查看: 643|回复: 1
APW708+KSZ9021RNI+SCY99090SNT1G+SP2526A+A8内核M3352开发板原理图+PCB作品文件分...
发表于 2019-9-29 13:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
) s& D" f! h; A9 O. m, Z
. B# D2 m  N  ?/ _9 f" s" p& wAPW708+KSZ9021RNI+SCY99090SNT1G+SP2526A+A8内核M3352开发板原理图+PCB作品文件分享。
) A0 T3 N! Q; }" w1 |- {用AD画的两层板,
5 O. _- w! W% o& {1 `. }A8内核M3352开发板,
- g% j# S5 v: b1 b, E板子画的很漂亮,局部较密,有一定难度,
1 S! O5 D' R0 ^/ }! }/ N2 K" Q3 t* o有需要的可以看看。
" M" ]8 _. U5 Z1 ^. W2 {
. F: t  B$ |& Z! C, y层数:2层* B4 ^" v2 E4 r9 F: f* Z" O* w
用途:开发板
) f* m/ ~4 Z8 o& l
pcb作品截图如下:" j) K" }# L8 j* l( L4 |
# S1 t: K5 L) i6 j ! E. }  x, O/ C, j& }" o& k
! E: ?& r9 v' s; \* j - H  D' E5 Y4 _: R
附件:7 y) U( C- `5 L# ?' r
游客,如果您要查看本帖隐藏内容请回复
8 ]% N7 y2 |4 M. R2 kBOM:
! P, `* @2 W5 ^' v' ?  c2 e1 _
Comment
Designator
Quantity
Footprint
BUZZER2
B1
BUZZ-.28/.46
BATTERY
BT1
BAT-3V
106,10μF
C1, C4, C31, C34, C36, C50, C53, C58, C61, C72, C75, C81, C88, C138, C141
15
0805C
104,±10%
C2, C3, C5, C6, C7, C13, C14, C17, C18, C24, C25, C28, C29, C30, C35, C38, C39, C40, C41, C42, C46, C49, C52, C59, C60, C63, C64, C65, C66, C73, C76, C80, C84, C85, C86, C87, C89, C90, C91, C92, C93, C94, C100, C101, C102, C105, C111, C112, C113, C122, C132, C133, C135, C137, C139, C142, C144, C145, C146, C147, C148, C149, C150, C151, C152, C153, C154
67
0603C
105,1μF
C8, C11, C15, C19, C22, C26, C67, C69, C71
9
0603C
68P,±5%
C9, C20
0603C
22P,±5%
C10, C21, C70, C74
0603C
220μF,50V
C12, C16, C23, C27
RB-.2/.4
226,22μF
C32, C37, C45, C48, C95, C103, C134, C136
8
0805C
18P,±5%
C33
0603C
102,±10%
C43, C51, C54, C62, C77, C106, C107, C108, C109, C110, C140, C143
12
1206C
102,±10%,2KV,X7R
C44, C47, C127, C131
1206C
475,±10%,16V,X7R
C55
0805C
104,±10%,50V,X7R
C56, C57, C114, C115, C116, C117, C119, C121, C125, C130
10
0603C
47P,±5%
C68
0603C
15P,±5%
C78, C96, C97, C98, C99
0603C
3P,±0.25PF
C79, C82, C83
0603C
105,1μF,±10%,16V,X7R
C118, C120
0603C
18P,±5%,50V,COG
C123, C124
0603C
106,10μF,±10%,10V,X5R
C126, C129
0805C
+ y/ i6 m% }) E
CB1, CB2, CB4, CB5, JP7, JP8, JP9
JUMP-2
HEADER 25X2
CON1
IDE-50-C-2.0
MiniARM M3350
CON2
EPCARM THT-4.5X6.0C3-P160-1.27
NET-HR911105C
CON3
HR911102A
POWER
CON4
POWER-AC
CON3
CON5, CON6, CON7, CON13
CON-3-5.0
USB double
CON8, CON18
USB-A-D2
USB_MINIB_SMT
CON9
USB_MINIB_SMT
PHONEJACK-5
CON10, CON11
EAR-5N-3.5
SD card  AXA2R73061-M
CON12
SD-CARD-Panasonic
DB9
CON14, CON16
DB-9RA/M
HY911130AE
CON15
HR911130AE
DB9
CON17
DB-9RA/F
DIODE1
D1, D2
SOD-323
BRIDGE1
D3
BRIDGE-D
DIODE SCHOTTKY
D4, D5
SOD-SK34A
PESD5V0L5UV
D6, D22, D23, D26
SOT-666
ESD-1
D7, D9, D19, D21
SOD-323
PESD24VL2BT
D8, D10, D18, D20
SOT-23
NUP4202W1
D11, D12, D15
SOT-363
1N4148
D13
SOD-1005A
DIODE-D
D14
SOT-23
ESD-3
D16, D17, D25, D27
SOT-23
PESD5V0L5UV
D24
SOT-23
JK60-090,Ф10×2mm
F1
AX-5P-12D
SMD0603P050TF
F2, F3, F4, F5
0603R
HOLE
HOLE1, HOLE2, HOLE3, HOLE4, HOLE5
HOLE-3.2
120Ω_EN
JP1, JP2, JP3, JP5
SIP-2
HEADER 7X2
JP4
IDC-14
CON3
JP6, JP23
SIP-3
HEADER 4X2
JP11, JP21
IDC-8
HEADER 2X2
JP12, JP20, JP24
IDC-4
CON2
JP13, JP15, JP16, JP17, JP18, JP22
SIP-2
HEADER 6X2
JP14, JP19
IDC-12
CON3
JP25
CN-3-2.54
INDUCTOR1
L1
L-4.0S-VLS
INDUCTOR1
L2, L3, L4, L5, L6, L7
0603R
INDUCTOR1
L8, L9
L-12X12S
LED1
LED1, LED2, LED3
LED-0805
MARKER
MARK2, MARK3, MARK5, MARK6, MARK8, MARK9
MARKER-C
PNP-1
Q1
SOT-23
10KΩ
R1, R2, R3, R19, R20, R21, R22, R23, R29, R32, R36, R51, R55, R63, R70, R71, R86, R87, R88
19
0603R
100KΩ
R4, R9, R15, R58, R112, R113, R114
0603R
1KΩ
R5, R25, R33, R59, R60, R75, R131, R132
8
0603R
15KΩ
R6, R10, R14, R80, R81, R108, R109, R118, R119, R123, R124
11
0603R
51KΩ,±0.5%
R7, R37, R38
0603R
12KΩ,±1%
R8, R61, R125
0603R
47KΩ,±1%
R11
0603R
15KΩ,±1%
R12
0603R
R13
1206R
4.7KΩ
R16, R17, R18, R74, R82, R83, R98, R99, R100, R135, R136
11
0603R
22Ω
R24, R27, R28, R35, R62, R64, R65, R77, R78, R84, R104, R105, R106, R107, R111, R116, R117, R121, R122
19
0603R
R26, R69, R90, R101, R102, R103, R126, R127
8
0603R
10KΩ/NC
R30, R31
0603R
12.1KΩ,±1%
R34
0603R
300Ω
R39, R40, R89, R92
0603R
49.9Ω,±1%
R41, R42, R43, R44
0603R
1MΩ
R45, R47, R49, R53, R57, R66, R76, R93, R94, R95, R96, R97, R110, R120
14
1206R
120Ω
R46, R48
0603R
120Ω,±1%
R50, R54
1206R
10Ω
R52, R56
0805R
5.1Ω
R67, R68
0603R
20KΩ,±1%
R72, R73
0603R
1KΩ/NC
R79, R85, R91, R128, R129, R130, R133
0603R
1MΩ
R115
0603R
0Ω/NC
R134
0603R
22Ω×4,SMD
RP1, RP4, RP5, RP6, RP7, RP8, RP10, RP11, RP12, RP13
10
0603RA
10KΩ×4,SMD
RP2, RP3, RP9
0603RA
SW-PB4P
RST1, RST2
KEY-6S
10KΩ,3296W
RV1
VR-5
VIN
TP1
PAD-25/40
GND
TP2
PAD-25/40
5.0V
TP3
PAD-25/40
3.3V
TP4
PAD-25/40
CLK
TP5
PAD-25/40
1.2V
TP7
PAD-25/40
CLKO
TP8
PAD-25/40
APW7080
U1, U2
SOIC127P600X175-9N
KSZ9021RNI
U3
QFN50P700X700X100-49N
SCY99090SNT1G
U4
SOT-23-5
SP2526A
U5, U8
SOIC127P600X175-8N
RSM3485ECT/ECHT
U6, U7
RSM485CT/CHT
TLV320AIC23
U9
SOP65P640X110-28N
CTM8251T
U10, U11
CTM Series
SP3232E
U12, U13
SOP65P640X120-16N
SN74LVCC3245
U14, U16, U17, U18
SOP65P775X200-24N
PCF8563
U15
SOIC127P600X175-8N
USB2514BI-AEZG
U23
QFN50P600X600X90-37N
XTAL4-B
X1
XTAL4-3.2X2.5
XTAL2
X2, X4
XTAL2-TH
XTAL2
X3
XTAL2-C
% B" X& B& x4 W3 D% R
7 G) r+ U" v5 Q  Y% g
GMT+8, 2025-7-19 16:16 , Processed in 0.156250 second(s), 27 queries , Gzip On.
