2 v S; |5 o6 f0 b+ O# F* [2 O E: c! ]( G& t
响应‘提速降费’政策,综合容量评估解决方案分析研究 摘 要 随着移动LTE网络发展趋势,在国家“提速降费”的政策号召下,自今年1月份以来,全面推广“不限量”套餐,LTE网络流量增长迅猛,某地市全网流量较年初增长了2.12倍,高负荷小区占比增长2.14倍,局部热点区域网络负荷问题带来严重的挑战,出现重点高价值区域热点更热,网络干扰严重、容量受限,严重影响用户感知。为此,基于用户感知提升,本文主要从新型网络结构调整和网络资源精准调度两个方案去研究解决。在网络资源精准调度方案中开发和运用了网络资源智能优化系统,网络资源精准调度:通过负荷均衡、参数优化、拆闲补盲、新技术运用等方法,充分发挥资源利用率。网络资源智能优化系统,集成网络负荷预警系统、高负荷小区分析、实施方案输出和系统自适应改进等四部分内容,依托网络资源智能优化系统把容量优化和规划工作体系化。新型网络结构调整,利用宏微结合、内外协同、立体分层的结构化思维,可以从根本上解决当前以宏覆盖为主的网络结构不合理、系统内干扰突出的现状。极大的提高了频谱利用效率和用户感知水平,并具备向5G平滑演进的能力,将有效的提升运营商的投资收益比,为运营商和设备厂商带来更高的红利。 Abstract With the development trend of mobile LTE networks, under the call of the national policy of "speeding up and lowering fees", since January this year, the "unlimited" package has been fully promoted. LTE network traffic has grown rapidly, and total network traffic has increased 2.12 times since the beginning of the year. The proportion of high-load areas increased by 2.14 times. The problem of network load in local hot spots poses serious challenges. Hotspots in key high-value areas are hotter, and network inte RFerence is serious and capacity is limited, which seriously affects user perception. Therefore, based on the improvement of user perception, this paper mainly studies and resolves the two schemes of new network structure adjustment and network resource precise scheduling. The intelligent optimization system of network resources is developed and applied in the network resources precision scheduling scheme. The network resources precision scheduling: through load balancing, parameter optimization, unwinding and blind, and the use of new technologies, the utilization of resources is fully utilized. The network resources intelligent optimization system integrates four parts: network load warning system, high-load cell analysis, implementation output, and system adaptive improvement, and relies on the network resources intelligent optimization system to systematize capacity optimization and planning work. The new type of network structure adjustment, using the structural thinking of macro and micro combination, internal and external coordination, and three-dimensional stratification, can fundamentally solve the current situation where the network structure based on macro coverage is unreasonable and the interference in the system is prominent. It has greatly improved the spectrum utilization efficiency and user perception level, and has the ability to evolve smoothly to 5G. It will effectively increase the operator's return on investment ratio and bring higher dividends to operators and equipment manufacturers. 关键词:提速降费、不限量套餐、新型网络结构调整、网络资源精准调度体系、网络资源智能优化系统、用户感知评估体系 Key Words: Speed-up and Cost-reduction, Open-ended Meals, New Network Structure Adjustment, Network Resource Precision Scheduling System, Network Resource Intelligent Optimization System, User Perception Evaluation System 引言 在“提速降费”政策的背景下,不限量套餐大规模推广, 4G流量增长迅猛,全网流量较年初增长了2.12倍,高负荷小区占比增长2.14倍,对网络造成严重的冲击。LTE高负荷小区日趋严重,热点区域遭遇网络瓶颈,为继续配合市场营销策略的推广。对此,提出以网络容量为主的用户感知提升措施,在网络规划和优化方面进行创新并形成体系化,运用一种新的容量评估解决方案,快速解决网络高负荷问题。 提升用户感知,在容量方面主要是两个方案,一是网络资源精准调度,通过负荷均衡、参数优化、拆闲补盲、新技术运用等方法,充分发挥资源利用率;二是热点区域网络结构调整,打破网络瓶颈,提高热点区域网络容量,同时有效控制干扰。在实际运用中,不断分析和总结经验,对这两个方案形成运用体系,提高其推广价值。 1.容量评估解决需求现状 随着“提速降费”政策的实施,LTE流量将会持续增涨,网络容量重要指标面临巨大挑战,目前高负荷小区占比为5.6%,比达标值0.5%高了5.1%,高负荷小区变化情况如图: 图1 2019年高负荷小区占比指标变化图 当前“不限量”套餐快速推广,热点区域容量问题更加突出,部分区域已出现容量瓶颈,网络承载能力也无法匹配市场用户的发展。且无系统化的评估体系,通过人工评估耗时长,精准度低,无法快速有效的输出容量解决方案,急需做一套网络资源精准调度系统工具、以及容量瓶颈的结构化思维方案来解决当前的困境。 2.研究思路 1. 2.1新型网络结构调整 针对新型网络结构调整研究方向,对新型网络结构调整思路、优化思路、建设方案等方面进行分析和论证。 工作思路 制订提升目标,选择确定本次试验站点,务求提升覆盖效果,提高用户感知。 研究解决方法,研究一种适合市区中心,繁华商业区域,居民楼宇密集的覆盖方法。需提升覆盖效果,分担网络负荷,提高用户感知,减少网间干扰。 确定解决形式,采用宏微结合,形成多层次,多小区,多频段的立体覆盖形式。务求做到低投入、高质量、方便安装、易于维护。 优化整改思路 通过“摸底测试、优化调整、现场查勘、天线整改、联合调优”五步法,优化整改现网天线,具体方法如图2所示: 图2新型网络结构调整总体优化整改思路 总体规划思路 打破传统,灵活组网,立体分层、宏微结合、内外协同。通过三维两步走方法,从拓容量、强深度、控干扰三个问题维度,从优化整改、立体规划两个步骤解决。 2.2网络资源精准调度体系 网络资源精准调度体系,集成网络负荷预警系统、高负荷小区分析、实施方案输出和系统自适应改进等四部分,依托网络资源智能优化系统把容量优化和规划工作体系化。 网络资源精准调度体系包含:网络负荷预警系统、高负荷小区判断和高负荷小区解决方案输出3个模块。 3.研究方法 3.1 新型网络结构调整 3.1.1 成果的创新性和技术性 新型网络结构调整的创新性: 1)对覆盖区域各场景的小区负荷采用科学的负荷预估算法; 2)区分楼间对打和传统宏站的性质,楼间对打旁瓣、反射、绕射情况难以避免,在网络结构调整时把楼间对打的地位提升至并列至宏站小区,创新使用F频段优先用于低话务场景的深度广覆盖,而传统的道路及其它室外覆盖次之。 新型网络结构调整的技术性: 1)楼间对打仍然使用F频段,但要控制覆盖范围,传统宏站配合楼间对打主要覆盖高层住宅楼用户室内,并结合住宅楼和宏站覆盖范围的负荷预警情况,统筹进行覆盖小区的分裂和聚合。 2)热点区域内外协同优化,通过对楼间对打覆盖控制和容量规划后,对热点区域周边相关D频段小区进行规划和优化的调整减配,最终把D频段微站通过超密组网的方式建设到容量层,从而打破整个热点区域的容量瓶颈。 3.1.2 成果的效益和价值 新型网络结构调整的基本点在于打破传统网络结构,通过一系列的协同规划和调整,把微站以超密组网的方式部署与热点区域的话务层。所以新型网络结构调整主要是解决了热点区域的容量问题,在提升用户感知、促进移动业务使用、支撑市场营销推广活动等方面,具有极大的效益和价值。 3.2 网络资源精准调度体系 3.2.1 成果的创新性和技术性 网络资源精准调度体系的创新点: 1) 开发网络资源智能优化系统,集成负荷预警、高负荷小区分析和解决方案,具体实施方案等功能,在容量规划和优化方面形成体系化。 2) 在高负荷小区分析和解决方案中,把高负荷小区的分析和解决方案的输出系统化,特别是高负荷小区扩容方案的输出,完全改变了当前扩容规划的工作模式。 网络资源精准调度体系的技术性: 1) 在负荷预警功能中构建了日常小区容量增长预估算法、节假日保障容量预估算法、按给定增长率算法等三种更科学的算法。 2) 高负荷小区扩容方案的输出实现系统化,解决做大批量小区扩容方案工作的困难。 3.2.2 成果的效益和价值 据了解,某区域分析一个月的高负荷小区并输出解决方案,他们是通过24人左右加班一周完成,说明当前设备商运营商都同样面临该工作量大的问题,苦不堪言,所以网络资源智能优化系统的开发运用,在人力资源和工作效率方面的改进效果非常明显。 4.总结 新型网络结构调整方案是充分利用波束可调天线的性能优势,实现了网络分层,在控制干扰的同时,提高网络容量,在突破网络热点区域容量瓶颈的同时,大量部署超密组网,积极抢占杆站资源,为5G网络建设提供了网络基建便利,该方案可在全网高负荷热点高价值区域进行推广。 网络资源智能优化系统,不仅把对容量的规划和优化工作系统化、集成化和体系化,同时也大幅度提高了工作效率和数据分析的准确率。 8 t3 q0 k" z9 V0 h. v; U
