查看: 527|回复: 1
Composite Layers A Love or Hate Situation
发表于 2019-11-25 17:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Composite Layers A Love or Hate Situation+ P) h1 U2 O7 Z' {1 G) _% }3 N
3 k$ J* m# ]7 Z( ]" {' R
4 \9 `2 S* x5 V' Q; z0 {
* ], c7 P, \5 j3 h7 h8 V$ f
4 ^* m4 y+ [! k) o- [. N
So Rich says, "Hey John. I just got that 4 layer CAM job from
1 p, g0 P. V  b& X2 p, q0 A" V( J7 ]Curkits-R-US and after CAM350 loaded them, I got 25 layers!- s( v8 D# g- o- G5 U. [% ~! w
What the frapp is going on?"6 u( N( T4 d. S0 i) O2 X2 O
0 N+ r! t4 }7 N8 X- Z3 C& c
7 F4 T9 U/ T- K' }( W* G: _And John says, "Doesn't Curkits-R-US use Allgro? It probably. B) ^; \8 M9 V
contains one or more composite layers."
. x9 c& X& W- K0 @! v; x
# A( Q8 h8 b$ {) |
5 S) K) [3 Y# ^And Rich responds, "I don't care if they designed it with an Etch-
, Y: T# a. S- b* ?+ EO-Sketch. I don't know how to edit the stuff, or export it, or check7 o  [- @, h0 C1 }" K
it, or plot it and I feel if we took the time for you to show me, we'd' o% w  c& e# C' R
no longer be friends."* |; D" P1 W3 {, O
% k# Y& f# I1 y
1 ]' v- }# K6 ]% I5 V, @) \
% V; N% e6 j( L! t5 i) ]# n
# I  m& E) v: h( w, G
Does this sound familiar? Does the word c-o-m-p-o-s-it-e cause your stomach to start twitching? This document is supposed to answer all your questions. Think of this as Rolaids for the PCB CAM.6 @' g* r' X( v3 Y5 [, m
! |' h4 u( \) [2 ~: V# _1 v( z
$ P* Z! Y4 @0 h6 d+ d1 z6 Z
* What is a composite?
- D! B  ^. I* H3 Q- Why do we have composites?) U2 M0 _( i; F0 x& R
- How it's done in the Gerber file$ I6 W  Z" h/ _
: - Good things about them# ~& }6 [# B5 U1 w7 v* @
- Bad things about them
7 o6 y  n; e7 s8 T& W2 v- s
' Y" t# D0 d' B8 w; W
9 m* g  q5 f; m2 Y: l. V8 W* Working with composites& Q$ w; [- M' _$ s( U8 M2 L
- How to create a composite3 L& i3 D7 a& m9 h2 F& v4 g
- How to view them! m" v' g' J& j; M% N% b, u3 p
- How to edit them3 E* R4 |0 i+ G; s
-HowtodoaDRC
4 b. h7 `1 C) Z) e- How to export them! \% _; ~2 d5 n' p0 V( Q: o
4 c# \2 ^$ i+ I
) P$ i1 y" q8 ^* R3 D9 J  v
* Cautions when working with composites
/ a7 X6 r- ]& d3 A0 v: I* z. |/ Z+ Z- Netlist extraction and DRC
5 u. q; ~2 C3 t8 p/ o
- [* Q% c7 f0 d8 c- C
! g6 n: P# v+ P/ U% |$ _& b) k9 X: v* How to convert a multilayer composite to a single layer.0 n7 B( l  j8 Y" d$ ]* z2 J
. q. e8 ^) C4 U" _& N0 m7 k/ M# e
* E% q! a+ {" _( d( y
6 {) Q1 q8 L( l6 Q
; W1 k1 Y2 g  ~" x4 GWHAT IS A COMPOSITE; D& @( T  x0 O5 ~+ I8 D9 H
3 u1 B- y8 E  W; d
% _! G1 X% g  z1 w***** A composite is a single layer that is made up from multiple layers. ***** **
0 n. a. j, H+ H1 |6 @8 D' [Usually each layer has a different polarity (dark vs clear, NOT voltage!) A dark layer adds data to the plot and a clear layer removes data. This is often called paint and scratch too.( q! j; C9 A- |7 m  [/ o# z: g
+ u9 _/ z2 T; C( c6 m8 C
  ~7 I9 P4 C* A7 C( [/ i
5 b: }) d4 V7 p9 k$ ^  _: g' jWhy do we have composites?! W* E( Z: E4 [9 @
: M3 d! d/ U. U9 }
! I  m! I, i& c; V5 n* oWhat's the easiest way to place a connecting trace on an intermal power plane? Ever try to do it? In the old days before laser plotters, you would create three different layers. One was the original plane information. Another opened up a channel or space where the trace from the third  n; d" {6 L  y7 \- t: J" r
layer was placed. Then you would leave the film in the plotter and plot each layer on top of the previous. Or, how do you shield a trace on an outside layer that begins as a solid copper area?) ]! S' x% O! m4 Y, X
3 Z" v" p' y* {+ t
* c* z, ^# q* U
, n9 m6 e; M( [0 ?' C
游客,如果您要查看本帖隐藏内容请回复
* s' u( ^# L! u6 b7 Y6 j
# f% `% m0 K! }9 N0 T; i) m
8 _1 N9 k! u, R* S+ P$ u- N
% V* w: p  ?" D; W( B
0 N8 t: A9 x2 O' Z$ G) y0 X
2 R9 b# j! X2 e0 j: @
3 Z9 W3 _: J& L  t$ ^, \  m
发表于 2019-11-25 19:11 | 只看该作者
哎呦喂,还是英文的
GMT+8, 2025-8-23 19:29 , Processed in 0.125000 second(s), 26 queries , Gzip On.
