查看: 508|回复: 1
HC245+74HC138+74HC04+LED 全彩大屏+PCB作品文件分享。
发表于 2019-10-12 17:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
; o0 m+ k8 h0 k- }4 w2 s
HC245+74HC138+74HC04+LED 全彩大屏+PCB作品文件分享。  R+ m, {, A! u: M8 J5 u1 {
用AD画的4层板,
4 e6 N/ \# n1 x, A& u3 x" \1 kLED 全彩大屏,
" J0 v* s/ I5 P& I& X板子很密,有一定难度,$ C% Y+ T7 R' K3 S
有需要的可以看看。( M6 U! V4 [( ?) B" G7 Q
; M% T" Z# V  N. E% T: R层数:4层
4 |$ M2 G0 F* E用途:LED控制1 g& C) t! p8 q$ ^5 F
pcb作品截图如下:
. C* K  n3 D3 e4 F. i; A
/ F- _! Y% O* H  z7 p+ G5 R/ T0 \7 Z
3 k1 `9 P! Q8 W3 V0 Z" H
7 ?; U7 y' e# L" F1 t$ |' }+ Z
附件:
. \, d7 G% {- R0 D* r1 y5 a
游客,如果您要查看本帖隐藏内容请回复
1 V6 ^/ T( l6 _( X; yBOM:
$ V: ^9 M0 x; `$ W, r: V
9 C# p. u! t& ]/ U: V& L
Comment
Designator
Quantity
Footprint
5 P! R' Q# l* [2 ?* |
C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, R1, R2, R3, R4, R5, R6, RH1, RH2, RH3, RH4, RH5, RH6, RH7, RH8, RH9, RH10, RH11, RH12, RH13, RH14, RH15, RH16, RK1, RK2, RK3, RK4, RK5, RK6, RK7, RK8, RK9, RK10, RK11, RK12
50
0805
104
C17, C18
7 o' y0 h1 R4 B( n' k& |
CL2, CL6
YC6*6
4148
D1, D2
DIODE0
& z  I! b: R% B- r
INPUT, OUTPUT
NJ-16
100K
R10
  f- _9 K4 |; l& m
RR1, RR2, RR3, RR4, RR5, RR6, RR7, RR8, RR9, RR10, RR11, RR12, RR13, RR14, RR15, RR16
16
SP4-2
1 z. E: N7 z  n# O- J* T% N7 J( u
T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T18, T19, T20, T21, T22, T23, T24, T25, T26, T27, T28, T29, T30, T31, T32, T33, T34, T35, T36, T37, T38, T39, T40, T41, T42, T43, T44, T45, T46, T47, T48, T49, T50, T51, T52, T53, T54, T55, T56, T57, T58, T59, T60, T61, T62, T63, T64, T65, T66, T67, T68, T69, T70, T71, T72, T73, T74, T75, T76, T77, T78, T79, T80, T81, T82, T83, T84, T85, T86, T87, T88, T89, T90, T91, T92, T93, T94, T95, T96, T97, T98, T99, T100, T101, T102, T103, T104, T105, T106, T107, T108, T109, T110, T111, T112, T113, T114, T115, T116, T117, T118, T119, T120, T121, T122, T123, T124, T125, T126, T127, T128
128
YT4-6MM-S
: t9 S% Q$ [9 W5 u" B
U1, U2, U3, U4, U5, U6, U7, U8, U9, U10, U11, U12
12
SOP24
HC245
U13, U14
SOL-20
$ b% C* K7 n5 _/ O5 N2 J
U15, U16, U17, U18, U19, U20, U21, U22
8
SO-8
74HC138
U23
SO-16
74HC04
U24
SO-14
) ]! W6 t: U% V
5 x; A6 x$ @  Q1 c) j
5 m6 y( ?8 b) `5 T
7 G. N2 o3 a1 {% M: Q+ J7 b' H' l, P5 _: B- `
GMT+8, 2025-7-19 22:23 , Processed in 0.125000 second(s), 27 queries , Gzip On.
