查看: 507|回复: 1
[Allegro15.5][6层]OMAP-L138 Hawkboard(OMAP-L138+DDR2+网口+USB口)pcb文件
发表于 2019-12-12 17:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
" e9 _) _6 _# O5 [1 e1 U7 Y* w! \
文件描述:
" Z+ c5 l, T$ G% I- `3 I
1. 作品用途:Usb+串口+存储
2. 软件版本:allegro15.5
3. 层数:6层
4. 用到的主要芯片:OMAP-L138+DDR2+网口+USB口
5. pcb尺寸:100*90  MM
4 g6 O! l# W: j) ~  t/ @# D% a% {
作品截图如下:
* r4 M8 [% c( W0 p5 @2 P
顶层截图:
4 M2 u; {: |- G6 ~& b8 R8 ]5 ?) d
底层截图:
: e/ @0 w( W7 _( T; _* X0 o* J
* W* I6 H! I. n# Q$ ~
全层截图:
7 h; Z3 T2 W: E; g; ]; O, e
叠层信息:
9 b: ]* @+ p- v1 W& a4 A3 W5 I3 _/ @7 E! [3 `' I" C3 O
BOM:
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_CLASS
QUANTITY
REFDES
名称
类型
属性
类别
数量
位号
BATTERY
BATTERY_0_BATTERY_BATTERY HL
BATTERY Hl
IC
BH1
BGA361
OMAP-L138_0_BGA361_OMAP-L138
OMAP-L138
IC
U6
BGA-63
K9F1208R0C_8_BGA-63_MT29F1G08AB
MT29F1G08ABCHC:C
IC
U17
BGA-DDR2
MT47H64M16HR _1_BGA-DDR2_MT47H6
MT47H64M16HR-3 IT
IC
U16
C0402
CAPACITOR NON-POL_C0402_0.1UF/5
0.1uF/50V X7R
IC
116
C3; C19; C20; C21; C22; C23; C24; C25; C28; C29; C30; C32; C33; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C47; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C65; C66; C67; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C85; C88; C95; C96; C97; C98; C100; C101; C102; C103; C104; C105; C107; C108; C117; C118; C119; C121; C125; C127; C129; C132; C134; C136; C137; C139; C140; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C165; C166; C167; C168; C169; C170; C173; C175; C181; C182; C184; C185; C186; C187; C188; C189; C192
C0402
CAP NP_C0402_0.1UF/50V X7R
0.1uF/50V X7R
DISCRETE
C4; C91; C92; C93; C94
C0402
CAPACITOR NON-POL_C0402_0.22UF/
0.22uF/50V X7R
IC
C26; C27
C0402
CAPACITOR_C0402_0.1UF/50V X7R
0.1uF/50V X7R
IC
C69; C70; C138; C202; C203
C0402
CAPACITOR NON-POL_C0402_33PF/50
33pF/50V NPO
IC
C106; C111; C114
C0402
CAPACITOR NON-POL_C0402_100PF/5
100pF/50V NPO
IC
C109; C112; C115
C0402
CAPACITOR NON-POL_C0402_270PF/5
270pF/50V NPO
IC
C110; C113; C116
C0402
CAPACITOR NON-POL_C0402_0.01UF/
0.01uF/50V X7R
IC
8
C120; C122; C126; C128; C130; C133; C135; C141
C0402
CAP NP_1_C0402_0.1UF/50V X7R
0.1uF/50V X7R
IC
C179
C0603
CAP POL_C0603_1UF/16V/X7R
1uF/16V/X7R
IC
C7; C180
C0603
CAPACITOR NON-POL_C0603_10PF/_1
10pF/50V X7R
IC
C48
C0603
CAPACITOR NON-POL_C0603_18PF/50
18pF/50V NPO
IC
C83; C84
C0603
CAPACITOR NON-POL_C0603_33PF/50
33pF/50V/COG
IC
C86; C87; C199; C200
C0603
CAPACITOR NON-POL_C0603_27PF/50
27pF/50V X7R
IC
C89; C90; C171; C172
C0603
CAPACITOR NON-POL_C0603_1UF/16V
1uF/16V/X7R
IC
C99; C142; C191
C0603
CAPACITOR NON-POL_C0603_330PF/1
330pF/100V X7R
IC
C164
C0603
CAP NP_C0603_220PF/50V X7R
220pF/50V X7R
IC
C174; C176
C0603
CAPACITOR NON-POL_C0603_10PF/50
10pF/50V COG
IC
C193; C194; C195; C196
C0603
CAPACITOR_C0603_0.022UF/50V X7R
0.022uF/50V X7R
IC
C197
C0603
CAPACITOR_C0603_0.1UF/50V X7R
0.1uF/50V X7R
IC
C205
C0805
CAP POL_C0805_10UF/16V X5R
10uF/16V X5R
IC
14
C1; C2; C5; C6; C8; C9; C10; C11; C12; C13; C14; C183; C190; C201
C0805
CAP POL_C0805_2.2UF/16V X7R
2.2uF/16V X7R
IC
C15; C16; C17
C0805
CAP POL_C0805_1UF/16V/X7R
1uF/16V/X7R
IC
C18
C0805
CAPACITOR NON-POL_C0805_10UF/16
10uF/16V X5R
IC
11
C31; C34; C46; C49; C50; C64; C68; C81; C123; C124; C131
C1206
CAPACITOR NON-POL_C1206_4.7UF/2
4.7uF/25V X5R
IC
C82
C1206
C_C1206_1000PF/2KV X7R
1000pF/2KV X7R
IC
C198; C204
CAPT6032N
FUSE_CAPT6032N_1500MA
1500mA
IC
F1
CC1206P
R_CC1206P_1.0OHM 2W
1.0ohm 2W
IC
R2
CON2X100P-14
CON14AP_0_CON2X100P-14_72454-01
72454-014LF
IC
J6
CSM-7
CRYSTAL_4_CSM-7_CS10-24.000MABJ
CS10-24.000MABJ-UT
IC
Y3
CSM-7
CRYSTAL_5_CSM-7_CS10-14.31818MA
CS10-14.31818MABJ-UT
IC
Y4
CSM-7
CRYSTALL_0_CSM-7_CS10 25.000MAB
CS10 25.000MABJ-UT
IC
Y6
DB9-HF
DSUB9-MALE_DB9-HF_190-009-163R0
190-009-163R001
IC
J3
DBV
NC7WZ16P6X_1_DBV_SN74LVC2G34DBV
SN74LVC2G34DBVR
IC
U9
DBV
SN74LVC1G11_DBV_SN74LVC1G11DBVR
SN74LVC1G11DBVR
IC
U10
DCU
SN74LVC2T45DCUT_DCU_SN74AVCH2T4
SN74AVCH2T45DCUR
IC
U11
DCU
SN74LVC2T45DCUT_DCU_SN74LVC2T45
SN74LVC2T45DCUR
IC
U13
DCU
TXS0102DCUR_DCU_TXS0102DCUR
TXS0102DCUR
IC
U15
DIP8
SW DIP-4_0_DIP8_MGDH04
MGDH04
IC
SW1
F0805
INDUCTOR_F0805_MMZ2012S121A
MMZ2012S121A
IC
27
FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20; FB21; FB22; FB23; FB24; FB25; FB26; FB27
FSX
CRYSTAL_6_FSX_FSX327LF
FSX327LF
IC
Y2
HDR50X2
CONN PCB 50X2-S_HDR50X2_GRPB502
GRPB502VWQP-RC
IC
J13
L0805
INDUCTOR_L0805_1UH/80MA
1uH/80mA
IC
L4; L5; L6
LED0805
LED_LED0805_LED-G
LED-G
IC
LED1; LED2; LED3; LED4; LED5; LED6
LQFP48
THS8135PHP_8_LQFP48_THS8135PFP
THS8135PFP
IC
U12
MINIUSB-5PF
MINI-USB-AB-SOCKET_2_MINIUSB-5P
SD-56579-015
IC
J2
MSOP8
TPS2087_0_MSOP8_TPS2068DGNR
TPS2068DGNR
IC
U3
OSC_7X5
OSC4/SM_0_OSC_7X5_CB3LV-3I-24M5
CB3LV-3I-24M5760
IC
Y5
OSC_SATA
ECS-250-20-33-A-E-L-TR_2_OSC_SA
IC
Y1
PE_RES_0402_3P_OPTION
JUMPER_0_PE_RES_0402_3P_OPTION_
1K/1% 1/10W
IC
R22
POWERJACK
KLDX-0202-AC_1_POWERJACK_PJ-002
PJ-002A
IC
J1
PQFP80
TVP5146M2_1_PQFP80_TVP5147M1PFP
TVP5147M1PFP
IC
U20
PULSE_H2019
S558-5999-46_2_PULSE_H2019_HX11
HX1188NL
IC
TFR1
QFN32
TPS650250_3_QFN32_TPS650250RHBR
TPS650250RHBR
IC
U5
QFN32
CDCM61001RHBT_0_QFN32_CDCM61001
CDCM61001RHBT
IC
U8
QFN32
LAN8700_SMALL_0_QFN32_LAN8710A-
LAN8710A-EZK
IC
U22
QFN48
TLV320AIC3106_5_QFN48_TVL320AIC
TVL320AIC3106RGZ
IC
U21
R0402
R_R0402_220E/5% 1/10W
220E/5% 1/10W
IC
R1
R0402
R_R0402_3.4K/1% 1/10W
3.4K/1% 1/10W
IC
R3; R120
R0402
R_R0402_1K/1% 1/10W
1K/1% 1/10W
IC
9
R4; R28; R33; R34; R43; R44; R128; R129; R153
R0402
RESISTOR_R0402_0E/5% 1/10W
0E/5% 1/10W
IC
19
R5; R6; R58; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R118; R119; R125; R126
R0402
R_R0402_10K/1% 1/10W
10K/1% 1/10W
IC
30
R7; R8; R54; R59; R60; R63; R64; R65; R66; R67; R69; R70; R71; R73; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R92; R99; R100
R0402
R_R0402_4.7K/5% 1/10W
4.7K/5% 1/10W
IC
43
R9; R10; R13; R16; R17; R19; R20; R23; R29; R30; R31; R32; R35; R36; R37; R39; R45; R46; R47; R48; R49; R50; R51; R57; R101; R102; R103; R116; R117; R130; R136; R143; R145; R146; R147; R149; R151; R154; R155; R167; R175; R191; R192
R0402
R_R0402_1E/5%/1/10W
1E/5%/1/10W
IC
R11
R0402
R_R0402_100K/1% 1/10W
100K/1% 1/10W
IC
R12; R14; R148
R0402
R_R0402_330E/1% 1/10W
330E/1% 1/10W
IC
R15
R0402
R_R0402_5.6K/1% 1/10W
5.6K/1% 1/10W
IC
R18
R0402
R_R0402_1.4K/1% 1/10W
1.4K/1% 1/10W
IC
R21
R0402
R_R0402_200K/1% 1/10W
200K/1% 1/10W
IC
R24
R0402
R_R0402_160K/1% 1/10W
160K/1% 1/10W
IC
R25
R0402
R_R0402_300K/1% 1/10W
300K/1% 1/10W
IC
R26
R0402
R_R0402_60K/1% 1/10W
60K/1% 1/10W
IC
R27
R0402
R_R0402_1.18K/1% 1/10W
1.18K/1% 1/10W
IC
R38
R0402
R_R0402_680E/5% 1/10W
680E/5% 1/10W
IC
R40; R41
R0402
RESISTOR_R0402_100E/1% 1/10W
100E/1% 1/10W
IC
R52
R0402
100E/1% 1/10W
IC
18
R53; R68; R72; R76; R93; R94; R95; R96; R177; R178; R179; R180; R181; R182; R183; R184; R187; R188
R0402
RESISTOR_R0402_10K/1% 1/10W
10K/1% 1/10W
IC
R55
R0402
R_R0402_0E/5% 1/10W
0E/5% 1/10W
IC
R56; R61; R62; R150; R173; R190
R0402
R_R0402_330E/5% 1/10W
330E/5% 1/10W
IC
R90; R91
R0402
RESISTOR_R0402_33E/5% 1/10W
33E/5% 1/10W
IC
R97; R98; R168
R0402
R_R0402_75E/5% 1/10W
75E/5% 1/10W
IC
R121; R122; R127
R0402
RESISTOR_R0402_2.2K/1% 1/10W
2.2K/1% 1/10W
IC
R123; R124
R0402
RESISTOR_R0402_22E/1% 1/10W
22E/1% 1/10W
DISCRETE
9
R131; R132; R133; R134; R135; R139; R140; R141; R142
R0402
RESISTOR_R0402_10E/1% 1/10W
10E/1% 1/10W
DISCRETE
R137; R138
R0402
RESISTOR_R0402_4.7K/5% 1/10W
4.7K/5% 1/10W
IC
R144
R0402
R_R0402_20K/1% 1/10W
20K/1% 1/10W
IC
R152; R160; R161; R165
R0402
R_R0402_5.6K/5% 1/10W
5.6K/5% 1/10W
IC
R156; R157; R158; R159
R0402
R_R0402_2K/1% 1/10W
2K/1% 1/10W
IC
R162; R163; R164; R166
R0402
R_R0402_49.9E/1% 1/10W
49.9E/1% 1/10W
IC
R169; R170; R171; R172
R0402
R_R0402_1.5K/1% 1/10W
1.5K/1% 1/10W
IC
R174; R176
R0402
RESISTOR_R0402_75E/5% 1/10W
75E/5% 1/10W
IC
R185; R186
R0402
RESISTOR_R0402_12.1K/1% 1/10W
12.1K/1% 1/10W
IC
R189
R0402
10E/1% 1/10W
IC
R193
R0402
R_R0402_1M/5% 1/10W
1M/5% 1/10W
IC
R194
R0402
RESISTOR_R0402_220E/5% 1/10W
220E/5% 1/10W
IC
R195; R202
R0402
RESISTOR_R0402_49.9E/1% 1/10W
49.9E/1% 1/10W
IC
R196; R197; R198; R199; R200; R201
R0603
R_R0603_50E/0.5% 1/8W
50E/0.5% 1/8W
IC
R42
R0603
R_R0603_2.2K/5% 1/8W
2.2K/5% 1/8W
IC
R74; R75
RCA
CONNECTOR COAX-J_1_RCA_RCJ-014
RCJ-014
IC
J9
RJ45-59_LED
RJHSE-5384_0_RJ45-59_LED_2-4065
2-406549-4
IC
J12
RN0804
RESISTOR DIP 4_RN0804_4.7K/5% 1
4.7K/5% 1/10W
IC
11
RP1; RP2; RP3; RP4; RP5; RP6; RP7; RP8; RP9; RP10; RP11
SATA
8 HEADER_0_SATA_SD-67491-002
SD-67491-002
IC
J7
SD
MMC4_1.0_CONN_SD_MHC-W21-601
MHC-W21-601
IC
J4
SIP100P2N
B2S_0_SIP100P2N_JUMPER 2P
JUMPER 2P
IC
JP1
SMD_SW
SPST W/ESD_2_SMD_SW_GSE10.00F13
GSE10.00F130QP
IC
S1
SOIC8
TPS3705_0_SOIC8_TPS3705-33DR
TPS3705-33DR
IC
U1
SOIC-D16
TPS2087B_SOIC-D16_TPS2087D
TPS2087D
IC
U2
SOP-DGG48
OCT_DS_BUSTRASCEIVER_0_SOP-DGG4
SN74AVC16T245DGGR
IC
U14; U19
SOT23-5
NC7SZ14P5X_2_SOT23-5_SN74AHC1G0
SN74AHC1G04DBVR
IC
U4
SOT23-5
SN74LVC1G125_SOT23-5_SN74LVC1G1
SN74LVC1G125DBVR
IC
U18
SOT23_3
DIODE ZENER_1_SOT23_3_BZX84B5V1
BZX84B5V1LT1G
IC
D1
SOT23_3
DIODE_DUAL_RS_AJK_1_SOT23_3_BAV
BAV99LT1
IC
DN1
SOT23_3
DIODE_DUAL_RS_AJK_2_SOT23_3_BAV
BAV99LT1
IC
DN2
SOT23_3
2N1613_1_SOT23_3_MMBT3904LT1G
MMBT3904LT1G
IC
Q1; Q2; Q3; Q4; Q5; Q6
SP53
INDUCTOR IRON_SP53_3.3UH/2.6A
3.3uH/2.6A
IC
L2
SPC1608
INDUCTOR IRON_SPC1608_2.2UH/1.7
2.2uH/1.7A
IC
L1; L3
SSOP16
TRS3221ECDBR_1_SSOP16_TRS3221EC
TRS3221ECPWR
IC
U7
STX3500
KYCON ST-3500_3_STX3500_STX-350
STX-3500-4NTR
IC
J10
STX3500
KYCON ST-3500_4_STX3500_STX-350
STX-3500-4NTR
IC
J11
TC7343
CAPACITOR POL_0_TC7343_10UF/6.3
10uF/6.3V POL
IC
C177; C178
TP
TEST POINT_TP_TEST POINT
TEST POINT
IC
19
TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19
USB-A
1-1734084-1_2_USB-A_156-1000000
156-1000000901
IC
J5
VGA-DB15
CONN ASY CENT S/S 14_1_VGA-DB15
070213FR
IC
J8
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
    擦汗
    2021-12-17 15:01
  • 签到天数: 8 天
    [LV.3]偶尔看看II
    发表于 2019-12-13 10:00 | 只看该作者
    看着很漂亮看着很漂亮
    GMT+8, 2025-7-20 06:46 , Processed in 0.156250 second(s), 27 queries , Gzip On.
