MAX706S+74ALVC164245+CY7C1041B+TMS320BVC5416开发板+原理图+PCB作品文件分享。! E' a0 E; v; b( v, o( R6 R, K: i9 q6 X
/ d8 w% I% c2 T% P4 [- l* n( cTMS320BVC5416开发板,用AD画的两层板,
5 h! s/ R( y0 ~3 w& D板子布局布线都很清晰,
/ @- a# @3 j* h1 K8 ?8 M5 F画的很漂亮,有需要的可以看看。2 t. @: Z1 [+ l6 o
$ J! y: P( a9 L$ u. \5 B/ Z# D% E1 w6 A' f5 d* R
8 a8 q; \. a" N+ `
层数:2层: ?- l( p9 z9 h
用途:开发板
' k4 q! B; k' o5 [pcb作品截图如下:
, c; l' v" Q1 u T- n/ v/ ~+ g% M1 h+ M4 n
! y2 j2 Q* M" \) F9 v9 C. u9 K( V3 J! C7 w
3 M# w$ }) i7 X
附件:
5 k0 n- m9 ?$ s9 C$ {: F' V0 d# E
BOM:
' L0 k1 S6 |6 s1 R Z
9 F: J" H9 C; v1 x3 G, `6 rComment | Designator | Quantity | Footprint | 3V | BT1 | 1 | BATTERY | 104 | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C16, C17, C18, C19, C20, C21, C22, C23, C24, C25, C26, C27, C28, C32, C33, C34, C35 | 31 | 0805 | 102 | C30 | 1 | 0805 | 33u | C31 | 1 | CAK45-C | 47P | C36 | 1 | 0805 | 22P | C37 | 1 | 0805 | 10u | C38, C39, C40, C41 | 4 | CAK45-C | 100u | C42, C43 | 2 | CAK45-C | 4001 | D1, D4 | 2 | DIODE0.3 | LED | D2, D3 | 2 | 0805LED | 4148 | D5, D6, D7, D8 | 4 | DIODE0.3 | 1N4002 | D9 | 1 | DIODE0.3 | AM29LV400B | D10 | 1 | TSOP48 | BRIDGE1 | D11 | 1 | BRIG-01 | POWER | D12 | 1 | 0805LED |
# Z( C: ~3 V% y1 U& k4 l
0 E u9 V5 b8 }' w/ w& x& x0 s | J1 | 1 | SIP-2 | DB25 | J2 | 1 | DB-25/M | HEADER 7X2 | J3 | 1 | IDC-14 | RS232 | J6 | 1 | DB-9/M | CON3 | J7 | 1 | POWR3 | LCM12864ZK | J8 | 1 | SIP-20 | RS422 | J9 | 1 | DB-9/M | AIN | J10 | 1 | SIP-2 | VREF | J11 | 1 | SIP-2 | DI | JP1 | 1 | IDC20 | DO | JP2 | 1 | IDC20 | HEADER 20X2 | JP3 | 1 | IDC-40 | LED PORT | JP4 | 1 | IDC20 | 4*4 KEY | JP5 | 1 | SIP-8 | CZ | L1 | 1 | SIP-2 | 10K*4 | PZ1, PZ2, PZ3, PZ4, PZ5, PZ6, PZ7, PZ8, PZ9, PZ10, PZ11, PZ13 | 12 | RCA | 2K*4 | PZ12 | 1 | RCA | 33 | R1, R2, R3, R4 | 4 | 0805 | 470 | R5, R6, R7 | 3 | 0805 | 10K | R8, R9, R10, R11, R12, R13, R14, R26 | 8 | 0805 | 1M | R15 | 1 | 0805 | 10.7K | R16 | 1 | 0805 | 0 | R17, R27 | 2 | INDUCTOR | 0 | R18, R19 | 2 | 0805 | 30.1K | R20 | 1 | 0805 | 350 | R21, R22 | 2 | 0805 | 650 | R23, R24 | 2 | 0805 | 10K | R25 | 1 | POT-03 | SW DIP-4 | S1 | 1 | DIP8 | SW POWER | S2 | 1 | SW-POWER | RESET | S3 | 1 | RESET4 | TMS320VC5416-PGE | U1 | 1 | F-QFP20X20-G144/N | 7406 | U2, U3, U4 | 3 | SO14 | MAX706S | U5 | 1 | SO8 | 74ALVC164245 | U6, U7, U8 | 3 | SSO48 | CY7C1041B | U9 | 1 | TSOP44-II | 16.000MHz | U10 | 1 | CY_PCB | TLV1578-SOP32 | U11 | 1 | PSOP32 | TL16C750PM-64PIN | U12 | 1 | SQFP10X10-64(N) | EPM3128TQFP144 | U13 | 1 | F-QFP20X20-G144/N | CH452S/A-2 | U14 | 1 | SOP28 | MAX3232 | U15 | 1 | SO16 | MAX3491CSD | U16 | 1 | SO14 | 7805 | U17 | 1 | 78XXNSP | TPS767D301 | U18 | 1 | PSOP28 | | XP1 | 1 | IDC-14 | | XP2 | 1 | IDC-10 | 14.7456MHz | Y1 | 1 | CRYSTAL | - X+ l- K( Q! p0 B: S5 [" K
+ h$ W+ \! d2 m4 ?' [6 g8 U$ V5 k( m$ D2 |/ a$ F1 F
- c, y2 w; T0 p/ b' s+ v4 T
1 q1 l) _, A- C- G. k# j0 D
