查看: 500|回复: 3
[allegro 15.7]【6层】OMAP35xx_ES2.0+TFP410+usb 原理图和pcb文件
发表于 2019-12-13 16:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# ^$ M" c1 @4 ^, U, n
0 L$ e% @/ D8 E- y. M( i$ q: X8 i" B7 V! Q8 l
文件描述:
/ m0 a, X3 l$ E5 Z% ^9 a/ S% r- D5 \
1. 软件版本:allegro 15.7
2. 层数:6层
3. 用到的主要芯片:OMAP35xx_ES2.0+TFP410+usb
4. PCB尺寸:3.1*3.0  mm
$ `+ T7 W, p" k" |  q
$ k0 R, L# R. d9 t- L9 X  h
作品截图如下:
- z5 i* X% Y; O  U4 y3 ^" D
顶层截图:
0 w$ u' B# H& D2 ]9 {
: `& x, ~  F, s7 o
底层截图:
: ?, Z1 P& b3 H' [; E2 o  b+ L  @: f" T* s
1 t* ^& s. s- ?. V. z* k
3 M/ A8 {# U1 g8 Z9 r# ~
全层截图:
1 @/ @9 }; s( h1 y; `) I; a2 k6 l" M7 ]% g4 l9 V, s, ?
& r1 |+ q1 L8 S1 G7 C; q6 w
* r- x* p# f+ `4 k3 e+ h- H' a6 Q" ~
1 A( ?3 j+ {. i) i) h; [
6 H, Q) L2 B: ^) L
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA2X4-YZPTXB0102_1_BGA2X4-YZP_TXS0102 (YTXS0102 (YZP)IC1U9
BGA2X4-YZPTXB0102_0_BGA2X4-YZP_TXS0102 (YTXS0102 (YZP)IC1U11
BGA5X5-4MMUSB3319_0_BGA5X5-4MM_USB3319 (CUSB3319 (CSP)IC1U7
BGA515-CBBOMAP3430_ES2_5.0_BGA515-CBB_OMAOMAP35xx_ES2.0IC1U3
BGA-ZXN-209TWL4030_6_BGA-ZXN-209_FBGA209_1FBGA209_15-74_280x280IC1U5
C402-25CAP_0402_0R1UF_X7R_10V_C402-25_0.1uFIC81C1; C3; C4; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C46; C50; C73; C74; C75; C78; C79; C80; C81; C82; C84; C86; C87; C88; C89; C90; C91; C92; C93; C94; C96; C98; C99; C100; C103; C105; C107; C110; C111; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126
C402-25207-0229-000_0_C402-25_DISCRETE150pFDISCRETE2C5; C6
C402-25100NF-16V X7R_2_C402-25_DISCRET0.1uFDISCRETE2C7; C8
C402-25CAP_0402_0R1UF_X7R_10V_C402-2_10.22uFIC2C44; C45
C402-25CAP_207-0009-000_C402-25_DISCRE100PFDISCRETE6C51; C60; C61; C62; C63; C70
C402-250402_0R01UF_X7R_16V_10_C402-25_0.1uFIC1C52
C402-25CAPACITOR NON-POL_C402-25_100PF100pFIC2C58; C59
C402-25CAP_0402_0R1UF_X7R_10V_C402-2_20.1uF,CERIC2C64; C65
C402-25CAP_207-0009-000_C402-25_DISC_122PFDISCRETE2C68; C69
C402-25RD0402C-47P_1_C402-25RD_47PF47pFIC4C56; C57; C66; C67
C603-35X457343L_100UF_TANT_10V_10_C603-351uFIC1C2
C603-35X450402_0R01UF_X7R_16V_10_C603-35X1uFIC3C47; C48; C49
C603-35X45207-0000-075_1UF_C603-35X45_DIS1UFDISCRETE1C55
C603-35X45207-0000-075_0_C603-35X45_DISCR1UFDISCRETE1C71
C1210-70X1021812-X5R-10V-47UF_C1210-70X102_47uF,CERIC2C53; C54
C1210-70X120C_47UF25V_POL_3528_C1210-70X120C47uf, 25VIC1C101
C3216-35X550603C-2U2_0_C3216-35X55_2.2UF2.2uFIC1C72
C3216-35X5510UF-10V-293D-C_1_C3216-35X55_D10UFDISCRETE7C76; C77; C83; C85; C95; C97; C112
C3216-35X55CAP35284.7uFDISCRETE3C102; C104; C106
CONN3-PWR-PJ102ACONN JACK PWR_1_CONN3-PWR-PJ102PJ-002AIC1J1
CONN4-DIN-RTSVIDEOCONN_0_CONN4-DIN-RT_SVIDESVideoConnIC1P4
CONN-6N1-MMC-SDMMC4_2.0_CONN_CONN-6N1-MMC-SD_MMHC-W21-601IC1P8
CUI-SJ1-3513-SMTPHONOJACK STEREO-R_CUI-SJ1-3513PHONOJACK STEREO-RIC2P5; P6
DBV6-27X39-6SN74LVC2G07DCKR_DBV6-27X39-6_ICSN74LVC2G07DCKRIC1U4
DGN-16X60TPS2061_2_DGN-16X60_TPS2061 (DGTPS2061 (DGN)IC1U6
DRB8-14X33-PADTPS73701_0_DRB8-14X33-PAD_TPS73TPS73701IC1U2
F603-41X39DIODE BI-DIR TRIG_F603-41X39_PGPGB0010603MRIC2D1; D15
F603-41X39DIO_V5.5MLA0603_F603-41X39_PG_1PGB0010603MR,DNIIC1D2
F603-41X39DIO_V5.5MLA0603_F603-41X39_PGB0PGB0010603MRIC4D3; D4; D13; D14
F603-41X39DIO_V5.5MLA0603_F603-41X39_DIO_DIO_V5.5MLA0603IC4D8; D9; D10; D11
HDMI-SMT-W-FLANGEHDMI_CONN_3_HDMI-SMT-W-FLANGE_HHDMI_ConnIC1P10
IND603-24X32INDUCTOR_IND603-24X32_FERRITE,FERRITE, MMZ1608R301AIC3L4; L5; L6
IND-LPS3010INDUCTOR 1.0UH_IND-LPS3010_1UH1uHIC1L2
IND-LPS3015INDUCTOR 1.0UH_IND-LPS3015_1UH,1uH,2AIC2L1; L3
JUMP2-6040JUMPER_0_JUMP2-6040_JUMPERJUMPERIC1J2
JUMP2X5-6040HEADER 5X2_1_JUMP2X5-6040_HEADEHEADER 5X2IC1P9
JUMP2X7-6040-K6JUMP_0_JUMP2X7-6040-K6_IO_7638576385-407LFIO1P2
JUMP2X14-6040-1HEADER 14X2_JUMP2X14-6040-1_HEAHEADER 14X2IC1J3
LED1206-59X59LED_LTST-C150GKT_0_LED1206-59X5LTST-C150CKTDISCRETE4D5; D6; D7; D12
PAP64-12X70TFP513_1_PAP64-12X70_TFP410TFP410IC1U8
POLYSW200-5638-310PTC_POLYSW200-5638-310_RXEF010RXEF010IC1RT1
PWP14-12X70TPS21XX_1_PWP14-12X70_TPS2141TPS2141IC1U1
R402-25RDRES_0_R402-25RD_DISCRETE_56.2K,56.2K,0603DISCRETE1R7
R402-25RDRES_272-0065-000_R402-25RD_DISC33DISCRETE1R10
R402-25RDRES_0_R402-25RD_DISCRETE_10K_1%10KDISCRETE23R11; R12; R13; R14; R36; R49; R51; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R66; R82; R98; R101; R102; R109
R402-25RDRESISTOR_R402-25RD_10K10KIC4R15; R16; R22; R37
R402-25RDRESISTOR_R402-25RD_100K100KIC5R17; R18; R19; R20; R21
R402-25RDRES_272-0065-000_R402-25RD__1.61.65KIC2R27; R28
R402-25RDRES_0_R402-25RD_DISCRETE_33_1%33DISCRETE3R38; R40; R42
R402-25RDR_R402-25RD_10K10KIC1R39
R402-25RD0402_4R7K_1_R402-25RD_DISCRETE_4.7KDISCRETE3R41; R45; R47
R402-25RD272-0067-000_0_R402-25RD_DISCRE33DISCRETE2R44; R46
R402-25RDRES_0_R402-25RD_DISCRETE_1K_1%1KDISCRETE2R96; R99
R402-25RDRES_0_R402-25RD_DISCRETE_4.7K_14.7KDISCRETE2R97; R100
R603-35X45RESISTOR2_R603-35X45_0,06030,0603IC1R1
R603-35X45RESISTOR_1_R603-35X45_620K,1%,0620K,1%,0603IC1R3
R603-35X45RESISTOR_2_R603-35X45_200K,1%,0200K,1%,0603IC1R4
R603-35X45RES_0_R603-35X45_DISCRETE_10K,010K,0603DISCRETE8R5; R29; R30; R31; R32; R33; R64; R65
R603-35X45RES_0_R603-35X45_DISCRETE_22.6K22.6K,0603DISCRETE1R8
R603-35X450805_200_1_V_R603-35X45_8,200,6
8,200,603
IC1R9
R603-35X45RES_272-0065-000_R603-35X45__0_0IC2R23; R26
R603-35X450805_200_1_V_R603-35X45_200.060200.0603IC2R34; R35
R603-35X45RES_0_R603-35X45_DISCRETE_0_1%0DISCRETE1R43
R603-35X45RES_0_R603-35X45_DISCRETE_820_5820DISCRETE1R48
R603-35X45R_R603-35X45_820,603
820,603
IC1R50
R603-35X450402_10K_1_R603-35X45_DISCRETE_8.064kDISCRETE1R52
R603-35X45RES_0_R603-35X45_DISCRETE_510_1510DISCRETE1R95
R603-35X45RES_0_R603-35X45_DISCRETE_1K,061K,0603DISCRETE4R103; R104; R105; R110
R603-35X45RES_0_R603-35X45_DISCRETE_0,DNI0,DNIDISCRETE2R106; R107
R603-35X45RES_0_R603-35X45_DISCRETE_0.DNI0.DNIDISCRETE1R108
R805-35X60RES_0_R805-35X60_DISCRETE_1.0,01.0,0805DISCRETE1R6
RPAK16-10X25-2HVRPAK_RPAK16-10X25-2HV_DISCRETE_10DISCRETE4RP1; RP2; RP3; RP4
SC88RN1907_SC88_RN1907RN1907IC1Q1
SW4-6040-PUSHSW_KT11P2JM_4_SW4-6040-PUSH_DISB3F-1000DISCRETE2S1; S2
TP1-20SMTTESTPT1_0_TP1-20SMT_TESTPT1TESTPT1IC15TP3; TP4; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP19; TP20; TP21; TP22; TP23
TP1-20SMTTESTPT1_0_TP1-20SMT_TESTPT2TESTPT2IC2TP5; TP6
TP1-8040TESTPT1_0_TP1-8040_TESTPT1TESTPT1IC2TP1; TP2
TSSOP16-14X70MAX3221_1_TSSOP16-14X70_SN65C32SN65C3221EPWIC1U10
USB-MINI-SMT-NUMMINI-USB-AB-SOCKET_1_USB-MINI-SUX60-MB-5ST, miniUSB Type ABIC1P1
USB_A_SHCONN_54819-0578_2_USB_A_SH_IO_UUSB-A Conn. - 87520-xx1xxIO1P7
XTAL2_FX135QUARTZ-32KHZ-CM200S_0_XTAL2_FX132KHz,FX135DISCRETE1Y2
XTAL4-47X51-ECXOOSC_230-0067-000_0_XTAL4-47X51-ECLIPTEK_26MHZIC1Y1A
XTAL4-SG210OSC_230-0067-000_0_XTAL4-SG210_ECLIPTEK_26MHZIC1Y1
1 I& h( S8 Z' J* i" U6 B
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
, p" d4 q- }3 Y
发表于 2019-12-13 19:56 | 只看该作者
好像有根线没连上
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2019-12-16 22:11 | 只看该作者
    谢谢分享
    “来自电巢APP”
    GMT+8, 2025-7-20 10:41 , Processed in 0.125000 second(s), 27 queries , Gzip On.
