% i4 Z% Z% j4 {
+ }5 E) P) r8 o/ ~5 E1 ?3 O/ v4 a+ ]3 p. _# K. q3 p
1. 电磁兼容性 electromagnetic compatibility (EMC)2. 电磁骚扰 electromagnetic disturbance 3. 电磁干扰 electromagnetic inte RFerence 4. 电磁环境 electromagnetic environment 5. 电磁发射 electromagnetic emission 6. 电磁敏感性 electromagnetic susceptibility 7. 电磁屏蔽 electromagnetic screen 8. 抗扰度限值 immunity limit 9. 抗扰度电平(水平) immunity level 10. 静电放电ESD electrostatic discharge 11. 瞬态 transient 12. 猝发(脉冲群) burst 13. 喀呖声 click 14. 基波(分量) fundamental (component) 15. 谐波(分量) h ARMonic (component) 16. 人工电源网络 artificial mains network 17. 模拟手 artificial hand 18. 准峰值检波器 quasi-peak detector 19. 峰值检波器 peak detector 20. 平均值检波器 average detector 21. (辐射)测试场地 (radiation)test site 22. 电流探头 current probe 23. 工科医频段 ISM frequency band 24. (发射或信号的)带宽 band width(of an emisson or signal) 25. 选择性 selectivity 26. 电压波动 voltage fluctuation 28. 电压瞬时跌落 voltage dip (电压暂降) 29. 电压浪涌 voltage surge 30. 闪烁 flicker 31. 闪烁计 flickermeter 32.(抗扰度)符合电平 (immunity)compliance level 33.(性能的)降低 degradation(of performance) 34.有效辐射功率 effective radiation power 35.基本性能 essential performance 36.生理模拟频率 physiological simulation frequency 37.公共电网 public mains network 38.无线电频率RF radio frequency 39.信息技术设备ITE information technology equipment 40. 受试设备(EUT) equipment under test (EUT) 41. 接地参考平面GRP ground reference plane(GRP) 42. 耦合板 coupling plane 43. 调幅 amplitude modulation 44. 电波暗室 anechoic chamber 45. 全电波暗室 fully anechoic chamber 46. 半电波暗室 semi-anechoic chamber 47. 场强 field strength 48. 感应场 inducted field 49. 极化 polarization 50. 屏蔽室 shielded enclosure 51. 扫描 sweep 52. 收发机 transceiver 53. 去耦网络 decoupling network 54. 耦合网络 coupling network 55. 瞬态 transient 56. 辅助设备(AE) auxiliary equipment 57. 钳注入 clamp injection 58. 电流钳 current clamp 59. 吸收钳 absorbing clamp 60. 电磁钳 electromagnetic clamp 61. 感应线圈 induction coil " @1 e, ^9 k' j$ p3 n
