查看: 229|回复: 1
如何进行Linux网络编程
发表于 2019-10-9 14:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1、 tcp程序设计
+ H8 p3 w- f/ g( O+ q( c8 L, ^4 m  z
代码1 server:
9 |3 V# H& i! b, B
* r* i: u' e; \2 n' Z- N# q3 u
  • #include <stdlib.h>
  • #include <stdio.h>
  • #include <errno.h>
  • #include <string.h>
  • #include <netdb.h>
  • #include <sys/types.h>
  • #include <netinet/in.h>
  • #include <sys/socket.h>
  • #define portnumber 3333
  • int main(int argc, char *argv[])
  •    int sockfd, new_fd;
  •    struct sockaddr_in server_addr;
  •    struct sockaddr_in client_addr;
  •    int sin_size;
  •    int nbytes;
  •    char buffer[1024];
  •    //AF_INET: IPV4, SOCK_STREAM: TCP
  •    if((sockfd = socket(AF_INET, SOCK_STREAM, 0)) == -1)
  •         fprintf(stderr, "Socket error:%s\n\a", strerror(errno));
  •        exit(1);
  •    bzero(&server_addr, sizeof(struct sockaddr_in));
  •    server_addr.sin_family = AF_INET;
  •    server_addr.sin_addr.s_addr = htonl(INADDR_ANY);
  •    server_addr.sin_port = htons(portnumber);
  •    if(bind(sockfd, (struct sockaddr *) (&server_addr), sizeof(structsockaddr)) == -1)
  •        fprintf(stderr, "Bind error: %s\n\a", strerror(errno));
  •        exit(1);
  •    if(listen(sockfd, 5) == -1)
  •        fprintf(stderr, "Listen error: %s\n\a", strerror(errno));
  •        exit(1);
  •    while(1)
  •        sin_size = sizeof(struct sockaddr_in);
  •        if((new_fd = accept(sockfd, (struct sockaddr *)(&client_addr),&sin_size)) == -1)
  •             fprintf(stderr, "Accept error:%s\n\a", strerror(errno));
  •            exit(1);
  •        fprintf(stderr, "Server get connection from %s\n",(char*)inet_ntoa(client_addr.sin_addr));
  •        if((nbytes = read(new_fd, buffer, 1024)) == -1)
  •            fprintf(stderr, "Read Error: %s\n", strerror(errno));
  •            exit(1);
  •        buffer[nbytes] = '\0';
  •        printf("Server received %s\n", buffer);
  •        close(new_fd);
  •    close(sockfd);
  •    return 0;
  • }7 U( N2 P4 G4 ^( A
/ y& w, k, j; R. z; T5 W5 G
- k' ]( T% x" J" I
! U% _( [, {- K# T/ D2 Z2 _8 k代码2 client:
0 b/ p5 Y0 e7 ~) a6 W
3 x' S$ O9 Q  G
  •    int sockfd;
  •    struct hostent *host;
  •    if(argc != 2)
  •        fprintf(stderr, "Usage: %s hostname \a\n", argv[0]);
  •        exit(1);
  •    if((host = gethostbyname(argv[1])) == NULL)
  •         fprintf(stderr, "Gethostname Error:%s\a\n", strerror(errno));
  •        exit(1);
  •        fprintf(stderr, "Socket Error: %s\a\n", strerror(errno));
  •        exit(1);
  •    bzero(&server_addr, sizeof(server_addr));
  •    server_addr.sin_addr = *((struct in_addr *) host->h_addr);
  •    if(connect(sockfd, (struct sockaddr *)(&server_addr), sizeof(struct sockaddr))== -1)
  •        fprintf(stderr, "Connect Error: %s\a\n", strerror(errno));
  •        exit(1);
  •    printf("Please input char: \n");
  •    fgets(buffer, 1024, stdin);
  •    write(sockfd, buffer, strlen(buffer));
  •    close(sockfd);
  • return 0;
  • }! x' b; H+ x  G, C( M* j
8 @$ Y; y% E3 v) Y2 @; M  s. W" P, V
# F7 r9 r& N- i* f2 A  w
" ?+ E# }& |% H, p% ~; K0 GMakefile:
* E% B$ M  ^! F$ V- S. K
+ a3 N* W, w1 r& c5 x, K' n
  • CC = gcc
  • CURTDIR = $(shell pwd)
  • TARGET = tcp_client
  • #TARGET = tcp_server
  • %.o:%.c
  •        $(CC)-c $(EXTRAFLAGS) $< -o $@
  • %.o:%.S
  • .PHONY: all clean
  • $(TARGET): $(TARGET).o
  •        $(CC)  -o $@ $^
  • clean:
  •        rm-RF $(TARGET) $(TARGET).o
    ! u* z6 u1 z- r/ y) U: z/ ]
- D, n9 s/ m. z- f
! e% n$ o# a7 I( M+ d" x7 R5 S7 V4 v: a; R9 H
运行结果:
游客,如果您要查看本帖隐藏内容请回复
; T! S+ g5 B/ ~: N8 V# X0 j5 p& S2 M5 [3 c: ?
. E( s3 x1 d4 O: }2 ]5 O3 T
( i# \/ h; x: o
! e/ P0 P* P  Y' w
! j# F* C9 X6 Q0 m
发表于 2019-10-9 18:48 | 只看该作者
看看如何进行Linux网络编程。
GMT+8, 2025-8-24 08:34 , Processed in 0.109375 second(s), 23 queries , Gzip On.
