查看: 278|回复: 2
干货三:Linux socket编程示例 3多线程并发
发表于 2019-9-26 13:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
# }% ~: S5 z4 z' ^4 `9 o9 ]/ g: m) R6 y, f0 W* |4 i1 O3 P8 L! X5 \& H
2 ^6 F) l" S; H9 W
  • * 文件名:pthread_server.c
  • * 文件描述:创建子线程来接收客户端的数据
  • * louis  tested
  • #include <sys/types.h>
  • #include <sys/socket.h>
  • #include <stdio.h>
  • #include <netinet/in.h>
  • #include <arpa/inet.h>
  • #include <unistd.h>
  • #include <stdlib.h>
  • #include <pthread.h>
  • #include <time.h>
  • void *rec_data(void *fd);
  • int main(int argc,char *argv[])
  •        int server_sockfd;
  •     int *client_sockfd;
  •        int server_len, client_len;
  •        struct sockaddr_in server_address;
  •        struct sockaddr_in client_address;
  •        struct sockaddr_in tempaddr;
  •        int i,byte;
  •        char char_recv,char_send;
  •        socklen_t templen;
  •            int res;
  •        server_sockfd = socket(AF_INET, SOCK_STREAM, 0);//创建套接字
  •        server_address.sin_family = AF_INET;
  •        server_address.sin_addr.s_addr = inet_addr("192.168.1.40"); //htonl(INADDR_ANY);
  •        server_address.sin_port = htons(8888);
  •        server_len = sizeof(server_address);
  •        res= bind(server_sockfd, (struct sockaddr *)&server_address, server_len);//绑定套接字
  •         if(res == -1)
  •                 perror("bind failed");
  •                 exit(-1);
  •        templen = sizeof(struct sockaddr);
  •        res= listen(server_sockfd, 100);// louis 原来的代码确实listen 调试不过
  •        if(res == -1)
  •                 perror("listen failed");
  •                 exit(-1);
  •        printf("server waiting for connect\n");
  •        while(1){
  •               pthread_t thread;//创建不同的子线程以区别不同的客户端
  •               client_sockfd = (int *)malloc(sizeof(int));
  •               client_len = sizeof(client_address);
  •               *client_sockfd = accept(server_sockfd,(struct sockaddr *)&client_address, (socklen_t *)&client_len);
  •               if(-1==*client_sockfd){
  •                      perror("accept");
  •                      continue;
  •               if(pthread_create(&thread, NULL, rec_data, client_sockfd)!=0)//创建子线程
  •                      perror("pthread_create");
  •                      break;
  •               }else{
  •                                         printf("pthread_created\n");
  •                           sleep(1);
  •        shutdown(*client_sockfd,2);
  •        shutdown(server_sockfd,2);
  • * 函数名称:rec_data
  • * 功能描述:接受客户端的数据
  • * 参数列表:fd——连接套接字
  • * 返回结果:void
  •        int client_sockfd;
  •        int i,byte;
  •        char char_recv[100];//存放数据
  •        client_sockfd=*((int*)fd);
  •        for(;;)
  •               if((byte=recv(client_sockfd,char_recv,100,0))==-1)
  •                      perror("recv");
  •                      exit(EXIT_FAILURE);
  •               if(strcmp(char_recv, "exit")==0)//接受到exit时,跳出循环
  •                      break;
  •               printf("receive from client is %s/n",char_recv);//打印收到的数据
  •        free(fd);
  •        close(client_sockfd);
  •        pthread_exit(NULL);
  • 2 m' G0 L  m) d
    & O/ z5 |9 F6 J5 l" o5 H
+ X' K3 S: k# L' y1 g
' |7 y! |& J. U
7 ^" t  U" E# l$ ~1 \# I* _: h9 V9 U
6 s. r3 x% S8 C. [
pthread_client.c
9 ~7 c. _6 s5 X# M/ w/ @8 \
游客,如果您要查看本帖隐藏内容请回复
2 X! [0 K( N+ l) S) Z/ L
4 Y2 a2 D, e# h
GMT+8, 2025-8-24 02:51 , Processed in 0.109375 second(s), 23 queries , Gzip On.
