作品名:[AD 9][2层] AT90S8535+ICL7660+LM7806CT原理图和PCB源文件
2 S& s. ~8 f$ H! g) n7 P. @. S# w: |2 M文件描述 1. 作品用途:AT90S8535+ICL7660+LM7806CT原理图和PCB源文件 2. 软件版本:AD 9 3. 层数:2层板 4. 用到的主要芯片:AT90S8535+ICL7660+LM7806CT 5. PCB尺寸:165.5mm*72mm
+ s2 Q g. e1 {. K6 Q! E5 Y/ u作品截图如下: 全层截图:
0 \- C7 y$ e7 D7 P8 ^6 f- b叠层信息截图如下: 2 D* C& U L. g# w; x! ^5 s1 I8 L: B
BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C1, C2, C3, C7, C8, C9 | RAD0.1 | 6 | 30pF | C4, C5 | RAD0.1 | 2 | 105 | C10, C11 | RAD0.1 | 2 | 220u | C12, C13, C14 | RB4/8 | 3 | 10u | C15, C16, C19, C20, C21 | RB2/4 | 5 | 10uF | C17, C18 | RB2/4 | 2 | 10u | C22 | RB3/6 | 1 | 1N4148 | D1, D2, D5 | DIODE0.4 | 3 | 4148 | D3 | DIODE0.4 | 1 | 1N4001 | D4 | DIODE0.4 | 1 | CON2 | j5 | jxz3 | 1 | CON4 | J1 | JXZ4 | 1 | CON2 | J2 | SIP2 | 1 | CON4 | J3, J8, LED | SIP4 | 3 | CON3 | J6 | jxz3 | 1 | CON3 | J7 | SIP3 | 1 | 100uH | L? | RAD0.2 | 1 | LED | LED1, LED2, LED3, LED4 | SIP2 | 4 | 9013 | Q1, Q2, Q3 | TO-92C | 3 | 470 | R1, R2 | AXIAL0.3 | 2 | 100 | R3 | AXIAL0.3 | 1 | 3K | R5 | AXIAL0.3 | 1 | 5.1K | R6 | AXIAL0.3 | 1 | 2K | R7, R23, R24 | AXIAL0.3 | 3 | 20K | R8, R10, R13 | AXIAL0.3 | 3 | 10K | R9, R14, R18, R19, R25 | AXIAL0.3 | 5 | 1K | R11, R12, R15, R20, R22, R26, R30 | AXIAL0.3 | 7 | 10K | R16 | AXIAL0.4 | 1 | 200K | R17 | AXIAL0.3 | 1 | 510 | R21, R27 | AXIAL0.3 | 2 | RES2 | R31, R32, R33, R34 | AXIAL0.3 | 4 | 500 | RP1 | VR6 | 1 | 1 | RP2 | VR6 | 1 | AT90S8535 | U1 | DIP40 | 1 | 4051 | U2 | DIP-16 | 1 | 74HC14 | U3 | DIP-14 | 1 | TL084 | U4 | DIP-14 | 1 | ICL7660 | U5 | DIP8 | 1 | MAX232A | U6 | DIP-16 | 1 | LM7806CT | U7 | TO-220 | 1 | LM7805CT | U8 | TO-220 | 1 | 11.0592 | Y? | XTAL1 | 1 | / W% c( \, R, a) |
附件: 原理图和PCB源文件如下: , I2 g, J9 j- ]- |
