCRETE_47010KDISCRETE1RT1
0805_CCCAP_NP_0805_CC_DISCRETE_1.45MM_22UFDISCRETE1C19
0805_CCCAP_NP_0805_CC_DISCRETE_1.45 MM47uFDISCRETE1C70
0805_CCRES_0805_CC_DISCRETE_470-79981_2.7KDISCRETE1R2
BGA49_0P5_3P62X4WM8962_BGA_49P_CUST_BGA49_0P5_3WM8962IC1U6
BGA169_0P5_12X16SDIN5C2_TFBGA_169P_BGA169_0P5_1SDIN5C2-8GIC1U5
C035STEST PAD_C035S_IC_0.1 MM_280-75TEST POINTIC18TP8; TP29; TP30; TP31; TP33; TP35; TP37; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP50; TP51; TP73; TP74
CC0603CAP_NP_CC0603_DISCRETE_0.9 MM_12.2uFDISCRETE6C151; C152; C153; C374; C375; C376
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.01610uFDISCRETE10C10; C20; C69; C138; C145; C148; C149; C155; C163; C203
CC1210CAP_NP_CC1210_DISCRETE_2.413MM_100UFDISCRETE6C3; C180; C181; C191; C192; C210
CC1210CAP_NP_CC1210_DISCRETE_2.42 MM_47uFDISCRETE1C146
CC7343ACAP_POL_CC7343A_DISCRETE_3.1 MM150 UFDISCRETE1C150
CON3_VER_SMTCONN_UMC_3P_M_CON3_VER_SMT_IO_1128-0711-20IO2J19; J20
CON5_AUD_JACK_RA_TH_SJ-435143.5MM_AUDIO_JACK_CON5_AUD_JACK_Audio JackIO1J130
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5IO2J9; J26
CON19_SDCARD_DUAL_SM_NSPCONN_SDCARD_DUAL_15P_CON19_SDCACONN CRD 19IO3J21; J22; J23
CON_2X26_0P8_SMT_AMINI_PCI_LATCH_52P_CON_2X26_0P8CON 2X26 MINI PCI EXPRESSIO1J8
CON_4M_1MM_SM_RASM04B_CON_4M_1MM_SM_RA_IO_2.95MSM04B-SRSS-TBIO1CON500
CON_120S_QSH_SM_05PITCHQSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-AIO2J12; J13
CON_BBC_40P_0P4_SMFX12B-40P_CON_BBC_40P_0P4_SM_IOCONN PLUG 40IO1J24
CON_PH_2M_78_THHDR_1X2_M_CON_PH_2M_78_TH_IO_6.B2B-PH-K-SIO1J1
CON_SIM_CD_2P54MMSF7W006S1A_CON_SIM_CD_2P54MM_IOCON 6 SIM CARDIO1J133
DIP-SMT2SW_DIP-2_DIP-SMT2_IC_4.83 MM_51SW_DIP-2/SMIC1S1
DO_CASE_267DIODE_DO_CASE_267_IC_5.3MM_480-1N5400IC1D4
DO_VMN2DIODE_DO_VMN2_IC_0.4MM_480-7793RB521CS-30IC1D3
FBGA168_0P5_12X12MM_NSPMT42L256M32D2_FBGA_168P_FBGA168MT42L256M32D2IC1U2
HDR2X4_2P54_TSM_SMCONN_HDR_4X2_HDR2X4_2P54_TSM_SMHDR 2X4IO1J136
HDR102CONN_HDR_2X1_HDR102_IO_8.39MM_2HDR 1X2IO2J14; J18
HDR103CONN_HDR_3X1_HDR103_IO_8.586 MMHDR_1X3IO2J16; J17
HDR103_49MILCONN_HDR_3X1_HDR103_49MIL_IO_4.CON_1X3IO1J2
HDR104CONN_HDR_4X1_HDR104_IO_10.29MM_HDR 1X4IO1CON4
HDR210_TST_RATSW-110-05-G-D_HDR210_TST_RA_IOTST-110-05-T-D-RAIO1J7
IND4_CHOKE_0805DLW43_IND4_CHOKE_0805_DISCRETE_90OHMDISCRETE2L14; L15
IND_LPS4018INDUCTOR_FERRITE_A_IND_LPS4018_2.2uHDISCRETE1L8
IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET1UHDISCRETE2L3; L7
IND_VLS252010INDUCTOR_IND_VLS252010_DISCRETE1UHDISCRETE4L2; L4; L5; L6
LED_0603LED_LED_0603_IC_1.1MM_370-76427LED RedIC3D6; D18; D21
LED_0603LED_LED_0603_IC_1.1MM_370-76425LED GreenIC4D11; D15; D22; D23
MIC_WM-63PRMIC_MIC_WM-63PR_IC_2.2 MM_510-7WM-64PCTIC1P4
MSO8_MO-1872G125_2_MSO8_MO-187_IC_1.3MM_31SN74LVC2G125IC1U31
MX6SL_BGAMX6SL_432P_MX6SL_BGA_IC_1MM_344PCIMX6L8DVN10AAIC1U1
PSOP8TXB0102_PSOP8_IC_0.9MM_315-7889TXS0102IC1U34
QFN24_4X4MM_SLUGLAN8720A-QFN24_QFN24_4X4MM_SLUGLAN8720AIC1U8
QFN32_MC1320XFT232RQ_QFN32_MC1320X_IC_1.05MMFT232RQIC1U28
QFN56_0P5_8X8_EP4P1X4P4MMPF0100NPZES_56P_QFN56_0P5_8X8MMPF0100F1EPIC1U3
RAPC722DC_POWER_JACK_3_RAPC722_IO_11.0CON_1_PWRIO1J6
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_240DISCRETE3R88; R93; R94
RC0603RES_RC0603_DISCRETE_470-75405_220DISCRETE2R771; R772
RJ45_8_MAGJACK_THRJ45_MAG_LED_SI-50170-F_RJ45_8_RJ45 8IO1J11
SC70-5ONE_AND_SC70-5_IC_1.1MM_312-303NC7SZ08P5IC1U32
SC70_3MOSFET_N_SC70_3_IC_1.0MM_480-76NTS4001NT1GIC1Q3
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10DISCRETE2SH7; SH8
SH0603-X2_PIN1TO2RES_SHORT-3_1TO2_SH0603-X2_PIN10DISCRETE2SH12; SH13
SH0805_40RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTDISCRETE9SH1; SH2; SH3; SH4; SH5; SH11; SH14; SH15; SH16
SO8WSTM25P32_SO8WST_IC_2.5MM_334-7733M25P32-VMW6TGIC1U13
SO8_PAKFDMS6681Z_SO8_PAK_IC_1.10MM_480FDMS6681ZIC1Q1
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U19
SOD123ZDIODE_SOD123_IC_1.35MM_480-768MMSZ5231BT1GIC1D2
SOD123LFDIODE_SCHTKY_SOD123LF_IC_1.0 MMMBR140SFTIC1D12
SOD-923DIODE_TVS_SOD-923_IC_0.40MM_480ESD9L5.0ST5GIC3D1; D13; D14
SOT23DUALDIODE_CA_SOT23_SOT23_IC_1.1BAT54A-7-FIC2D19; D20
SOT23NPN_SOT23_IC_1.12MM_480-75757_MMMBT3904IC1Q5
SOT232N7002_SOT23_IC_1.3MM_480-751592N7002IC2Q7; Q31
SOT23-40X40DUALDIODE_CC_SOT23_SHTKY_SOT23-BAT54C-7-FIC1D24
SOT23_S6SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4IC2U17; U18
SOT363PNP_DUAL_SOT363_IC_1.1MM_480-77MBT3906DW1T1IC1Q2
SOT-23MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401IC2Q6; Q30
SPACER_139TSPACER_SPACER_139T_IC_16.13MM_2.635" LONGIC4H1; H2; H3; H4
SSOP8SN74LVC2G126DCTR_SSOP8_IC_1.30MSN74LVC2G126IC1U27
SSOT6_1P7X3FDC6331L_SSOT6_1P7X3_IC_1.1MM_3FDC6331LIC1U33
SW3_SLIDE_THSW3_SPDT_SLIDE_SW3_SLIDE_TH_IC_SPDT_PWR_SWITCHIC1SW14
SW4_PB_ESW_SM_P177SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBIC10SW1; SW2; SW6; SW7; SW8; SW9; SW10; SW11; SW12; SW13
SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8IC3SW3; SW4; SW5
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILIC2TP75; TP76
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_2.286MMTESTLOOPIC8TP65; TP66; TP67; TP68; TP69; TP70; TP71; TP72
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020IO1TP25
TQFN28_0P4_4X4MAX8903A_TQFN_28P_TQFN28_0P4_4XMAX8903BIC1U4
TSSOP2074-244A_20P_TSSOP20_IC_1.1MM_3174LVC244APWIC3U21; U23; U24
USB_AUSB_A_USB_A_IO_7.01MM_210-30008USB_TYPE_AIO1J10
XTAL2-3P2X1P5-SMXTAL_XTAL2-3P2X1P5-SM_IC_0.65MM32.768kHzIC1Y1
XTLOSC4_3P2X2P5MM_SMCRYSTAL_JXS63_XTLOSC4_3P2X2P5MM24MHZIC1Y3
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
0 S5 m! l) f: S1 {
    2025-7-2 15:42
  • 签到天数: 552 天
    [LV.9]以坛为家II
    发表于 2020-1-7 16:45 | 只看该作者
    学习一下,下载看看。
    无聊
    2019-11-19 15:32
    发表于 2020-1-16 04:18 | 只看该作者
    下载下来看看# }3 ~* d% A3 F1 r" {' @2 O
    发表于 2020-4-1 22:16 | 只看该作者
    GMT+8, 2025-7-3 00:27 , Processed in 0.093750 second(s), 27 queries , Gzip On.
