查看: 255|回复: 1
Linux环境安装tomcat
发表于 2019-10-8 10:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
官网下载,Tomcat压缩包。
1 C0 ]) X! r1 R7 ^' S- a" X, ]
# tar -zxvf/share/ecs/apache-tomcat-8.5.5.tar.gz -C  /opt/
( @3 r9 k* t, T- D  ^9 Q! u/ K# y% t& E) ^( _  e6 x
start stop restart' d/ H0 o. R# }& g* m) F* l6 J
& x7 Y2 U' N3 L
# /opt/apache-tomcat-8.5.5/bin/startup.sh& m3 Z& s: f1 V
8 |) Z! I7 J" F* S, a8 ]; XUsing CATALINA_BASE:   /opt/apache-tomcat-8.5.5
) ~$ f, U  V- O7 l9 }, O  w, @
; q2 I; ]7 x$ k- A6 @$ N: qUsing CATALINA_HOME:   /opt/apache-tomcat-8.5.5
5 |  T# g$ J8 E3 h0 L" z7 F
" Q# J3 W+ c. N+ d0 U6 ~# V% sUsing CATALINA_TMPDIR:/opt/apache-tomcat-8.5.5/temp
' ?" m1 |! m8 I$ T. x6 B
% v+ f0 f" V- e$ d! }- J/ ]5 b# ]Using JRE_HOME:        /opt/jdk1.8.0_101% A3 ~& {# x( D% o8 x1 G
$ z4 t- J3 d' Y4 C
Using CLASSPATH:      /opt/apache-tomcat-8.5.5/bin/bootstrap.jar:/opt/apache-tomcat-8.5.5/bin/tomcat-juli.jar  U0 z# ~2 X% u; N, ^3 \
( V- Y- k& V2 {4 L" @5 ]; D
Tomcat started.+ M* n$ ]  N1 G9 i2 H& i
4 S7 E3 i1 x3 a# `0 e7 |
#tail -f   logs/catalina.out" b" R& G8 P) g' M8 ^- j& |# m+ g
: \6 L7 e# {+ u* A8 x
# wget http://localhost:8080
/ U( X+ y/ h  _0 ?. t+ x! C6 k$ G; d2 A' Y' x; H
--2016-09-24 22:13:08--  http://localhost:8080/! @' a5 K7 [4 {3 [
, @% [. I" Z7 P/ Y% A
正在解析主机 localhost (localhost)... 127.0.0.1( X! x* m7 A+ R
6 _5 p3 c$ q0 ^6 n1 {1 p( x6 }正在连接 localhost (localhost)|127.0.0.1|:8080... 已连接。2 X* b9 W" _) K7 W, C0 |( w  ^
: A7 N% w7 ?% s- A& T
已发出 HTTP 请求,正在等待回应...200
! b2 L# y' O! X5 v- ^4 F/ l( F. I' t& Z0 a8 g8 u3 o
长度: 未指定 [text/html]
1 ]: S: G- \: z4 d/ @5 M# F$ m2 t  Q7 l- B* m" |0 u9 |
正在保存至: “index.html.1”, Q) o, E9 {9 d$ V/ ~8 z* v' M
& `4 O  `. O" B0 C- L, E% x   [ <=>  ] 11,228      --.-K/s  用时 0s
: s' _* G( H. L; L5 D( u& ~. k: F  C' i
2016-09-24 22:13:08 (73.1 MB/s) -“index.html.1” 已保存 [11228]' L8 @( k6 T5 A& T3 B8 n3 c
* i# @+ h) [1 @0 [) W8 J
! N, M+ [: X  V( O2 x: @% _1 P#vi  /etc/rc.d/rc.local. a$ a4 E2 G5 z" z# {' a9 P
& T* L, V" C  ^& ^+ R5 o2 W
" c9 f: I8 f5 \# G
, e- p0 r6 ], Q+ U) U3 @& p
( p5 l, J6 V6 M9 u( H5 D% e1.能过apt-get方式安装Tomcat
# f) I+ G0 `, _3 ^. t3 q/ t% `
* F: j# f7 h' k- P3 o* P' ]#sudo  apt-get  install tomcat69 S$ Z0 s1 q: x9 H% A. O0 J
- A" e5 p7 I* ~% C  a- t$ |
2.进入安装上当下的\bin目录。0 y5 \  @4 n  r! J
, t1 ]- i( g' y( `: O执行./startup.sh   或   Tomcat6  start- j' f9 {1 V; }# t
9 ]- x5 m6 m$ Q4 p$ u) k
本地访问:localhost:8080
. o4 D. ~; C+ J! {' N# Y" I- h
3 \' m4 N% u7 S# x8 r7 d- t3.启动Tomcat服务
, J  ^0 e4 Z9 q" N& \; @
9 u, c2 u" v- w- L2 A#sudo  /etc/init.d/tomcat6 start' q; G: s% H% M! r0 z) }1 X3 y
# k; k$ Z" n8 y% |9 @: f
4.停止Tomcat服务
. c. f) J0 l8 B$ J
- w4 ?: W/ ?% L$ T#sudo  /etc/init.d/tomcat6  stop
0 H# Z' Y! F5 _
% p0 L5 T, A' }  s, k
+ p; ?1 Y( e% Z& ?
8 z* D( N* ?8 D
0 N# ]( _  J. b
" i! G# e1 L7 w7 [& V4 x
5 g  u+ ?. v, |1 W: O: @! q
) U, f5 `( y6 o7 ~; Z3 j6 w  t# @) L
发表于 2019-10-8 17:34 | 只看该作者
看看啥东东。
GMT+8, 2025-8-24 08:38 , Processed in 0.125000 second(s), 23 queries , Gzip On.
