MP1484EN+SP3232EEN+MAX3485+AT24C02A+S5PV210开发板底板+原理图+PCB作品文件分享。7 W: G0 v1 }: {( k/ [ Z# r; M
6 y: ?: D( d/ h; R: C: K$ ]
用AD画的两层板,S5PV210开发板底板,
; z9 Y, o3 a5 O9 X% d板子层数较少,只有两层,
6 J$ s* Q4 T# V有一定难度,有需要的可以看看。4 W6 Z) q3 R' H# m1 s9 X S3 U
层数:2层
0 q# k# U# _3 x用途:开发板
/ _$ s; `5 {1 Z: ipcb作品截图如下:
; Y6 z$ q3 x+ D6 X1 ` `) o% D. g
+ p3 ]+ `( e5 @+ S& {: n# W R5 H0 C4 F
, D! D; h- ?/ h- a
3 U, s0 K6 y( p: B" r" i附件:- v1 R. W) s! I% @9 M
% D! i. `- X5 V2 l. k
BOM:4 @$ Q$ [5 u$ T9 D$ ?/ `
: f4 U4 W5 P& Z/ b: N0 z
Comment | Designator | Quantity | Footprint | MG3732 | 3G | 1 | MC8630 | CON8 | ADC | 1 | DIP8_2.0 | MODEL_ANTENA | ANT1 | 1 | ANT2 | CON3 | BAT | 1 | IDC3_2.54 | BATTERY | BAT1 | 1 | BAT600 | BUZZER | BUZZER | 1 | BUZZER | 104 | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C21, C22, C23, C102, C103, C104, C105, C202, C204, C205, C212, C401, C402, C403, C404, C405, C411, C412, C413, C414, C415, C421, C423, C501, C506, C511, C512, C513, C518, C520, C521, C602, C604, C609, CB3, CB6, CD1, CD2, CG1, CG2, CG8, CG9, CG15, CM1, CM2, CMB1, CMB2, CP3, CP6, CT6, CT32, CT34, CT35, CT43, CT63, CT72, CT76, CU2, CU3, CU4, CW2 | 71 | C_0603 | 220uF/16V | C20, C605 | 2 | 47U1 | 220uF/50V | C107 | 1 | 1000UF | 10uF/25V | C108, C601, CB2 | 3 | 1206 | 22uF/6.3V | C201, C203, C517, C519, CT42, CW5 | 6 | 3216A | 22p | C207, C208 | 2 | C_0603 | 100uF/6.3V | C210, CT33, CT36 | 3 | C_1210 | 22pF | C211, CS1, CS2, CU10, CU11, CW4 | 6 | C_0603 | 10uF/16V | C422, C606, C607, C608, CG5, CT31 | 6 | 3216A | 1uF | C503, C504, C505, C524, C526, C527, C528, C529, CP2, CP4, CT71, CT77 | 12 | C_0603 | 4.7uF | C509, C510 | 2 | C_0603 | 100uF/10V | C515, C516 | 2 | C_1210 | 220pF | C525 | 1 | C_0603 | 6.8nF | C603, CG4 | 2 | C_0603 | CAM_2.0 | CAMERA, CAMERB | 2 | IDC20S_2.0 | 0.1uF | CB1 | 1 | C_0603 | 0.47uF | CB4 | 1 | C_0603 | 22uF | CB5 | 1 | 1206 | 47uF/10V | CG0, CG7, CT61, CT62 | 4 | C_1210 | 10nF | CG3 | 1 | C_0603 | 33pF | CG10, CG11, CG12, CG13, CL5 | 5 | C_0603 | 104NC) | CG14 | 1 | C_0603 | 1nF | CL1, CL2, CL3, CL4, CT74, CT75 | 6 | C_0603 | SD/MMC CARD | CON8 | 1 | SD-5011 | 104(NC) | CP1, CT73 | 2 | C_0603 | 10uF | CU1, CU5, CU6, CU7 | 4 | 0805C | 1nF(NC) | CW1 | 1 | C_0603 | 1N4148 | D3, D4, DP1, V7 | 4 | D1206 | 1N5822 | D7, DB1 | 2 | RB160L-40 | BAT54S | D8, D9, D10, D11, D12, D13 | 6 | SOT23 | SMBJ20A | D101 | 1 | SMBJ_SMD | SMBJ6.8A | D421 | 1 | SMBJ_SMD | SS34B | DB2 | 1 | SM5824 | FIX | FIX1, FIX2, FIX3, FIX4 | 4 | FIX | 2.6A | FUSE | 1 | FUSE | 2A | FUSE2, FUSE4 | 2 | 1206 | CON280 | J1 | 1 | CON280_SMD_BOT | SIMMS-00630-TP10 | J2 | 1 | SIM_CT | COM1 | J3 | 1 | DIP5_2.0 | HEADER 20X2 | J4 | 1 | IDC40P_2.00 | CON6_DIP | J5 | 1 | CON6_2.0 | USB_WIFI(NC) | J6 | 1 | USB_WIFI | IPXNC) | J7 | 1 | | COM2 | J8 | 1 | DIP5_2.0 | 485 | J9 | 1 | DIP2_2.0 | USB-A | J10, J11 | 2 | DIP4_2.0 | KEYOUT | J12 | 1 | DIP6_2.0 | POWER | J13 | 1 | POWER2-5.08 | SWITCH | J14 | 1 | POWER2-5.08 | NET | J15 | 1 | DIP7_2.0 | MIC | J16 | 1 | DIP3_2.0 | LINE | J17 | 1 | DIP3_2.0 | HEADER 5X2 | JTAG | 1 | IDC10S | UP | KEY1 | 1 | SW-PB2 | DOWN | KEY2 | 1 | SW-PB2 | | KEY3 | 1 | SW-PB2 | ESC | KEY6 | 1 | SW-PB2 | POW | KEY8 | 1 | SW-PB2 | 0R | L201 | 1 | 1206 | F.B/120 | L421, L501, L503, L504, L505, LG2, LG3, LG4 | 8 | R_0603 | F.B/120(NC) | L422 | 1 | R_0603 | 0R | L502, L507, RG8, RP7 | 4 | R_0603 | 0R(NC) | L506 | 1 | R_0603 | 10uH | L601, LB1 | 2 | IN | LCD40P | LCD40P | 1 | FPC0.5-SMT-40P |
7 r+ c# y# C0 t0 [. ?' d | LED1, LED2 | 2 | LED_0805 | GREEN | LED, LED3, LP1 | 3 | LED_0805 | 10uH | LG1 | 1 | INDUCTANCE_1A | MIC | MIC2 | 1 | MIC | AO4459(NC) | N4 | 1 | SO-8 | AO4459 | N6 | 1 | SOP8 | RED | POWER | 1 | LED_0805 | 3K | PR | 1 | RP2 | S8050 | Q1, Q2, Q15, QB2 | 4 | S9013SMD | S8050(NC) | Q03, Q5, QG1 | 3 | S9013SMD | 8050 | Q10 | 1 | S9013SMD | SI9933ADY | QB1 | 1 | SOP8 | AP2305GN(NC) | QW1 | 1 | SOT23-3 | 10K | R1, R2, R5, R6, R8, R17, R18, R61, R62, R63, R64, R71, R603, RA5, RB7, RD1, RD2, RD3, RD4, RD5, RD6, RD7, RG6, RG7, RM6, RM21, RMB6, RMB21, RO1, RO2, RO3, RO4, RO5, RO6, RQ5, RQ6, RQ7, RS1, RS2, RS3, RS4, RS5, RS6, RS7, RS8, RT3, RT71, RW1, RW2, RW3, RW4, RW5, RW6, RW7, RW8 | 55 | R_0603 | 1K | R9, R10, R65, R122, R331, R422, RB2, RG9, RP5, RP6 | 10 | R_0603 | 0 | R31, R203, R505, RA4, RM5, RM22, RM24, RM25, RMB1, RMB3, RMB5, RMB22, RN4, RT64, RW21 | 15 | R_0603 | 0(NC) | R32, R201, R427, RM1, RM3, RT1, RT2 | 7 | R_0603 | 22R | R101, R102, R103, R104, R105, R106, R107 | 7 | 8P4R_0603 | 22R | R108, R109, R428, R429 | 4 | R_0603 | 100K | R123, R601, RB4, RG1, RU18, RU19, RU21 | 7 | R_0603 | 6.8K(1%) | R204 | 1 | R_0603 | 4.7K(NC) | R205, RMB19, RMB20, RW19, RW20 | 5 | R_0603 | 51 | R206, R207, R208, R209 | 4 | R_0603 | 5.1K | R421, RF2 | 2 | R_0603 | 2K | R424, R425, RB1 | 3 | R_0603 | 120 | R426 | 1 | R_0603 | 2.2K | R504, RB6 | 2 | R_0603 | 47K(NC) | R506 | 1 | R_0603 | 8.2K | R507, R508, R509, R510 | 4 | R_0603 | 44.2K | R602 | 1 | R_0603 | 6.8K | R604, RG2 | 2 | R_0603 | 100 | RA1, RF1 | 2 | R_0603 | 100mohm | RB5 | 1 | 1210 | 33.2K1%) | RG3 | 1 | R_0603 | 10K(1%) | RG4 | 1 | R_0603 | 10K(NC) | RG5, RM23, RMB23, RO7, RO8, RP3, RT74, RV1 | 8 | R_0603 | 1K(NC) | RG10, RV2 | 2 | R_0603 | 22 | RM7, RM8, RM9, RM10, RM11, RM12, RM13, RM14, RM15, RM16, RM17, RM18, RMB7, RMB8, RMB9, RMB10, RMB11, RMB12, RMB13, RMB14, RMB15, RMB16, RMB17, RMB18, RP1, RP2, RS9, RS10, RS11, RS12, RS13, RS14, RS15, RS16, RU1, RU2, RU5, RU6, RU9, RU10, RU13, RU14, RW9, RW10, RW11, RW12, RW13, RW14, RW15, RW16, RW17, RW18 | 52 | R_0603 | 4.7K | RM19, RM20, RP4, RP8, RT61 | 5 | R_0603 | 3K(1%) | RP9 | 1 | R_0603 | 1K(1%) | RP10 | 1 | R_0603 | 75 | RT62, RT63, RT65 | 3 | R_0603 | 0/20K(NC) | RT72, RT73 | 2 | R_0603 | 15K | RU3, RU4, RU7, RU8, RU11, RU12, RU15, RU16 | 8 | R_0603 | 2.7K (1%) | RU17 | 1 | R_0603 | 47K | RU20 | 1 | R_0603 | DS18B20 | SENSOR | 1 | TO-92 | LABA | SPK | 1 | DIP2_2.0 | NHDS_4 | SW2, SW4 | 2 | NHDS_4_2.54 | AV-8.4-5A | TVOUT | 1 | TV | AT24C02A | U5 | 1 | SOP-8 | MP1484EN | U6 | 1 | SOIC8 | SP3232EEN | U40, U41 | 2 | SSOP16 | MAX3485 | U42 | 1 | SOP8 | CON6 | UART2 | 1 | DIP6_2.0 | CON4 | UART3 | 1 | DIP4_2.0 | LTC4002-8.4 | UB1 | 1 | LTC4002 | MP1484 | UG1 | 1 | SOIC8 | MG1613S | UP1 | 1 | MG1613S | MG2217S2 | UP2 | 1 | MG2217S2 | USB-A | USB3 | 1 | USB-S | MINIUSB | USBOTG | 1 | MINIUSB | MINI_SD | uSD1 | 1 | SD_MICRO | DM9000AE | UT2 | 1 | DM9000AE | LM1085IS-3.3 | UT3 | 1 | TO-263 | WM8960GEFL | UT5 | 1 | WM8960 | NJM2561F1 | UT6 | 1 | NJM2561F1 | SA4148 | UT7 | 1 | SOP8 | FE1.1S | UU1 | 1 | SSOP-28 | CON16 | WIFI2 | 1 | IDC16_DIP_B | 12M | X2 | 1 | OSC2PR-1 | 25M | X6 | 1 | OSC2PR-1 | + v! ~, [. n, W! ?- d- |! {' l
4 y9 y5 Z& r% E8 t* ?, ?8 P
6 P, A/ U: O+ M4 } |
