查看: 401|回复: 2
低信噪比下相位编码信号载频估计新方法
    2019-11-20 15:05
    发表于 2019-10-14 09:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    低信噪比下相位编码信号载频估计新方法
      o! y9 d* q" Y8 \- v
    (电波科学学报2016年第31卷第一期)
    9 c3 w4 a5 k& }5 W
    5 Q# t4 y1 i$ l) P+ H
    摘要:研究了电子侦察中相位编码信号的载频估计问题,提出一种低信噪比下载频佑计新方法.该 方法首先将相位编码信号划分为等长度的交叠区间,并计算各个区间内信号频谱的聚集性测度,然后采用网 格密度聚类算法对聚集性测度进行分类,以聚类结果作为载频佑计的特征类,最后叠加特征类频谱并提取峰 值得出信号载频佑计值,实验结果表明,该方法无需先验知识,对编码形式不敏感,且能够在较低信噪比下完 成相位编码信号的载频佑计,适合于电子侦察场合。
    # r+ b" O; `+ ~4 A1 M& \* o+ ]* a4 D7 Z" o! |" b, H
    关键词:电子侦察;相位编码;载频估计;低信噪比
    $ [8 W9 N5 Y- c7 x! H" ?$ g5 d3 V8 |, k' x4 ~
    Abstract: Carrier frequency blind estimation of phase shift keying(PSK) signals in the electronic re-connaissance is discussed and a novel blind estimation method in iow signal to noise ratio(SNR) is pro-posed. The PSK signal is divided into some overlapping intervals of equal length. The spectral concentra-tion measures of the signal in every interval are calculated based on the Fast Fourier Transform. Then,the grid-density clustering algorithm is adopted to process the spectral concentration measures,and the cluste-ring result is regarded as the characteristic class. Finally,the spectrums of the characteristic class are ac-cumulated to estimate the carrier frequency of the PSK signal. Experimental results shows that the pro-posed method,which can effectively estimate the carrier frequency in iow SNR without any prior knowl-edge and is not sensitive to the coded type,is suitable for electronic reconnaissance occasions. Keywords electronic reconnaissance;phase shift keying;carrier frequency estimation;low SNR .  T) w  R% X/ z* @4 I1 B0 ?
    . ^% X# W# v' A2 y4 p
    & v1 k1 E* r2 t) m0 m' Q
    9 b/ U4 ~) E  S4 O# G1 ]
    游客,如果您要查看本帖隐藏内容请回复
    . N' z9 c8 I3 Y& K$ ~
    9 _  o1 s% k- R# [9 [
    发表于 2019-10-14 20:40 | 只看该作者
    看看楼主说的方法。
    发表于 2019-10-18 14:07 | 只看该作者
    谢谢楼主分享
    GMT+8, 2025-9-28 13:48 , Processed in 0.140625 second(s), 26 queries , Gzip On.
