查看: 5272|回复: 2
大家进来看看,帮个忙好吗?
发表于 2009-7-21 09:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
---- Photoplot outline rectangle not found ... using drawing extents9 s9 ?8 R# T+ h) B: F
& [" U) c2 U- M6 hResults from parameter file ...2 y5 ^, W# q* ~* n9 `, D
    DEVICE-TYPE           GERBER_RS274X
. D: }" n2 H( d# w    OUTPUT-UNITS          INCHES/ j, t6 T; `) ?& h9 Z
    FILM-SIZE             2400000 1600000
, I. w$ m' u; g* I/ n    FORMAT                2.5
7 X' f5 ^8 {- O( k- ~! ?8 A    ABORT-ON-ERROR        NO
! R7 [5 v1 {5 Y$ z2 F% U    SCALE                 1% H: i* `1 K; U* n# d
    SUPPRESS-LEAD-ZEROES  YES4 Z( M: P( `* N  M
    SUPPRESS-TRAIL-ZEROES NO( B. @3 C+ u4 A
    SUPPRESS-EQUAL        NO7 b! i1 l7 ~$ D5 V" L" }' r7 y
    UNDEF-APT-CONT        NO
' I7 t+ F4 C) Z( f% b6 j1 r1 h& ?1 l2 d3 z0 ]# j) B
! ]6 H9 Y4 V# S) ~5 t) t     PROCESSING FILM < POWER >7 s$ B# z& l/ X! H5 |
     TO FILE < E:/test-layer4/test-layer4/testpcb/POWER.art > ...
9 v# l$ U$ `8 t" s& `1 x" J================================================================4 H' s# |8 |( Z2 k4 r! x* |' T
  FILM PARAMETERS :3 u3 u3 s  L  }9 W
: }) E/ Z3 A2 r/ ^2 q/ ~  Undefined line width                6.0
$ t* i% k! a3 v  J: a  Mirror code                         NONE8 a0 \8 [1 c- u3 A! s, B! m/ o
  Rotate angle                        NONE3 ^$ a. o; j8 ^3 n
  Offset x:                           0.07 l$ _3 e1 ^2 ]# y) ?" ]0 L
  Offset y:                           0.00 ?0 J4 }; O+ R% x$ U7 N
  Plot negative                       YES
3 k$ P3 \7 {% T7 I" M/ V! H  Suppress unconnected internal pads  NO, R  a+ u5 H! d
    ERROR:  Layer polarity of class ETCH subclass POWER does not
' h1 Z# H9 a4 Q* m* P: l" ^# u              match film polarity of Negative.  DRC may be unreliable.
% o4 A- e& g7 v3 ~3 P) V# q    WARNING: 0 width line found at (0.0 0.0)
! M: m7 o2 f% a; p5 \           ... using undefined line width of 6.08 ]/ R+ X- m: l
% D# j! D" G! h! g( g* P
    ERROR: aborting film - Shape with first seg=(10.1 10.1) [layer=POWER]3 W! `4 {  j% b; o& {  P
has a void with extents [(5474.7 106.1) (5724.9 256.3)] that touches
. N- H: @3 m5 f another shape with first seg=(10.1 10.1). Manually resolve problem.
; d3 T6 Q5 S0 h0 S& u8 ]' f- R. H    ERROR: aborting film - artwork will not be generated!& L# \( Z7 I+ H+ T5 f
Error in POWER--halting output.  Artwork file not generated.
" ?3 r, [1 A% [0 O9 l+ g: O, p *** ERROR with POWER
, j8 f" R8 Z  p& y  U. `$ R! a
" R8 i- G9 ~9 @  J
7 D1 {0 I+ V$ P------------------------------------------------------/ j9 e9 o' O, c2 E
SUMMARY:
7 u1 L( P3 \. t3 U    *** ERROR with POWER
. E9 z& O& B0 n! m9 |! s ARTWORK Error
发表于 2009-7-23 16:53 | 只看该作者
应该是POWER层的铜皮有问题。8 f5 Y( z$ b0 ?4 B& V
用SHAPE的CHECK,输入4,就会显示出错的地方,把这两个地方[(5474.7 106.1) (5724.9 256.3)过细的铜皮修正
发表于 2011-2-25 19:43 | 只看该作者
我也遇到这个问题了,但是我把GND和POWER设置为负片后,竟然通过了,不知为何?但是我个人还是觉得应该设置为负片的。期待高手解决
GMT+8, 2025-7-18 14:17 , Processed in 0.109375 second(s), 24 queries , Gzip On.
