* E- q9 K. B; c9 D" X { G分享一份定时器TIM3触发adc采样的程序,可以调用来设置采样率。- E& {! y- a( p, m7 Z! a. @
程序2:
# r6 m( b. k- O) Y# f9 s; A- void ADC1_2_Config(u16 SampleFreq,u16 DMA_BufferSizer)
- ADC_InitTypeDef ADC_InitStructure;
- DMA_InitTypeDef DMA_InitStructure;
- GPIO_InitTypeDef GPIO_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_ADCCLKConfig(RCC_PCLK2_Div2);
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- //定时器3控制采样率
- TIM_TimeBaseStructure.TIM_Prescaler= 0;
- TIM_TimeBaseStructure.TIM_CounterMode= TIM_CounterMode_Up;
- TIM_TimeBaseStructure.TIM_Period= 72000000 / SampleFreq - 1;
- TIM_TimeBaseStructure.TIM_ClockDivision= 0;
- TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
- TIM_TimeBaseInit( TIM3, &TIM_TimeBaseStructure);
- TIM_SelectOutputTrigger( TIM3, TIM_TRGOSource_Update );
- TIM_ARRPreloadConfig(TIM3,ENABLE);
- TIM_Cmd( TIM3, ENABLE );
- DMA_DeInit(DMA1_Channel1); //DMA通道1恢复到默认状态
- DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address; //设置数据来源地址
- DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_DualConvertedValueTab; //设置copy目标地址
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //设置copy方向
- DMA_InitStructure.DMA_BufferSize = ADC_BufferLength; //设置数组大小
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //数据来源不变
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //数据保存的数组地址自增
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word; //DMA操作字长 32位
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word; //DMA操作字长 32位
- DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //普通的DMA操作模式:当DMA操作转移够 数组大小 //所限定的数据总量后,则不再进行DMA操作
- DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA优先级
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //关闭mTM
- DMA_Init(DMA1_Channel1, &DMA_InitStructure); //使能dma
- /* Enable DMA1 Channel1 */
- DMA_Cmd(DMA1_Channel1, ENABLE);
- /* DMA Transfer Complete Interrupt enable */
- NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn; //通道
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //占先级
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应级
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //启动
- NVIC_Init(&NVIC_InitStructure); //初始化
- DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE);
- /* ADC1 configuration ------------------------------------------------------*/
- ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; //ADC1同步规则组模式
- ADC_InitStructure.ADC_ScanConvMode = ENABLE; //启动扫描
- ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; //连续转换
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO; //无外部触发
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //结果右对齐
- ADC_InitStructure.ADC_NbrOfChannel = 1; //转换通道数2
- ADC_Init(ADC1, &ADC_InitStructure); //配置ADC1
- /* ADC1 regular channels configuration */
- ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_28Cycles5); //通道配置
- /* Enable ADC1 DMA */
- ADC_DMACmd(ADC1, ENABLE);
- /* ADC2 configuration ------------------------------------------------------*/
- ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; //ADC2同步规则组模式
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //无外部触发
- ADC_Init(ADC2, &ADC_InitStructure); //配置ADC2
- /* ADC2 regular channels configuration */
- ADC_RegularChannelConfig(ADC2, ADC_Channel_4, 1, ADC_SampleTime_28Cycles5); //通道配置
- /* Enable ADC2 external trigger conversion */
- ADC_ExternalTrigConvCmd(ADC2, ENABLE); //使能ADC2的外部触发模式
- /* Enable ADC1 */
- ADC_Cmd(ADC1, ENABLE); //使能ADC1
- /* Enable Vrefint channel17 */
- // ADC_TempSensorVrefintCmd(ENABLE); // 使能温度传感器内部参考电压通道
- /* Enable ADC1 reset calibration register */
- ADC_ResetCalibration(ADC1); //ADC1的校准
- /* Check the end of ADC1 reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADC1));
- /* Start ADC1 calibration */
- ADC_StartCalibration(ADC1);
- /* Check the end of ADC1 calibration */
- while(ADC_GetCalibrationStatus(ADC1));
- /* Enable ADC2 */
- ADC_Cmd(ADC2, ENABLE); //使能ADC2
- /* Enable ADC2 reset calibration register */
- ADC_ResetCalibration(ADC2); //ADC2的校准
- /* Check the end of ADC2 reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADC2));
- /* Start ADC2 calibration */
- ADC_StartCalibration(ADC2);
- /* Check the end of ADC2 calibration */
- while(ADC_GetCalibrationStatus(ADC2));
- /* Start ADC1 Software Conversion */ //软件启动ADC1,开始转换
- ADC_SoftwareStartConvCmd(ADC1, ENABLE);
- // while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));
- // /* Clear DMA1 channel1 transfer complete flag */
- // DMA_CleaRFlag(DMA1_FLAG_TC1);
- // DMA_Done = 1;
- void DMA1_Channel1_IRQHandler(void)
- if(DMA_GetITStatus(DMA1_IT_TC1) != RESET)
- DMA_ClearITPendingBit(DMA1_IT_TC1);
- DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,DISABLE);
- ADC_Cmd(ADC1,DISABLE);
- ADC_Cmd(ADC2,DISABLE);
- DMA_Done =1;
; G7 g0 J) q- ?% i: b. c- | 3 u- n* a% t; O) G
2 K) f1 N1 |/ M" }- V" U4 `
/ o3 P" I2 i A* a! R$ j调用方式:ADC1_2_Config(5120,512); ; ~" f3 \5 A7 S' ?( P0 |* o3 a' w
& m$ H4 W7 ?' g* M4 e0 P可以用作FFT分析前的采样。
' O0 E0 p8 m; r( i( [4 S
; `3 }9 ~3 j- k( S
& v* y' s7 ~7 I3 n
$ i; k3 C1 B8 _% D! d1 h/ E% p1 j; U: U& k+ i* N
