查看: 2623|回复: 10
[HyperLynx] Hyperlynx转brd出错求大神帮忙看看,不胜感激
发表于 2019-11-2 10:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Job Name         : C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final
" O) \* S& q, t$ D2 LInput File Name  : C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final.brd$ J5 v5 G& d- o) H" N- G
HYP File Name    : C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final.hyp: @$ s6 [- j2 y/ D% m1 P
REF File Name    : C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final.ref% }1 v" \# Q/ a. M6 z3 ?
Log File Name    : C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final.log
: a, o* T) }6 X/ p2 yErr File Name    : C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final.err
2 e9 z5 v& q# F/ w; BControl File     : C:\mentorGraphics\9.4.1HL\SDD_HOME\hyperlynx64\control_hyp.txt
5 Z8 p% I" X) l- c% z1 ~info : Extracting allegro Board Database
0 \3 F1 O) F6 L8 bERROR: Could not run Cadance Allegro utility: extracta." w. [, }( V& J8 m6 [
ERROR: File or path is not found.
& B( }8 ~' A5 @7 T9 p3 ]: E& r" EERROR: Could not convert file 'C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final.brd'- e" W- i  O0 f, `5 v' P
       to file '"C:\Users\Brave\Desktop\DA750-MB-EVT-V10-BRD_1025_final.a_b"'.+ A0 P# H# F# ^% s+ c
The Allegro-to-HyperLynx translator requires cadence's ASCII-out
1 A2 i/ _; e" f+ a& g7 b" Zutility, EXTRACTA, as well as the Allegro directory structure./ [6 X0 l& ~" v" {( J# {- l1 ?( F6 ~
This can be found in any Allegro installation including the 8 p; s3 h( W0 g5 t/ r. c" f% ?9 n
Allegro Physical Viewer, which is available from Cadence.
# R+ v, b3 R) _6 u% k3 ]7 O; W(The free download - Allegro FREE Physical Viewer - will not
$ M2 i2 j% W% v$ l- u' Owork for this purpose.)
/ i% U2 T9 m# THyperLynx Online Help includes instructions for operation of a+ ]8 V; t+ `$ V; h: B
HyperLynx utility that works with Cadence's Extracta, and that can  v* }, N6 }' I" u% o
be provided to your PCB service bureau.  This application is allegro2hyp;. f- w  i1 A( h2 ~+ v
and you can read more on this subject by navigating to 'Cadence Allegro
7 B! N/ [$ Z3 `" L, o: s0 c' wTranslator' topic in the HyperLynx Help system.7 l2 V% W6 W) l! X! p
info : Error with extraction3 b# x$ ~8 K, R2 L6 \  D9 Q& k
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2019-11-6 10:09 | 只看该作者
    要装Allegro软件才能导入
    有装allergo 17.2啊  详情 回复 发表于 2019-11-10 10:09
     楼主| 发表于 2019-11-10 10:09 | 只看该作者
    dzkcool 发表于 2019-11-6 10:097 s) T: e$ M2 h8 w( o! B: B1 z
    要装Allegro软件才能导入
    & E7 i! a  G- u1 i
    有装allergo 17.2啊
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2019-11-10 14:44 | 只看该作者
    不支持17.2,要装16及以下版本
    版主16.6可以嘛  详情 回复 发表于 2019-11-10 17:28
     楼主| 发表于 2019-11-10 17:28 | 只看该作者
    dzkcool 发表于 2019-11-10 14:44
    ; g, T9 O1 [, `/ |  U2 \不支持17.2,要装16及以下版本
    6 A4 Z) Z9 Z! m- |8 `! N* p4 g# A版主16.6可以嘛3 f: s  D- U' W( x( K* M9 F
    郁闷
    2019-11-19 16:10
    发表于 2019-11-12 15:46 | 只看该作者
    brd文件名字改一下,不能有减号
    无聊
    2023-3-3 15:46
  • 签到天数: 8 天
    [LV.3]偶尔看看II
    发表于 2019-11-29 22:07 | 只看该作者
    可以通过Allegro转出ODB++格式,然后再导入到Hyperlynx
    感谢大神不胜感激  详情 回复 发表于 2019-11-30 11:18
     楼主| 发表于 2019-11-30 11:18 | 只看该作者
    ajingge 发表于 2019-11-29 22:07
    / {: z7 d5 [1 \6 d" l可以通过Allegro转出ODB++格式,然后再导入到Hyperlynx
    : r! D7 V0 B  ^( M
    感谢大神不胜感激
    7 B- e9 c8 L& v
    发表于 2021-1-28 17:06 | 只看该作者
    通过Allegro转出ODB++格式需要安装ODB++插件,然后再导入到Hyperlynx
    发表于 2021-2-26 15:54 | 只看该作者
    楼主你的问题解决了吗,我也遇到一样的问题,转ODB格式时,软件直接卡死了……
     楼主| 发表于 2021-3-6 19:53 | 只看该作者
    好久都没用Hyperlynx了
    GMT+8, 2025-7-20 03:47 , Processed in 0.140625 second(s), 24 queries , Gzip On.
