有个问题请教:我下载了tisdk包,里面有的uboot是201109的,我使用的开发板是335xd,我想自己编译个uboot测试功能,在没有任何修改的情况下编译报错, , 使用的编译命令是:make CROSS_COMPILE=ARM-linux-gnueabihf- am335x_evm_config7 J7 z, x; S p: F y# B
make CROSS_COMPILE=arm-linux-gnueabihf- am335x_evm3 p6 o# ~* g% }" q4 B
这样编译后报错
. z! Q, c; `. Z7 [. S& V1 |$ l) K; y# L4 w
ake[1]: Entering directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net'$ H; z9 B" J* k8 I1 `' Q
make[1]: Leaving directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net'
& o& a# f2 i/ c! F8 V0 B! Bmake[1]: Entering directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net') l4 |; l& |8 }$ _: P
arm-linux-gnueabihf-gcc -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x80800000 -DCONFIG_SPL_TEXT_BASE=0x402F0400 -I/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/include2 -I/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/include -I/root/work/TOD_uboot/335xd_uboot_201109/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/arm/gcc-linaro-arm-linux-gnueabihf-4.7/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5 -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security -o /root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/drivers/net/cpsw.o cpsw.c -c
6 x+ [+ J) C& D. Zcpsw.c: In function ‘cpsw_init’:4 a0 c6 T) Y- W8 \
cpsw.c:831:8: warning: passing argument 3 of ‘cpdma_submit’ discards ‘volatile’ qualIFier from pointer target type [enabLED by default]
* `* W8 e9 P+ C0 K+ R7 E1 p. x+ C. icpsw.c:652:12: note: expected ‘void *’ but argument is of type ‘volatile uchar *’
2 y" D% [# O) ccpsw.c: In function ‘cpsw_phy_init’:$ r! {6 {3 X4 _( [! k
cpsw.c:923:4: error: ‘CONFIG_PHY_ADDR’ undeclared (first use in this function)/ D! b0 a S+ t" s: n4 t
cpsw.c:923:4: note: each undeclared identifier is reported only once for each function it appears in
- J* T' v& f2 X8 s# ?cpsw.c: In function ‘cpsw_register’:, [$ ~3 c$ N' y! Y# F
cpsw.c:981:12: warning: assignment from incompatible pointer type [enabled by default]2 R" i5 Q0 D+ I
make[1]: *** [/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/drivers/net/cpsw.o] Error 1, u( ?1 a+ I1 f
make[1]: Leaving directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net'( O5 @' y/ {2 R
make: *** [/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/drivers/net/libnet.o] Error 2
# Y# g# L O/ n5 ~9 b- o6 E0 d
. i4 G: S* s$ H( U4 F# Y, ?, D请教这个是什么错误,我在网上找了半天,别人都是可以编译过的
$ ^4 T2 K* g: ~; x8 \
1 f- `3 s* S' h! q5 q( a+ m: P" P) s( g2 ?" f
9 M: q! k" U9 z
5 ]) h% ?& d: K; m' u0 f) \- ^3 O
. O" t! y! I/ @% W2 F" ]
! z1 p B0 F4 M& y
2 {3 ?) n7 s( }/ T7 ^' O
' o+ r! W6 K9 E8 [
* _9 s& }. C/ C0 |0 o7 ]9 B, c! i8 D
! a% ?* S5 @3 V3 A1 F- T# \5 I8 U
