在Virtualbox中装入CentOS 7 ,启动非常慢,还会进入紧急模式,但还是可以进入系统,并且可以正常运行,相关错误及问题如下," s! ?: Z j% [ F
+ }& F6 o$ {! b" Y+ y
>>[michael@~]>>$ journalctl -p err- ?6 w7 E! N6 g+ s' m+ C% [+ ~4 O
4 E* p8 L: {* X
-- Logs begin at 一 2018-10-08 22:12:51 CST, end at 一 2018-10-08 22:24:10 CST. --
& ]0 M' L+ t6 ]: r6 ^( G/ g$ |! Q
9 {& q# [& o, W, p. D4 w- M/ y10月 08 22:14:35 localhost.localdomain systemd[1]: Timed out waiting for device dev-mapper-centos\x2dhome.device./ R2 J* Y" f' U8 K, {9 B9 _
8 K& o6 d; R$ s" @10月 08 22:14:35 localhost.localdomain systemd[1]: Dependency faiLED for /home.) S) h' a3 |* P1 E2 L& o. w
# o! X# m, K. z. C
10月 08 22:14:35 localhost.localdomain systemd[1]: Dependency failed for Local File Systems.0 t# c" n- Q. J; V* T, Z3 I O
( O0 |, l A \: n
10月 08 22:14:35 localhost.localdomain systemd[1]: Dependency failed for Mark the need to relabel after reboot.2 U K3 `+ E7 H/ J7 n' ]
" @7 t q( [% u# d
10月 08 22:14:35 localhost.localdomain systemd[1]: Dependency failed for Relabel all filesystems, IF necessary.
. P/ H( ~& B& d5 `1 N6 z! h
% H$ h4 P+ k' j( S. s% F10月 08 22:14:35 localhost.localdomain systemd[1]: Dependency failed for Migrate local SELinux policy changes from the old store structure to
, J+ T& W. j: q( Z9 P# z. |# d$ m# K' I' I- O% X4 v4 I( Z' g& h
10月 08 22:16:07 localhost.localdomain systemd-udevd[516]: timeout '/usr/lib/systemd/systemd-vconsole-setup'
5 g2 x `2 u4 \- u: ~. l8 x8 B8 R, C, J% A, {
10月 08 22:16:07 localhost.localdomain kernel: NMI watchdog: BUG: soft lockup - CPU#1 stuck for 29s! [setfont:544]: E4 K) [& e- q8 q: ?) r: x% K
, ]% D, N% ?6 h6 u1 P. |; I* I" ?# {10月 08 22:16:07 localhost.localdomain kernel: INFO: rcu_sched detected stalls on CPUs/tasks: {} (detected by 0, t=61422 jiffies, g=1555, c=1
7 Q; H- e7 E4 v/ ~( E- s0 g' c; F. s, Y( ?
10月 08 22:16:07 localhost.localdomain kernel: All QSes seen, last rcu_sched kthread activity 61422 (4294833328-4294771906), jiffies_till_nex+ D/ p! Q& t4 j6 Q% n/ D% a
$ f: ^4 Q3 D7 J5 B* g10月 08 22:16:07 localhost.localdomain kernel: NMI watchdog: BUG: soft lockup - CPU#1 stuck for 29s! [setfont:544]
2 n0 {, l( d o4 A4 y; l3 z' @! i5 _' w/ g/ y2 B
10月 08 22:16:07 localhost.localdomain systemd[1]: Failed to start udev Wait for Complete Device Initialization.
: X8 k. o" i/ v& ]9 W7 t, K
& o1 i8 l: x% h8 `: ^, _2 Q10月 08 22:18:06 localhost.localdomain spice-vdagent[11480]: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.03 f* L+ Y' }+ W5 R$ v+ a. D
/ [1 g! r2 Y9 u10月 08 22:23:00 localhost.localdomain spice-vdagent[12141]: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
' h8 E( [3 L& s( L7 x
( z0 @! a4 P+ ~, t3 R" y10月 08 22:23:21 localhost.localdomain pulseaudio[11984]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.+ r- B& Z1 ?( z0 g9 }+ ?0 }8 i/ W" K
, e1 f2 B' l$ |0 C
. K1 x- \+ y6 s& j
>>[michael@~]>>$ systemd-analyze blame
3 @6 K3 Z( J |* t) k. G9 G7 Y
$ W4 Z, O7 F6 r5 f5 K 3min 8.399s lvm2-monitor.service+ N6 j- M- c u
( O4 c+ u5 m; D! U9 h 3min 5.293s lvm2-pvscan@8:2.service
4 B0 v! Y# y7 ]) `
$ F2 K' }3 l! A- f- b" @ 1min 5.600s plymouth-quit-wait.service0 k* g* a" x4 v( h7 n/ ?
3 e% j5 D0 l7 q 29.166s kdump.service! ?4 j( Q, U4 ]
: O! f4 J8 ~) T5 E. X3 ^) S& X+ u
20.665s vboxadd.service. |% A4 Q# B( [3 C. o
4 u6 p9 S" w9 ?2 a6 C# {8 Z
20.546s dev-mapper-centos\x2dswap.swap
! R" }' r: _, {- ~, I% X; T
. b1 m2 R7 O+ a" A6 r7 o% y! J 7.520s tuned.service
0 p5 T: [* z( E' [7 z
5 m4 A: B( p( G- E1 Z 6.919s firewalld.service
+ ?" L9 S, A5 \1 x( x9 F
; i3 ^" y$ M2 C' i) m 5.576s postfix.service
7 E3 I- s, \) A' z8 o" A6 x
! E B& y. G& |( O 4.849s modemManager.service' w6 q1 k' g# O3 d
! w4 @ y A6 U( U! E请熟悉的网友给个解决问题的方向!!!
4 N& E/ ^9 h. E' M" ^ |
