查看: 532|回复: 2
再给大家介绍一颗红外接收器IRM-3638MF31的使用方法
发表于 2019-11-22 14:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
0 m+ G# n  F* _介绍:
( U* N' d$ ]$ z" Y$ x1 g
The IRM-36xxMF31 series devices are miniature type(微型) infrared receivers which have been developed and designed by using the latest IC technology, specially optimized to suppress inteRFerences(排除干扰) from TFT backlight. The photo diode(光电二极管) and preamplifier(前置放大器) are assembled onto a lead frame and molded into an epoxy package which operates as an IR filter. The demodulated output signal can directly be decoded by a microprocessor.- j/ C& @1 i. @2 @
# V0 b. {8 J6 |2 u  ^
4 ?" H/ @* F/ e$ [# n
特性:
2 F4 L- B! x/ o0 L, p1 H
* N: x7 a3 A  Q: O6 x& h) w2 q
& V& d* d' q% Z$ z$ zHigh protection ability against EMI
+ D' X# |% ?/ z3 C" e* X6 n; `
. q6 z$ Y5 x: N8 {. L- [9 WCircular lens for improved reception characteristics# E& j* L/ M  l) v7 a$ E
* s8 H% `% |7 e; {' U& v1 \Available for various carrier frequencies6 D/ ]$ m2 C* m8 W
1 B' T6 v1 u- O  G
Min burst length: 6 cycles
/ N; o$ m/ r$ w5 g2 R2 j7 w3 o: ^4 m6 Z! e* C4 Q, G% b
Min gap length: 10 cycles
3 k% K% [1 U. U
: R1 @) n0 d, [1 U; c+ S4 `- VSuitable for continuous code
" Y1 \0 e, [0 A$ ?' _1 J8 u
- r9 l+ C1 ^- J$ a% C  w& @* kLow operating voltage and low power consumption
2 ?9 V! y# ?: x+ C
7 N. G3 R8 F: w, Q0 WOptimized immunity against TFT backlight interferences5 \$ \* U( I1 i1 o* e
& ]$ X9 u- f8 n7 q
High immunity against ambient light
* w$ L5 d- S1 S& C& C3 b! F7 K; M+ Q* o, ]: y8 T+ m
Long reception range' q8 W1 d+ T* u9 V3 C  J* a. Q
* h2 y/ v/ d! c' Y' q
High sensitivity
- w2 }  N) @5 M2 ]$ f3 h9 z  G
) x  p) L* g1 [; nPb free and RoHS compliant8 C/ D) J- q4 v/ @3 r
6 l2 p; ?) n" L/ M* J3 x/ `+ D$ y# b1 ~+ T  y* E2 |
实物图和引脚:
. l6 x. `8 h+ i$ L, g6 T9 j$ c: w. P6 r# S
' Z; h$ C' J, d4 X% z1 E" f& b5 h  G! ^0 O& S# p5 k* r
! J* K. X0 l5 K2 f) E  \* X, M
内部结构图:
4 m4 h6 E& j1 K/ X
, A8 r  a) l7 q2 h, r3 Z9 f# i& t* U7 Z
0 ^+ U: b+ s1 S4 T% D- e* Q* {" K% F' R  q+ }, ]/ ?/ {
; F4 @* }2 _; O! t# k- l应用电路图:; n0 R4 u5 V& w
# X. W! s* C8 u6 y& A8 E$ l
5 j6 e+ O7 w( |5 U4 O3 x5 T5 T( H4 S
, x) D% u: X& E' F& V2 i, r& I, z
6 `: C) S7 v. L
3 a$ Z& c3 R/ t: J0 M2 ]
尺寸图:6 p" G- M$ M/ w
* `: G- u8 z: w# k1 d- E/ V5 P7 A7 L
/ m8 A. t" [8 f5 f( n! _ $ W7 t- W1 \9 _- d1 R
) i# u) o& N; Z
; U( n( T6 |8 [- c5 {) o6 g9 W# G/ Y
基本参数:
: {3 _* ]* j* x  t% w. w6 c7 n7 @, W3 S2 ~: ?" o
' y8 n+ ~8 n% w' w6 F6 Q* p2 J9 f, e
2 O, X" j) T6 V# F. N其它参数:
5 Y! Z$ H  u/ a0 p& G+ A
8 ]: Y/ v3 P' f/ s' e' v$ [
5 j! s9 U3 l1 a% i8 m* y
1 S! |/ v% d0 F, R/ ?
/ P/ B; h8 f* `" d+ M% ]8 R! y' c& Y2 t# C7 |& b& N" N2 Z
/ M0 D( P5 s6 _, T/ i3 H: }3 s  n3 k1 b# i. s
  k3 J6 M; L" {  [0 u
  }4 ]7 u: B& P& e; o2 R/ ?
4 M2 G3 G$ T) p, t  E0 i! v
4 @' z3 L4 u& u0 _* k1 {. x& z7 ]3 @; p4 ]& J
发表于 2019-11-22 19:33 | 只看该作者
红外最近用的好像比较多了
GMT+8, 2025-8-24 20:50 , Processed in 0.125000 second(s), 26 queries , Gzip On.
