查看: 370|回复: 1
LMPA thermal cycling
发表于 2019-11-26 13:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
THERMO-MECHANICAL TEST8 h# Z' Z) b9 K2 e1 b* {( u
PURPOSE:
, x8 O, j4 @2 a5 ?- Z2 `5 zThe thermo-mechanical tests evaluate possible failure mechanisms caused by differences in
( q& b4 @( _/ Z4 sthe thermal expansion coefficient of the different materials used in the board assembly9 j" L3 }6 T. L. h4 o4 [
REFERENCE STANDARD:
+ @3 Y9 R' e( V6 p9 q& VThe test was run according to JEDEC standard JESD-A104 condition G (Temperature
, O+ Z/ c/ E  P& e1 ECycling). Temperature ramp rate is 11oC/minute.* E+ e1 P; d5 {2 b2 M
RESULT:  S) [$ M4 b  {5 _/ ]( L
 After 500 cycles: + H+ h$ K$ D4 p
o SnBiAg1 solder alloy5 C: t0 f& P6 p  q
 64 units in temperature cycling5 m! \1 {' L* j2 {2 p# Y: G9 N
 One early failure seen after 10 cycles. Expect this is an early failure. No
% t0 }- T! R1 ~additional failures noticed till 500 cycles.
8 ?/ j. x. U# N' o4 @o LMPA-Q solder alloy+ I7 p9 s9 j, P# O) V( x# i
- I# |" K6 |# Z: j3 G8 d# l7 z) z+ w No failures noticed till 500 cycles.5 n$ B" C* l7 X) L1 p( D
o LMPA-Z solder alloy
$ m0 [* N: ]0 s' w 64 units in temperature cycling
; o6 G+ d/ h7 N# V* W No failures noticed till 500 cycles
# o, \1 j- p* |7 ^! t
游客,如果您要查看本帖隐藏内容请回复
' T% o# s4 A* y4 v% `* ]9 l% s& y
5 J& c% K' m) E/ \  d2 |
GMT+8, 2025-9-28 21:22 , Processed in 0.140625 second(s), 27 queries , Gzip On.
