cd qtbase- /opt/qt-everywhere-opensource-src-5.4.1/qtbase/configure -top-level -v -prefix /opt/qt-everywhere-opensource-src-5.4.1/_install -opensource -confirm-license -release -make libs -xplatform linux-ARM-gnueabi-g++ -optimized-qmake -pch -qt-sql-sqlite -qt-libjpeg -qt-zlib -no-opengl -no-sse2 -no-openssl -no-nis -no-cups -no-glib -no-xcursor -no-xfixes -no-xrandr -no-xrender -no-separate-debug-info -nomake examples -nomake tools -nomake tests+ F3 i0 a6 e# |! q! j
This is the Qt Open Source Edition. You are licensed to use this software under the terms of
' w g+ T3 O/ N7 U4 Lthe Lesser GNU General Public License (LGPL) versions 2.1.
4 C; R& E( W, S+ |You are also licensed to use this software under the terms of7 U, Z9 v \0 o5 v' ~3 V
the GNU Lesser General Public License (LGPL) versions 3. You have already accepted the terms of the Open Source license. arm-none-linux-gnueabi-g++ -c -fvisibility=hidden fvisibility.c
" _# ~" X7 V! SSymbol visibility control enabled.
) v0 ~' H" l: }" o% ^, v2 Z2 a' uarm-none-linux-gnueabi-g++ -o libtest.so -shared -Wl,-Bsymbolic-functions -fPIC bsymbolic_functions.c" |. i& r! ]+ n
bsymbolic_functions.c:2:2: error: #error "Symbolic function binding on this architecture may be broken, disabling it (see QTBUG-36129)."
P3 u; Z6 B& W4 Y6 p" eSymbolic function binding disabled.
' a' p! B- ^3 c; o/ J: s+ ~DEFAULT_INCDIRS="/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/include/c++/4.5.2
! d& ?2 p; [' m( h# q/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/include/c++/4.5.2/arm-none-linux-gnueabi- x9 W5 l8 N% l$ _! f. r- J' Q
/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/include/c++/4.5.2/backward1 K& F9 }7 ~# G( Y6 F# l" v
/usr/local/arm/arm-2011.03/lib/gcc/arm-none-linux-gnueabi/4.5.2/include
8 R6 U9 B1 T9 M, h$ ?; O5 C6 e% u/usr/local/arm/arm-2011.03/lib/gcc/arm-none-linux-gnueabi/4.5.2/include-fixed6 X" G3 d Q! s+ j
/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/include5 T# L. X; h) A9 u7 k
/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/libc/usr/include
( a. Q2 b3 n7 W$ I"2 P7 I7 d/ F: `, J
DEFAULT_LIBDIRS="/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/libc/lib" M. \- U4 r/ a+ X" j& v, {* d
/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/libc/usr/lib
5 p. U; y4 Q4 m& L3 [/usr/local/arm/arm-2011.03/lib/gcc/arm-none-linux-gnueabi/4.5.2
. ?: J) i. k, W. ^- J M& ]/ c+ _/usr/local/arm/arm-2011.03/lib/gcc
2 G- z9 X" Y( s/usr/local/arm/arm-2011.03/arm-none-linux-gnueabi/lib
( V D0 [% J0 N"& | H) J( f! P
Creating qmake...
0 p n: H( k$ G k% N( A0 fgmake: Nothing to be done for `first'.
6 T( m& t) \) gRunning configuration tests...
- ?) r9 a/ B& _9 ]: o5 lFailed to process makespec for platform 'linux-arm-gnueabi-g++'$ M- i& d5 s2 l9 w4 z6 }6 x# N
/opt/qt-everywhere-opensource-src-5.4.1/qtbase/configure: line 3869: /opt/qt-everywhere-opensource-src-5.4.1/qtbase/bin/qmake: cannot execute binary file 6 Q8 c# z. E+ b4 K0 E* V% _+ s
