查看: 1488|回复: 2
orcad中元件信息中的device起什么作用?
发表于 2009-8-14 10:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题,orcad中画原理图调入元件时需要修改元件信息,其中有一行device不知道起什么作用,而且现在导网表时候会出现 [ALG0013] Conflicting values of following Component Definition properties found on LED_R7 and LED_R1 for part "SMD_R_0603".
, w" e2 ~0 n4 \* V1 W# E6 {$ {              VALUE
$ _! \, Q+ E0 {2 L+ @& R  都是电阻,这两个名字的值不能叫一样的吗?
发表于 2009-8-14 11:16 | 只看该作者
Error[ALG0013] Conflicting values of following properties found on different sections of < Part Reference >, m: r6 ]# S  a8 Y5 b
For multi-section parts, all sections must have the same values for the properties listed under [ComponentInstanceProps] in the configuration file. For example, ROOM is a component instance property, so if you add {ROOM} to the combined property string when you annotate, then sections with differing ROOM properties will not be packaged together.) B+ O' E7 l( ?
1 }3 E& {- ^7 Z* \; W. e1 u: {You can separate or combine component instances in a multi-section parts just by specifying distinguishing properties in the combined property string. Check the configuration file to identify the component instance properties currently available.
 楼主| 发表于 2009-8-14 16:32 | 只看该作者
版主这英语水平。。。。我汗啊
GMT+8, 2025-8-24 09:22 , Processed in 0.109375 second(s), 24 queries , Gzip On.
