本帖最后由 ygcgsa 于 2019-10-10 15:27 编辑 / k6 g9 e) o: e# `
j4 q$ `5 T& T! @# u3 |# N8 FMEM4G16D3EABG-125+AT24C16BN-SH+MP1482DS+A20-OLINUXINO-MICRO开发板PCB作品文件分享。# K+ f' n) W) T c2 a" J
用AD画的4层板,
* i4 L7 H9 T4 L( R9 ]板子局部较密,$ r }8 C, U0 [7 s
有一定难度,有需要的可以看看。* G1 [+ Z' H$ ~' q
层数:4层: z9 ~; x& x8 i( Y
用途:开发板/ K3 R" c! q( V8 h: o
pcb作品截图如下:- N6 T/ X& P" ?# N8 M/ U) c
8 n0 u. y! Y' j% |0 ~
# T9 F, T% ^4 ~2 p. L5 A
+ {" k+ z$ H5 S( `2 v ~* `2 U0 a( i5 w6 R9 h1 ?0 `; c( v
附件:* V [8 J0 \" q8 r- Z
3 C, t W' g* y5 p$ _% u; m
BOM:
) o4 G' d% z" y% V" A) S) t4 F8 r: O' r; N4 K9 m- I _+ \0 d- N' I
Comment | Designator | Quantity | Footprint | Open | 5V_E, VPS-, VPS+ | 3 | SJ_1_SMALLER |
: h& u( X# L0 J. z# o( u | 5V_E_SATA | 1 | SJ_1_SMALLER |
* K5 U8 o% n, Q7 Q& z& d: g; K | +5V, 1.2V_CPU, 1.2V_INT, 1.5V, 2.5V, 3.0VA, 3.3V, 5VEXT, BAT, GND, IPSOUT, ODT1, SCKE1 | 13 | TESTPAD_40-ROUND | NA(DW02S) | 5V_PWR | 1 | DW02S | DW02S | 5V_SATA_PWR | 1 | DW02S | 220nF | C1, C4, C6, C8, C9, C12, C16, C17, C20, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55, C58, C81, C111, C114, C117, C118, C119, C120, C224, C225, C226, C227, C228, C229, C230, C231, C232 | 54 | C0603_DWS | 220nF | C2, C3, C5, C7, C10, C11, C14, C15, C18, C19, C21, C22, C23, C24, C25, C26, C27, C57, C59, C60, C61, C62, C68, C69, C70, C77, C78, C79, C80, C82, C83, C84, C85, C86, C87, C106, C134, C139, C155, C169, C175, C184, C189, C191 | 44 | C0402_TI | 22uF/6.3V | C13, C56, C64, C67, C76, C101, C103, C104, C105, C109, C115, C133, C138, C157, C168, C173, C186, C190, C193, C194, C197, C198, C199, C204, C205, C206, C207, C209, C210, C211, C212, C219, C220 | 33 | C0603_DWS | 100nF | C63, C65, C66, C74, C75, C88, C89, C90, C92, C93, C94, C95, C96, C122, C124, C125, C130, C137, C161, C170, C171, C176, C203, C216, C221 | 25 | C0603_DWS | NA | C71, C181, C183, C185, C188 | 5 | C0603_DWS | 33pF | C72, C73, C99, C100 | 4 | C0603_DWS | 1uF | C91, C110, C146, C150, C167, C174 | 6 | C0603_DWS | 10pF | C97, C98 | 2 | C0603_DWS | 100nF | C102 | 1 | C0402_TI | NC | C107, C108 | 2 | C0402_TI | 10uF/6.3V | C112, C113, C121, C128, C136, C145, C147, C148, C149, C151, C152, C156, C158, C159, C162, C164, C166, C172, C177, C178, C179, C180, C187 | 23 | C0603_DWS | NA(2.2uF) | C116, C144 | 2 | C0603_DWS | 100uF/16V/LOWESR/105C/6.3x11mm_RM2.5 | C123, C126, C135 | 3 | E2,5-6,3 | 1nF | C127, C129, C131, C132, C160, C165, C182, C218 | 8 | C0603_DWS | 10nF | C140, C141, C142, C143, C200 | 5 | C0402_TI | NA | C153, C154 | 2 | C0402_TI | 3.3nF | C163, C201 | 2 | C0603_DWS | 470nF | C192, C196 | 2 | C0603_DWS | 22pF | C195, C208 | 2 | C0603_DWS | 470uF/25V/LOWESR/105C | C202 | 1 | E5-10,5 | NA(22uF/6.3V) | C213, C214, C215 | 3 | C0603_DWS | LED/YELLOW/0603 | CHGLED | 1 | LED-0603 | 1N5819(S4SOD-123) | D1, D3 | 2 | SOD-123 | 1N5822/SS34/SMA | D4 | 1 | MLL-41 | SMBJ16A | D5 | 1 | DO214AA | 1N5822/SS34/SMA | D6 | 1 | MELF-MLL41 | SIDE_WTCM-TR(3X4) | ENTER, ESC, HOME, MENU, PWR_BUT, RECOVERY, RESET, SEARCH, VOL-, VOL+ | 10 | SW_TAKT3X4 | IRLML6402 | FET1, FET4 | 2 | SOT23 | BSS138 | FET2, FET3 | 2 | SOT23 | FSMD035 | FUSE1 | 1 | 1206 | 5 p$ c! s+ n; F
| GND_PIN | 1 | TEST_PAD40/70/SQUARE | GBH-254-SMT-40 | GPIO-1, GPIO-2, GPIO-3, LCD_CON | 4 | ML40-MALE(GBH-254-SMT-40) | HDMI-SWM-19 | HDMI | 1 | HDMI-SWM-19 | PJ-W47S-05D2-LF_V2 | HEADPHONES, MIC_IN | 2 | PJ-W47S-05D2-LF_5PIN_V2 | FB0805/600R/200mA(201209-601) | L1, L2, L3, L7, L15, L16, L17 | 7 | L0805_5MIL_DWS | CL470nH/0805/1.76R/250mA | L4, L5 | 2 | L0805_5MIL_DWS | FB0805/600R/2A | L6, L8, L10, L11 | 4 | L0805_5MIL_DWS | 2.2uH/1.5A/DCR<0.1R/CD32 | L12, L13, L14, L18, L20, L21 | 6 | CD32 | 10uH/3.15A/20% | L19 | 1 | 8X8MM_3131 | RJLBC-060TC1_GND_MILLING | LAN | 1 | RJLBC-060TC1_MILLING | LED/GREEN/0603 | LED1 | 1 | LED-0603 | DW02R | LIPO_BAT | 1 | DW02R | NA(HN1x2) | MIC2 | 1 | JP1 | Close | NAND_E | 1 | SJ_1_SMALLER_CLOSE_10MILS | YDJ-1136 | PWR | 1 | PWR_JACK_UNI_MILLING | LED/RED/0603 | PWR_LED | 1 | LED-0603 | 4SB25.000F20E15/5x3.2mm/20ppm/20pF | Q1 | 1 | HCX-4S | 32768Hz/6pF | Q2 | 1 | TC26H_3_REPAIR_SMD | 4SB24.000F20E15/5x3.2mm/20ppm/20pF | Q3 | 1 | HCX-4S | 2k/1% | R1, R2, R4, R6, R8, R20, R37, R39, R57 | 9 | R0603_5MIL_DWS | 1R | R3, R31, R51, R53, R60, R62, R63, R66, R68, R71, R72, R74 | 12 | R0603_5MIL_DWS | NA | R5, R23, R25, R49, R50 | 5 | R0603_5MIL_DWS | 330R/1% | R7, R9, R16 | 3 | R0603_5MIL_DWS | 10k | R10, R18, R19, R21, R30, R33, R38, R44, R46, R47, R54, R105, R136, R137 | 14 | R0603_5MIL_DWS | 100k/1% | R11, R17, R29, R91 | 4 | R0603_5MIL_DWS | NA | R12, R15 | 2 | R0402_TI_0R | NA(2.2k) | R13, R14 | 2 | R0603_5MIL_DWS | 560R | R22, R26 | 2 | R0603_5MIL_DWS | 0R(Board_Mounted) | R24, R34, R69, R87 | 4 | 0603_0R | 47k | R27, R28, R40, R52, R79, R84, R95 | 7 | R0603_5MIL_DWS | 2.2k | R32, R65, R70, R73, R75, R76, R81, R82, R83, R85, R93, R94, R120 | 13 | R0603_5MIL_DWS | NA(0R) | R35 | 1 | R0603_5MIL_DWS | 200k/1% | R36, R56, R67 | 3 | R0603_5MIL_DWS | 1k/1% | R41, R86, R104 | 3 | R0603_5MIL_DWS | 4.99k/1% | R42, R61, R77, R80, R89, R138 | 6 | R0603_5MIL_DWS | 51R | R43, R103 | 2 | R0603_5MIL_DWS | 13k/1% | R45, R48, R55, R100 | 4 | R0603_5MIL_DWS | 100R | R58 | 1 | R0603_5MIL_DWS | 0.03R/1% | R59 | 1 | R1206_5MIL_WS | 191R/1% | R64 | 1 | R0603_5MIL_DWS | 3.32k/1% | R78 | 1 | R0603_5MIL_DWS | 8.25k/1% | R88, R97 | 2 | R0603_5MIL_DWS | 1.1k/1% | R90, R92 | 2 | R0603_5MIL_DWS | 6.81k/1% | R96 | 1 | R0603_5MIL_DWS | 10k/1% | R98 | 1 | R0603_5MIL_DWS | 11k/1% | R99 | 1 | R0603_5MIL_DWS | 16.2k/1% | R101 | 1 | R0603_5MIL_DWS | 22.1k/1% | R102 | 1 | R0603_5MIL_DWS | 0R(Board_Mounted) | R106, R107, R108, R109, R110, R111, R112, R113, R114, R115, R116, R117 | 12 | R0402_TI_0R | 22R | R118, R119, R133, R134, R135 | 5 | R0402_TI | NA(10k) | R121 | 1 | R0603_5MIL_DWS | NA(0R) | R122, R123, R124, R125, R126, R127, R128, R129, R130, R131, R132 | 11 | R0402_TI | RA0805_(4X0402)_0R(Board_Mounted) | RM1, RM2, RM3, RM4, RM5, RM6, RM7, RM8, RM16, RM17, RM18, RM19, RM20, RM21 | 14 | R_MATRIX_4_0402_25_625_0R | RA1206_(4X0603)_4B8_4.7k | RM9, RM10 | 2 | R_MATRIX_4 | RA1206_(4X0603)_4B8_51R | RM13 | 1 | R_MATRIX_4 | RA1206_(4X0603)_4B8_100K | RM14, RM15 | 2 | R_MATRIX_4 | RA1206_(4X0603)_4B8_75R | RM24 | 1 | R_MATRIX_4 | RA1206_(4X0603)_4B8_10k | RM25 | 1 | R_MATRIX_4 | SATA-PWA-07 | SATA | 1 | SATA-PWA-07 | MICRO_SD/MMC_CP_NEWTFC-WPAPR-08 | SD/MMC1 | 1 | TFC-WPAPR-08 | PSD006A-LT2-BA0 | SD/MMC2 | 1 | SD_CARD | BC846B | T1 | 1 | SOT23 | A20 | U1 | 1 | TFBGA441 | MEM4G16D3EABG-125 | U2, U3 | 2 | FBGA96_MEM | AT24C16BN-SH | U6 | 1 | SO-08MN | RTL8201CP | U7 | 1 | LQFP48 | H27UBG8T2BTR | U8 | 1 | TSOP48 | SY6280 | U9, U10, U11 | 3 | SOT23-5 | AXP209(QFN48) | U12 | 1 | QFN48 | SY8008C(AA)C | U13, U15 | 2 | SOT23-5 | MP1482DS | U14 | 1 | SOIC8 | SY7208(SOT23-6) | U16 | 1 | SOT23-6 | RCLAMP0524P | U17, U22, U23 | 3 | SLP2510P8 | + Z7 c6 Q% P% I. H7 P* o
| U$5 | 1 | LOGO-OPENHARDWARE_8X8 | 1 a( l5 d0 O( J' I! e( o& D
| U$6, U$8 | 2 | OLIMEX1_V | + j. k! a; N) j4 P* [
| U$9 | 1 | PB | # B% {0 N- i- P$ m0 b" u. O+ k
| U$10 | 1 | |
8 O3 Q+ G) _9 p& Z% H: j& O, y | U$11 | 1 | RECYCLE_BIN1/8 | " [! H& A: x/ z, [" C; a) |. m
| U$12 | 1 | ROHS | HN1X4 | UART0 | 1 | HN1X4 | GBH-254-SMT-10 | UEXT1, UEXT2 | 2 | ML10_S | USB_TWO_LEVEL | USB_HOST | 1 | USB_TWO_LEVEL | USB-OTG | USB_OTG | 1 | USB_MINI_9PIN | WU06S | VGA | 1 | CON1.27MM-6-SMALL_ICSP | AP1231-2.5V(SOT23-5) | VR1 | 1 | SOT-23-5 | 7 X/ f, m6 N* W0 J# ~% @" k
4 u8 q# f; ~; f8 e6 I+ o
7 o" H$ E! N' s
N, i% ~$ y! [6 n) Z8 q3 M |
