* Simulation of block sbTDrOut07_hmodel_01, TT Case, 85C / x3 V/ v8 |) X6 ]) t# Q8 K3 I0 L/ e
.options list node post probe accurate
2 c. z! V6 B. q4 {! d9 z.options BYPASS=0
$ c! B; H! b3 w0 Q.global SUBSTRATE VSS
3 l& y# W4 i$ \3 E7 V) L0 ?1 P! m. [# S% \5 } B; i
********************************************************************( @& u* J5 D1 ?1 U' ~3 b* ?9 o
, {7 f7 l* O4 w# @1 ^: H, w( O0 ^ C* F
9 p* T; x8 g# q+ g6 c .lib "./vendorhspice.1_0v-3_3v-G" TT1 l+ A7 U7 _0 e' e d
.lib "./vendorhspice.1_0v-3_3v-G" TT_hvt, `2 i4 G+ Z' r7 x3 V7 u
.lib "./vendorhspice.1_0v-3_3v-G" TT_lvt
+ t5 p% e. B' ?! N) i .lib "./vendorhspice.1_0v-3_3v-G" TT_na$ U; p- T+ _) ^9 K
.lib "./vendorhspice.1_0v-3_3v-G" TT_BIP) c6 v$ @2 W9 E4 @
.lib "./vendorhspice.1_0v-3_3v-G" TT_DIO9 }1 A3 _/ m I. m# a4 T* `
.lib "./vendorhspice.1_0v-3_3v-G" TT_DIO_hvt
' f& y1 f1 V5 k+ u [ Y) { .lib "./vendorhspice.1_0v-3_3v-G" TT_DIO_na7 x5 }- N) p" k$ i/ \
.lib "./vendorhspice.1_0v-3_3v-G" TT_RES) ]+ G b1 r$ o- ^( r I
.lib "./ResModel.1_0v-3_3v-G" res_t
( f# }) z9 q% l* h+ E! B7 E8 H6 J8 K2 f
.temp 850 p, ^& f& a& T/ \+ O+ Q
2 l% F: B3 j R0 } m V9 X7 a********************************************************************* D& Q; V; x& ]& z3 s
+ ?: B+ X" _. H! N$ ^ .inc './TT/sbtdrout07_hmodel_01.inc'# h# p3 u p% ~2 q
.inc './TT/alias.inc'
" c3 Q5 _, P: Y9 J* .inc './data_pattern.inc'" S ] [4 r5 u
4 i( y$ M- l w0 ~0 `********************************************************************
* S) l L6 T/ v/ E" j ]" t+ O# X# |! q
********************************************************************9 K: {- q5 Y8 w6 D' L; K5 x
*StatEye example circuit/ w) G6 Z1 h8 }* s
.param _BW=0.16n
9 C$ x+ _3 w+ \* T) [.param trf='_BW*0.01'
& j2 e( S* M6 x.param opfreq='1.0/_BW'3 T* n! R! a: W+ O
*define ports and stimulus
/ l8 Z& d# q7 v1 p+ o4 q) [P1 data 0 port=1 LFSR (1 0 0 'trf' 'trf' 'opfreq' 1 [7,4,1])) n2 T# t7 j% x$ `$ P% t
P2 pad1 pad0 0 port=2( p; J3 V% ~5 A% V; n9 j
! E/ U- o! @* s" B7 m7 T* v
1 f) X; b1 t+ @
4 |7 F" n$ ` c& S! {
' [( D9 z: t _+ bVAVDD AVDD 0 dc=pwr.vdd
" _& @1 d" m) u/ a$ X" _; [1 Q& QVAGND AGND 0 dc=pwr.gnd
' o ~' p. N- z) ^: V* }/ V8 f+ `/ I+ i8 |
.param pwr.vdd = 0.98
# N6 p& l0 H' S; V# N# ^/ C" `# C.param pwr.gnd = 0.007 h9 W; Q/ M( @3 |3 c
, U0 L3 c% Y8 C8 c( p* U! A. o
2 l; V9 x$ h$ Y2 z
Rsub SUBSTRATE 0 100) {) r- @* l$ V+ O
Rvss VSS AGND 100u
6 Y# C! @& q1 @0 `5 VRagnd AGND 0 100u
# D' @7 U% N5 x. ?
8 R. d+ a& x+ I% K3 C9 q+ f* Set up loads* N7 A, w- P" P; ^
4 V, N* G% g& K7 ]& U, ^# D5 eRL1 pad1 vcm 50.0
& R6 O! l4 ?% x/ }( jRL0 pad0 vcm 50.0
+ h, D& v& q$ ~! I5 S s
2 T$ ^% m; q) c* Add subcircuit with parameter values
3 C7 M" J* S6 R% V! d1 w- W" v
" ^4 H K, t& e( j) T: B$ BXDUT AGND AVDD pad1 pad0 data 'sbTDrOut07_hmodel_01'9 i# b' Q! r+ ~, B
+ sr1=0 eq3=0 eq2=0 eq1=0 Clock=Clock Wait=Wait& s; h4 `/ e! j
3 h, V; T7 R$ j, V) h. p* Set Clock parameter0 [; X8 w3 I: k: m# w
.param Clock=6.250G5 S6 D/ j/ Q0 c7 O4 B! T( M. b
6 s: {" b5 S5 T6 @: F; c* ~- x' @* Set Wait parameter. N$ o1 ]8 ~8 ?/ M- \4 g( H
.param Wait=0n7 s. }9 t' _2 @3 Z
* e/ p/ L6 R* \*.TRAN 100p 50n
5 ^, F' i9 P$ j7 M0 L
1 `4 O# ?6 k' z4 Y% I* NOTE the 100ps timestep will cause interpolation inaccuracy, but does! l6 \4 I! ` \
* give a short simulation time. Serious work should be done at <10ps.7 Q9 b4 m. \8 z9 o
6 z t' R: g" B6 }: t*.probe
+ `# N1 a+ X+ a4 Y" f+ t*+ v(agnd): ^2 U1 q' T' W. o$ b! P, L8 \
*+ v(avdd)
, p( y) p% Y$ D h2 b: `*+ v(data)9 K: h R- i, {/ Y! y# {
*+ v(pad0)
0 r0 E3 ~( L+ ~2 l) ^4 I" V*+ v(pad1)
. l' Y( c; w3 m$ p. j1 C*+ v(vcm)
# ^1 M! K! }6 I9 L*+ i(vavdd)
5 c+ `( p! f& y*+ i(vagnd)# ?/ i. ]/ r, Q6 x$ e5 M4 {+ i1 P
: F" i8 D4 r" o*print and probe
1 G- R6 p; T2 L0 d*eye and ber
! ~3 @; ] a1 r: F) x( N
& a1 x& s7 O5 z# t.probe stateye eye(2) ber(2) eyeBW(2)
8 y& t9 m' {% ^.print stateye eye(2) ber(2) eyeBW(2)5 L7 a! N% L& d
6 a1 Q% K4 F# L( E0 v& [9 W. M
*bathtub curve
# o+ ]1 a- c1 Q0 l# H) @) [8 ~.probe stateye bathtubT(2,1e-11) bathtubV(2,0.0)
! D8 e+ l5 m; C.print stateye bathtubT(2,1e-11) bathtubV(2,0.0)
+ H! r% I9 N k$ `$ q: N( ^- G
+ J0 @, \) b3 i/ T$ X; e; J*eye size
2 g" R. D' { p! e* h2 w.probe stateye eyeV(2,0.0) eyeT(2,1.0e-11)
. S& s6 _5 N2 J' j8 {( m8 c8 h.print stateye eyeV(2,0.0) eyeT(2,1.0e-11)
2 A7 }# b3 ?6 K2 |% c6 S
1 Z7 g1 e3 Q+ s s. p*measurements $ r8 k$ Y3 x8 C' R9 ]
.measure stateye veye1 Veye 2 time=1e-11 tol=1e-10) M5 X5 U+ G" O
.measure stateye heye1 Heye 2 volt=0.0 tol=1e-10% C& E% s/ h/ Y9 y4 S" t; {5 I
.measure stateye worst1 WorstBits 2 time=10p
1 P2 z. J, P$ u$ ?6 @6 q4 t5 V2 z/ t( m# m. Y. F7 N$ ?% W
***********************************************************************" k* [2 V0 M: H$ L1 Q6 r/ ?5 O
+ ?- Y$ ` O+ }7 L! i
.end" w" Y) J3 ]1 _
4 ` k4 b! B- E# {+ A% m
错误信息如下: Init: read install configuration file: d:\synopsys\Hspice_C-2009.03-SP1\meta.cfg4 F6 k& f* @" G, L0 M: I9 W
**error** (e:\sim\stateye\sbtdrout07_hmodel_01_transmit_hspice_model\tt.sp:76)
0 e. b) H1 [0 k5 m# \9 _ syntax error when fetching "'sbTDrOut07_hmodel_01'"
/ f( t, v/ x/ V8 \3 @. I" m% @/ n/ Q3 Z! Z: m
我用hspice2008仿真没有问题。 |
