Do you really execute this same command word by word except for file name ??1 F8 f: X' S4 j5 p: `
+ O4 L$ n, Z. V1 I/ c
#1: execute the following command in XP command prompt
& e2 g$ `4 y- y( ?2 f7 ~' t9 d->extracta.exe R0A.brd hyp.txt R0A.a_l R0A.a_o R0A.a_c
3 }$ r( j) z/ K3 [( u& m6 V+ e) L5 W! J9 W% c6 o' K b7 O
if you execute the same command, except for file name, I do not see how it could create nine txt file, plus *.a_b file (what is that ??)
1 P A1 q. O. f9 O7 [) s" K) v, V
- |! x# B0 q* ?. {" {4 Vwhy not copy your brd file + hyp.txt to allegro extracta.exe directory ("X:\cadence\spb_16.2\tools\pcb\bin") and execute #1 command to see if it create those three files or not ?? (I bet it will unless there is error at brd file)
' Y1 g- @- o! z0 V( p/ b: l" O n# w1 S; P
5 Q, n, I5 M# N. T& F3 fThe Cadence Allegro(extracta.exe) must generate those *.a_c, *.a_l and *.a_o files for interfacing with HyperLynx.
* U0 M3 `; p0 Y0 `2 W1 fPlease refer the document I posted at https://www.eda365.com/thread-22898-1-1.html" x) V2 J S/ N; [: u. d
- Y" p) _ b- }6 @0 {7 VIf you can not create those three files, there is something wrong at Allegro side,
" a2 e' T0 I- x3 w& [" z! {0 Qnot HyperLynx side.
5 |3 I" j6 }2 ?/ K4 h& _! p1 r8 r4 f" C) z3 K; ^
3 m9 [7 C% R c& e
The following is the R0A.log that HyperLynx program created when I successfully finished the conversion.
# Q5 F6 d- P1 n y2 a( x* w6 W3 Z' t- |6 T( w- g
+ ?% O `! a/ B z, z3 }
-------------------------------R0A.log----------------------------------
f) {, k6 l! j6 K% l1 u+ R8 N9 C: C
Allegro2hyp: 7.7.33$ b- ~6 m3 d: M. S4 u, B" t
Copyright Mentor Graphics Corporation 2006. All Rights Reserved., j2 m, Y' `' q! g# X" y2 W+ S
Translating files: ( H1 D( e. D8 o% k0 w4 E+ T n
F:\Allegro_Works\R0A.a_c4 U( @6 O* }, \% \
F:\Allegro_Works\R0A.a_l
2 G! L6 D7 U' X6 ? F:\Allegro_Works\R0A.a_o, O- [4 j J2 M2 w7 P9 v
Use COMP_VALUE or COMP_DEVICE_TYPE for IC names.! P* q$ X: l8 j/ Y5 i$ t
Allegro file translation complete,$ D0 h' s& t. m$ D
F:\Allegro_Works\R0A.hyp created.. I6 X; Y+ _- T# D+ S0 O
- P$ G9 Z# I! N
* N T6 \: N! q8 R! i: v; [- X
& q% B2 p0 s0 I/ j& X-----------------------------------------------------------------
: T9 t2 f) ~+ _0 @% T
) B D- s2 q Y( T% ?) J3 [- F9 U* X
And I think you are using SPB 15.x version that are still with "extract.exe". New SPB 16.x is with "extracta.exe". They should be same as function wise. I have another PC still installed with spb 15.5 ("extract.exe") and got the same result as SPB 16.2 ("extracta.exe")5 ?) |6 l9 J3 d1 p3 ~- Z+ P- I
6 K8 B5 b$ Z( u, S4 s$ b, F9 Z
Hope it will help and good luck ! |
