本帖最后由 ygcgsa 于 2019-10-12 17:17 编辑 7 A! J) w& z5 ]2 V3 i
( A9 u j& e' B# W9 A$ ^; JBGA416-26+BGA96-32-1609D+QFN64-050-0909LH+海思Hi3516开发板+PCB作品文件分享。
. F% L* O" t+ D用AD画的6层板,9 n" y$ X7 E' h+ m
海思Hi3516开发板,$ [+ s/ s% }( Q( |. z% t
板子布局布线很清晰,6 w/ Q7 Y3 D9 B8 D" I+ I9 ^& {
画的很不错,有需要的可以看看。
& Z, E& T! t3 ?/ r. B2 O$ U9 ]) a6 D, n& x7 b1 H! Y: {
2 I2 R4 V$ K [% _0 p% v# v) |' n层数:6层
) z; N. s+ j: @- |( y用途:开发板6 W7 E; T. i# [6 u( x; Y& V# P
pcb作品截图如下:5 W$ D2 i3 @1 E. {+ Q
* l& u/ t8 o! H0 V9 \
+ ?1 y1 g& q( s; M5 \- E
3 { G& M2 g+ L附件:6 S7 F; c! W0 {2 J! |* l% T' ^
8 Y0 \5 B# h. }0 W
BOM:' F7 n) y6 r; ]) F7 f% ?# s
% R: ~* L! [! A) O2 h5 P
Comment | Designator | Quantity | Footprint | SC0603 | C1, C2, C4, C6, C7, C8, C12, C13, C14, C22, C23, C46, C48, C98, C99, C100, C101, C102, C103, C104, C109, C110, C113, C114, C115, C116, C118, C120, C121, C122, C123, C124, C125, C126, C127, C128, C129, C130, C131, C132, C133, C134, C135, C136, C137, C138, C139, C140, C141, C142, C143, C150, C151, C152, C153, C154, C155, C156, C157, C158, C159, C160, C161, C162, C163, C164, C165, C166, C167, C168, C169, C170, C171, C172, C173, C179, C180, C181, C182, C183, C185, C188, C189, C190, C191, C192, C193, C194, C195, C196, C197, C198, C199, C200, C201, C202, C203, C204, C214, C215, C216, C217, C218, C223, C224, C225, C226, C227, C230, C231, C237, C238, C239, C240, C241, C242, C244, C250, C251, C252, C253, C257, C258, C259, C260, C261, C262, C263, C264, C265, C266, C267, C268, C269, C270, C271, C274, C275, C276, C277, C278, C279, C280, C281, C282, C284, C286, C291, C292, C293, C296, C297, C298, C307, C314, C324, C326, C334, C336, C339, C340, C341, C342, C343, C344, C345, C346, C347, C348, C349, C365, C366, C367, C368, C369, C370, C371, C372, C373, C380, C381, C382, C383, C384, C396, C426, C428, C433, C442, C1005, C1011 | 191 | SC0603 | SC0402 | C3, C5, C16, C17, C18, C19, C20, C21, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C65, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C95, C96, C97, C106, C111, C112, C117, C144, C145, C146, C147, C148, C149, C174, C175, C176, C177, C178, C184, C186, C187, C205, C206, C207, C232, C233, C234, C235, C236, C256, C272, C273, C285, C290, C308, C313, C315, C316, C317, C318, C321, C325, C327, C328, C329, C330, C331, C332, C333, C335, C364, C374, C375, C376, C377, C388, C389, C390, C393, C397, C435, C438, C440, C441, C1003, C1004, C1006, C1007, C1008, C1012 | 144 | SC0402 | SC1206 | C9, C10, C11, C44, C45, C47, C105, C222, C283, C294, C295, C299, C300, C301, C302, C303, C304, C305, C306, C309, C310, C311, C312, C322, C323, C394, C395, C429, C430, C431, C432, C1001, C1002 | 33 | SC1206 | SCAPC2-280-327 | C15, C212, C213 | 3 | SCAPC2-280-327 | SC1210 | C107, C208, C209, C210, C211, C378 | 6 | SC1210 | CAP2-300-240 | C108 | 1 | CAP2-300-240 | SC0805 | C119, C219, C220, C221, C245, C246, C247, C248, C249, C254, C255, C338, C350, C351, C352, C353, C354, C355, C356, C357, C358, C359, C360, C361, C362, C363, C379, C385, C386, C387, C420, C421, C422, C423, C424, C425, C437, C439 | 38 | SC0805 | SAC6666 | C228, C229 | 2 | SAC6666 | STC3528 | C319, C320, C391, C392, C1009, C1010 | 6 | STC3528 | SD2723 | D1 | 1 | SD2723 | SOT23 | D2, D3, D4, D5, D6, D7, D8, D13, D14, D15, D16, D17, D18, D23, D32, D33, D36, D37, D43, Q1, Q2, Q3, Q4, Q5, Q6, Q8, Q9, Q10, Q16, Q17, Q20 | 31 | SOT23 | HSOD323A | D9 | 1 | HSOD323A | SEN3-100C | D21 | 1 | SEN3-100C | SD0805-LED | D22 | 1 | SD0805-LED | SOD323 | D30, D31 | 2 | SOD323 | HSD0603-LED | D41 | 1 | HSD0603-LED | SF6127 | F1 | 1 | SF6127 | SIP-3P | J1, J2, J3 | 3 | SIP-3P | VAF2 | J4, J6 | 2 | VAF2 | SDI-5DIP | J5 | 1 | SDI-5DIP | MTMM-125-D | J7 | 1 | MTMM-125-D | MJ8-SRLFY | J8 | 1 | MJ8-SRLFY | PCI36-12V | J9 | 1 | PCI36-12V | HEAD-4P | J10, J29, J30 | 3 | HEAD-4P | CONN_CD_676000004 | J11 | 1 | CONN_CD_676000004 | IDC20-DTM1-A | J12 | 1 | IDC20-DTM1-A | USB8-1715 | J13 | 1 | USB8-1715 | VAF5-A | J14, J16 | 2 | VAF5-A | PWC0103-M-C | J15 | 1 | PWC0103-M-C | DB9-2RM | J17 | 1 | DB9-2RM | DIM0425-80-A | J18 | 1 | DIM0425-80-A | VAF3-A | J19, J22, J23, J25 | 4 | VAF3-A | FPC24-40 | J20 | 1 | FPC24-40 | FPC20-40 | J21 | 1 | FPC20-40 | FPC18-40 | J24, J31 | 2 | FPC18-40 | SIP-6P | J26 | 1 | SIP-6P | SFMC-132-T2-L-D | J27 | 1 | SFMC-132-T2-L-D | MOLEX_47151 | J28 | 1 | MOLEX_47151 | SIP-1P | J32, J33, J34, J35, J36, J37, J38, J39, J40, J41 | 10 | SIP-1P | HSL1007 | L1 | 1 | HSL1007 | SL1210 | L2 | 1 | SL1210 | SL2828 | L3 | 1 | SL2828 | SPL0807D | L4, L5, L1001 | 3 | SPL0807D | SL0603A | L6 | 1 | SL0603A | SL0805 | LB1, LB2, LB3, LB4, LB5, LB13, LB14, LB15, LB16, LB17, LB18, LB20, LB21, LB22, LB23, LB24, LB25, LB26, LB27, LB28, LB29, LB31, LB33, LB34 | 24 | SL0805 | SL0402 | LB6, LB7, LB8, LB9, LB10 | 5 | SL0402 | SL0603 | LB11, LB12 | 2 | SL0603 | HOLE125-8STAR | M1, M2, M3, M4, M5, M6, M7, M8 | 8 | HOLE125-8STAR | SX4-0705 | OSC1, OSC3 | 2 | SX4-0705 | SOP8-50-150 | Q7, Q13, Q1001, U5, U10, U12, U18, U21 | 8 | SOP8-50-150 | SR0603 | R1, R2, R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R14, R15, R16, R17, R18, R19, R21, R23, R29, R61, R62, R63, R64, R65, R66, R67, R68, R69, R70, R71, R72, R73, R74, R75, R76, R77, R78, R79, R81, R83, R84, R85, R87, R88, R89, R90, R91, R92, R93, R94, R95, R96, R97, R98, R105, R106, R107, R108, R109, R110, R111, R112, R113, R114, R115, R116, R117, R118, R119, R120, R121, R122, R123, R124, R125, R126, R127, R128, R129, R130, R131, R132, R133, R134, R135, R136, R137, R138, R139, R140, R141, R144, R146, R147, R148, R149, R150, R151, R152, R153, R154, R155, R156, R157, R158, R159, R160, R161, R162, R163, R164, R165, R167, R168, R172, R173, R174, R175, R176, R177, R178, R179, R180, R181, R182, R183, R184, R185, R186, R187, R188, R198, R199, R200, R201, R202, R203, R204, R205, R206, R207, R208, R209, R210, R211, R212, R213, R214, R215, R216, R217, R218, R219, R220, R221, R222, R223, R224, R225, R227, R228, R229, R232, R234, R235, R236, R237, R238, R239, R240, R241, R242, R251, R252, R253, R254, R255, R256, R257, R258, R259, R260, R261, R264, R265, R266, R267, R269, R270, R271, R272, R273, R274, R275, R276, R277, R278, R279, R280, R281, R282, R283, R284, R285, R286, R287, R288, R289, R291, R292, R293, R294, R295, R296, R297, R298, R299, R300, R301, R302, R303, R304, R305, R306, R307, R308, R309, R310, R311, R312, R313, R314, R315, R316, R317, R318, R319, R320, R321, R322, R323, R324, R325, R326, R327, R328, R329, R330, R333, R334, R335, R336, R337, R338, R339, R340, R342, R348, R349, R350, R351, R352, R353, R354, R355, R356, R357, R358, R359, R360, R361, R362, R363, R364, R365, R366, R367, R369, R375, R376, R377, R378, R379, R380, R381, R383, R384, R385, R386, R387, R388, R389, R390, R391, R392, R393, R394, R395, R396, R397, R398, R399, R400, R401, R402, R403, R404, R405, R406, R407, R408, R409, R410, R411, R412, R413, R414, R415, R416, R417, R419, R420, R421, R422, R423, R424, R425, R426, R427, R428, R429, R431, R434, R435, R436, R437, R438, R439, R440, R441, R442, R443, R444, R445, R446, R447, R448, R449, R450, R451, R1008 | 353 | SR0603 | SR0805 | R13, R24, R268, R341, R382, R418 | 6 | SR0805 | SR1206 | R20 | 1 | SR1206 | SR0402 | R22, R25, R26, R27, R28, R30, R31, R32, R33, R34, R35, R36, R37, R38, R39, R40, R41, R42, R43, R44, R45, R46, R47, R48, R49, R50, R51, R52, R53, R54, R55, R56, R57, R58, R59, R60, R80, R82, R86, R99, R100, R101, R102, R103, R104, R142, R143, R145, R166, R169, R170, R171, R189, R190, R191, R192, R193, R194, R195, R196, R197, R226, R230, R231, R233, R243, R244, R245, R246, R247, R248, R249, R250, R262, R263, R290, R331, R332, R343, R344, R345, R346, R347, R368, R370, R371, R372, R373, R374, R430, R432, R433, R1001, R1002, R1003, R1004, R1005, R1009 | 98 | SR0402 | SRN8-0804 | RN5, RN6, RN7, RN8, RN9, RN10, RN11, RN12, RN13, RN14, RN15, RN16, RN17, RN18, RN19, RN20, RN21, RN22, RN23, RN24, RN25, RN26, RN27, RN28, RN29, RN30, RN31 | 27 | SRN8-0804 | PSW3-RA | S1 | 1 | PSW3-RA | SSW-PUSH | S2, S8 | 2 | SSW-PUSH | SDSW8-L | SW1, SW2, SW3, SW4, SW5, SW6 | 6 | SDSW8-L | STFM24-39-630 | T1 | 1 | STFM24-39-630 | STP40 | TS1, TS2, TS3, TS4, TS5, TS6, TS7, TS8, TS9, TS10, TS11, TS15, TS17, TS18, TS21, TS22, TS23, TS27, TS28, TS29, TS30, TS31, TS38, TS39, TS40, TS41, TS42, TS43, TS44, TS45, TS46 | 31 | STP40 | SOP8-50-173 | U1, U3, U48 | 3 | SOP8-50-173 | BGA324-40-1818 | U2 | 1 | BGA324-40-1818 | MLF40-050-0606L | U4 | 1 | MLF40-050-0606L | SOT23-6 | U6 | 1 | SOT23-6 | SBAT2-3209 | U7 | 1 | SBAT2-3209 | QFN64-050-0909LH | U8 | 1 | QFN64-050-0909LH | SOP8-50-150A | U9, U44 | 2 | SOP8-50-150A | BGA416-26-2222 | U11 | 1 | BGA416-26-2222 | BGA96-32-1609D | U13, U14 | 2 | BGA96-32-1609D | SOT23-5B | U15, U16 | 2 | SOT23-5B | MLF32-050-0505LE | U17 | 1 | MLF32-050-0505LE | SOP8H-50-155A | U19, U27, U28, U29 | 4 | SOP8H-50-155A | SOP38-20-173A | U20 | 1 | SOP38-20-173A | SOP16-26-208-255 | U22, U23 | 2 | SOP16-26-208-255 | QFN-72 | U24 | 1 | QFN-72 | SOP16-50-300A | U25 | 1 | SOP16-50-300A | SOP48-20-720A | U26 | 1 | SOP48-20-720A | SOIC8-50-157 | U30 | 1 | SOIC8-50-157 | SOP16H-26-173A | U31, U1001 | 2 | SOP16H-26-173A | SOP16H-26-173B | U32 | 1 | SOP16H-26-173B | BGA100-40-1010 | U49 | 1 | BGA100-40-1010 | SOP8-26-118 | U54 | 1 | SOP8-26-118 | XTAL2-100 | X1 | 1 | XTAL2-100 | SX2-1205 | X2, X3 | 2 | SX2-1205 | ) n6 |# O7 F9 \& ~( e" Q! d
( L5 G6 x6 U. \" J, `* C5 d) H
j9 n& d. L6 @& b
5 M/ H8 F, j9 T3 w* I. o |
