7 B4 M2 f, {8 G. }( lA13处理器是一种基于ARM Cortex-a8的平板处理器,它对于性能更高(ManyCore Lite)、功耗更低、系统整体更低的android平板来说更具竞争力。正如Android4.0.3的大脑一样,A13使得多任务处理更加顺畅,应用程序加载得更快,你触摸到的任何东西都会立即响应。更重要的是,eLQFP176中有A13Kage与音频编解码,和2分R-TP集成。4 {# \6 w+ Q$ h& q3 U
- c) y0 L5 [+ X* r c- f- h
A13芯片特点:* p' y7 }2 D9 j+ V5 S
z) L6 E E1 B d' BCPU1 W! m& x& s9 w. T
ARM Cortex-A8 Core
; T. ?, F0 X( A& U ARMv7 Instruction set plus Thumb-2 Instruction Set
' Q% s- t- C4 j$ ?8 C 32KB Instruction Cache and 32KB Data Cache5 B+ K4 ^' L% q& d
256KB L2 Cache
5 D, W! N0 F) m/ @ l. r NEONTM SIMD Coprocessor
. H% S% u6 b" W. { Jazelle RCT Acceleration; D1 b# F! N2 L
7 c: p R4 @; a
GPU
4 k8 d) h7 S0 E5 Q# E3D Graphic Engine
8 `* V6 F0 z2 a; E3 i0 m5 R---Support Open GL ES 1.1/ 2.0 and Open VG 1.1
9 x" p" d8 k3 N8 D3 ?
`8 L# d: `# ^2 }) I9 h/ zVideo Engine; @+ n' {1 n7 O
Video Decoding (FULL HD)
, t2 M8 ]* a1 W9 {---Support multi-format video decoding, including VP6/8, AVS, H.264, H.263, MPEG-1/2/4, etc& h2 m% R Z0 {) } r+ I
---Up to 1080p@30fps resolution in all formats% m0 O7 \- c' p4 f
Video Encoding
, u/ r$ o- ^; @& e2 J/ n. I9 X, \---Support encoding in H.264 MP format, l! B6 H8 V7 M6 B$ f4 I% n
---Up to 720p@30fps resolution
1 c3 {# n- s) `! P
* S: N( ?' w! x9 N4 M4 MDisplay Processing Ability
) A" U$ I$ B7 y' l1 M
7 @) M+ d; }! y5 CFour moveable and size-adjustable layers
* ~6 y3 z0 A0 F* e ~+ |4 kSupport multi-format image input ~$ B& ]& a4 j8 Q1 p: Y
Support image enhancement processor
' N5 P1 M. ~; ]3 d! t0 NSupport Alpha blending /anti-flicker
6 b- m' L/ ?# o0 d; u# _Support Hardware cursor
: B. ^# t; M: _3 a. i HSupport output color correction (luminance / hue / saturation etc)
5 ~ z# i) a9 H$ n2 k$ ?
8 a; s4 W' H9 [( P% D9 uDisplay Output Ability
! _/ i8 c6 M+ J4 Y* ?7 @1 ULCD inteRFace (CPU / Sync RGB )
8 p/ S; e2 P" e: B
" A! Q" W z1 D, T" | D' f: c1 jImage Input Ability
7 p6 z& v: d- O( C9 @8 PSupport 8bit CMOS sensor parallel interface+ m- l3 s' z' l- D1 J, v2 h
Support CCIR656 protocol for NTSC and PAL
z3 Z8 h$ p: P) r1 G/ M/ g$ ] c& T, u! [
Memory1 k# g6 n4 u* {& C
16-bit SDRAM controller
0 Q c( p9 \* @( S, R% J---Support DDR2 SDRAM and DDR3 SDRAM
& }: p4 f; ^2 F1 s---Memory Capacity up to 512MB3 V+ a+ E! K7 p2 ~/ U
8-bit NAND Flash Controller with 2 CE and 2 RB signals' V' n4 x7 b0 s% [) S0 b
---Support SLC/MLC/TLC NAND
7 d( [8 f! P4 b+ |8 x& T) f6 y; P---64-bit ECC% I5 t9 K% g3 i* r/ ]
+ u1 w2 [) f0 w, I, uExternal Peripherals
) {1 f- ~2 R8 l. Y6 AOne USB 2.0 OTG controller for general application and one USB EHCI/OHCI controller for host application
& p7 S- _/ ^9 P6 f4 wTwo High-speed memory controllers supporting SD version 2.0 and eMMC version 4.3. F# J. @0 k1 x( u6 V ^# r
Four UARTs(all with Infrared data Association[IrDA])2 h/ h% U4 u( l' g
Three SPI controllers(master/slave mode) `% j: Q7 ?) ~- P7 Y
Three Two-Wire Interfaces(TWI)
& ^, }) x, {5 x$ {! W+ q9 [IR controller supporting CIR remoter
, v# E; N4 S# F9 n6 J' d; } o6-bit LRADC for line control
1 ?% D/ M9 Q: C1 ?9 c) m; {# ~, OInternal 4-wire touch panel controller with pressure sensor and 2-point touch
9 m* i) `4 p2 n3 B9 cInternal 24-bit Audio Codec for 2-Ch headphone and 1-Ch microphone- {! t: N9 V$ T/ _3 o
- G& f8 }2 c' F# h+ Q
System Peripherals
/ U+ P6 i7 G4 A+ f& Z- C8 channels normal DMA and 8 channels dedicated DMA
t! D9 q' U, F; X5 f2 GInternal 48K SRAM on chip1 w7 m T8 I7 {1 K
6 asynchronic timers, 2 synchronic timers, 1 watchdog, and 2 AVS counters
( D: O5 I1 K' ]0 i0 z+ ?1 N9 d: s( T; ^$ r) F" @
Package 7 B+ |* }: l5 y7 R
eLQFP176 package% Z. G# \+ S& h8 ?; ]0 \7 Z+ Y% C1 [
- @+ q O# p/ N! f: w
7 P4 D2 R7 d4 l% t% f2 V1 j& Y) GA13方框图. h5 m3 G/ y+ y* G# q
$ d. W, ?5 j' {$ S1 ~
5 j' k2 ~3 O8 I, p
& {" m/ O" ?1 J# Z7 l' l |
