RT9701B+DM9118+K9K8G08U0A+CAT811+三星S3C6400核心板+原理图+PCB作品文件分享。4 A* a5 Q* T) q2 m# c
用AD画的6层板,# Q) z- k1 u- w0 R/ \
三星S3C6400核心板,; T* x' E$ T5 K: i
板子布局布线很清晰,画的很漂亮。局部较密,有一定难度,有需要的可以看看。
0 \$ [8 Y1 A7 X; j" e6 @- n5 ~0 w2 A& g3 M* E6 o7 o
层数:6层1 q @! p' W1 Q, t
用途:核心板# m9 r$ [' C9 d) O+ o
pcb作品截图:0 ?, {$ r0 ^$ g" s3 t
/ {5 t9 d) c1 N7 n5 @: { J
' g- k0 Q: c( n" I; D! J
. l* Z# @ L: @附件:
8 t5 \5 D% j' |6 V/ T4 u- {5 g' w4 q3 D$ Y# n" H
BOM:% e4 e0 B# k* Y" ?5 b
) q4 I% z- W1 pComment | Designator | Quantity | Footprint | 0.1uF | C1, C3, C4, C5, C6, C15, C17, C21, C22, C26, C27, C28, C29, C30, C31, C32, C33, C35, C36, C38, C39, C42, C43, C46, C47, C50, C52, C53, C73, C77, C82, C88, C89, C91, C92, C94, C95, C96, C97, C98, C100, C101, C107, C110 | 44 | 0603C | 15pF | C8, C9 | 2 | 0603C | 22pF | C10, C11, C12, C13, C44, C45 | 6 | 0603C | 1.8nF | C14 | 1 | 0603C | 10uF/10V | C18, C20, C55, C56, C57, C58, C60, C61, C62, C63, C64, C65, C133, C136, C137, C140 | 16 | CASEA | 10uF/10V | C24 | 1 | CASEB | 10uF/16V | C25 | 1 | CASEA | 10uF/10V | C59 | 1 | 0603C | 25M | CRY1 | 1 | X3X5 | 32.768KHz | CRY2 | 1 | CRYSTAL-3276 | 27M | CRY3 | 1 | X3X5 | 12M | CRY4 | 1 | X3X5 | 48MHz | CRY5 | 1 | X3X5 | LED | D1, D2 | 2 | 0805LED | CON5 | J1, J2, J3, J4, J5, J6, J7, J8, J9, J10, J11, J12, J13, J14, J15, J16, J17, J18, J19, J20, J21, J22, J23, J24, J25, J26, J27, J28, J29, J30, J31, J32 | 32 | SMD_5 | BEAD | L6 | 1 | 0603 | F.B/120 | L8, L9 | 2 | 0603 | CON1 | MARK1, MARK2, MARK3, MARK4, MARK5, MARK6, MARK7, MARK8, MARK9, MARK10, MARK11 | 11 | TP3 | OPEN | R1, R2, R3, R4, R35, R47 | 6 | 0603 | 100K | R5, R6, R7, R48, R49, R112, R113 | 7 | 0603 | 10K | R8, R9, R10, R11, R16 | 5 | 0603 | 0R | R12, R13 | 2 | 0603 | 3.4K 1% | R14 | 1 | 0603 | 1K | R15, R17, R62, R63 | 4 | 0603 | 1M | R18, R19 | 2 | 0603 | 4.7K | R23 | 1 | 0603 | RES | R54, R55 | 2 | 0603 | 6.8K/1% | R57 | 1 | 0603 | 6.24K 1% | R64 | 1 | 0603 | TESTPOINT | TP1, TP2, TP3 | 3 | TP2 | S3C6400 | U1 | 1 | 424-FBGA-13.0X13.0 | K4X51163PC-LGC3 | U2, U3 | 2 | K4X51163PC | RT9701B | U4, U5 | 2 | SOT23-5 | K9K8G08U0A-PCB0/PIB0 | U10 | 1 | TSOP48 | DM9118_6 | U22 | 1 | LQFP48 | CAT811 | U30 | 1 | SOT-143 |
& D1 }2 B; Q# X0 E4 n5 T$ T2 `
$ J2 h3 M- w. x+ c% o4 Z* ~ |
