?1 X1 I/ R3 p/ T+ n9 a
6 I& N1 p7 O9 P8 V$ m* C
CP8310+IT809+AT24C256A+AZ6208BM+TRI1461+XC6206P18+监控摄像头原理图+PCB作品文件分享。3 a5 R) S; E# e5 [5 s
% l# C8 c# x8 ]8 {/ p% d
用AD画的两层板,监控摄像头, s- a& b. U7 ~5 w8 r& ]) U) v
板子很简单,适合入门,
0 T. Q3 v L. |# C6 L5 E, c有需要的可以看看。
- W: c2 x, n4 D, G
6 f A7 y4 s1 h层数:2层( ~8 o( z, r6 e1 }) t) {' |
用途:监控摄像头0 I- i% F7 b# \6 L, Y- }8 I" c7 G2 Z
pcb作品截图如下:- A$ z7 Y3 U7 n) g( A _
+ }' D, `% m+ t$ N+ r
1 W0 I; S" X: w8 H
3 Z9 l7 H% r- L+ e5 i4 ~4 u; e# T" \# d0 h/ u
附件:( f( k, P- \9 }7 C0 {5 v1 |! e6 A
BOM:
- N, B' x4 a2 Z# ?) Q; A; v* ZComment | Designator | Quantity | Footprint | 0.1uF | C1, C2, C3, C4, C5, C6, C7, C8, C9, C12, C13, C14, C15, C16, C24 | 15 | 0603-2 | 30pF | C10, C11 | 2 | 0603-2 | 22nF | C17 | 1 | 0603-2 | 100uF/16V | C18 | 1 | CAP6.6 | 10uF/25V | C19, C20 | 2 | ZCP | 47uF/6.3V | C21, C22 | 2 | ta-a | 0.01uF | C23 | 1 | 0603-2 | 22uF | C25 | 1 | W0805 | PS0080 | D1 | 1 | DO-214AC | SCS551V | D2, D4 | 2 | WSCS551V | SW-PS151M-LF | D3 | 1 | SMD-1206 | MS1681 | IC1 | 1 | IC_SOT-23-6 | 1.5X3P SMD | J1 | 1 | 1.5 x 3pin smd | 1.2 x 2pin smd | J2, J3 | 2 | CON_SDM\1.25\2PIN(53047-02) | 10uH (3225) | L1, L2 | 2 | 3225 | PL3018F 47UH | L3 | 1 | C3-P1.5R | MTV 12mm | M1 | 1 | Y.P_LENS | 1.25X8PIN | P1 | 1 | 1.2x8p | 2SC1623 | Q1 | 1 | 2sc1623 | 10K | R1 | 1 | 0603-1 | 1.5K | R2, R3, R4, R5 | 4 | 0603-1 | 75R | R6, R7, R11 | 3 | 0603-1 | 1M | R8 | 1 | 0603-1 | 47K | R9, R10, R13, R23 | 4 | 0603-1 | 15K | R12 | 1 | 0603-1 | 10R | R14 | 1 | z0805 | 0R | R15, R16, R17, R18 | 4 | 0603-1 | 10R | R19 | 1 | 0603-1 | 3.9K(1%) | R20 | 1 | 0603-1 | 100K | R21 | 1 | 0603-1 | 12K(1%) | R22 | 1 | 0603-1 | IT809 | U1 | 1 | 809 | AT24C256A | U2 | 1 | WSOP8 | CP8310 | U3 | 1 | 60CLCC | AZ6208BM | U4 | 1 | SO8(P1.27-W7.0) | TRI1461 | U5 | 1 | IC_SOT-23-6 | XC6206P18 | U6 | 1 | XC6206P | 27MHz | XT1 | 1 | XTAL-3*8 | DSX321G/27MHz | XT2 | 1 | SMD3.2*2.5 | " w& N6 q# H w4 |, {5 _
1 s$ g S& f+ S
0 L2 \- A5 n, o1 o8 ^; P- [
. V1 j7 C# \/ f/ f
