WM9713+MCP2515+SN65HVD230DR+GM320+ HS9016+三星6410底板原理图+PCB作品文件分享。用AD画的两层板,% ^: ]0 m& \; F2 A7 b- U& Q
板子很简单,适合入门,
# J' Q6 d$ ]& S0 s有需要的可以看看。7 X: ?; w& ]2 w1 l3 G6 A. ~
/ \+ q i& M( i0 M5 C7 W; ^0 m' S层数:2层4 A% L5 y6 i0 c1 D% K3 q
用途:开发板底板! t! X! D- T, W4 `( ^) g2 y
pcb作品截图如下:
( c L- V3 s5 {: ]9 P, p" i; J/ u7 k. R( L- [
5 k' X4 t; r* l3 b$ E
`! ]5 y; Y. m! t: A2 b5 ]! Y& W+ z
1 c2 X$ H( L1 d, C附件:3 r ^ A8 ?1 Q1 O# k& ?
BOM:
1 X A6 c3 v9 S& s# A8 S) N) I, h5 p3 z! g( Z7 v
Comment | Designator | Quantity | Footprint | CR1220 电池座 | BT1 | 1 | DIANCI | 1UF 0603 | C1 | 1 | C0603 | 10uF/6V A | C2, C3, C4, C55, C56, C57 | 6 | C1206A | 100nF | C5, C8, C47, C208, C210, C227, C229, C231 | 8 | C0603 | 10uF | C6 | 1 | C0805 | 33uF/6V | C7, C9 | 2 | C1206B | 104 | C39, C41, C43, C44, C49, C50, C51, C52, C53, C116 | 10 | C0603 | 0.01UF 0805 | C42 | 1 | c0603 | 22pF | C45, C46 | 2 | C0603 | 680pF | C67 | 1 | c0603 | NC | C100, C103, C104, C105, C300, C301, C302 | 7 | C0603 | 100uF/6V | C101, C102 | 2 | C1206B | 100uF/6V B | C114, C115, C117 | 3 | D | 4.7uF | C201, C202, C203, C204, C205, C206 | 6 | C0603 | 10uF/6V | C207, C209 | 2 | c0603 | 1uF | C211, C214, C217, C218, C221, C222, C223, C224, C225, C226, C228, C230, C236 | 13 | C0603 | 2.2uF | C212, C213 | 2 | c0603 | 100uF | C215, C216 | 2 | c0805 | 220pF | C219, C220 | 2 | C0603 | 10uF/6V | C232, C233, C234, C235, C237 | 5 | C1206A | 1N5822 | D9 | 1 | D3528 | P6SMB6.8A | D13 | 1 | SMB | 1N4148 | D15 | 1 | D4148 | Comment | Designator20 | 1 | HAND | MPZ1608S300A | FB6, FB204, FB205, FB206, FB207 | 5 | 0805R | BLM15EG121SN1D | FB14, FB14_1 | 2 | 0805R | BLM15EG121SN1 | FB201, FB202, FB203 | 3 | 0805R | 1.27mm 贴片双排母 2*40P | J1, J2 | 2 | 1.27_2_40 | RCA | J3 | 1 | RCA | RJ-45 带灯 | J4 | 1 | RJ8-SRLFY | NC | J5 | 1 | SIP-3.96MM | RS485 | J6 | 1 | SIP-3.96MM | DR9 母头DB9弯针 | J7 | 1 | DB9 | MINI USB 座子 90°弯针 5针 | J10 | 1 | MiniUSB-DIP | USB-A 90度弯针 母头 | J12 | 1 | USB-AP | SD卡座 自弹式 | J19 | 1 | SDCARD1 | Camera | J22 | 1 | IDC20-2.0MM | DC005电源座 5.5x2.1mm | J24 | 1 | POWER | CK-3.5-025M | J201, J202 | 2 | CK-3.5 | AUDIO | J203 | 1 | SIP2-S | 6*6*6 轻触关 按键 | K1 | 1 | PUSHSW | 轻触按键 2脚 | K2, K3, K4, K5, K6, K7, K8, K9, K10, K11 | 10 | KEY2-DIP | LED贴片 | LED1, LED2, LED8 | 3 | LED | GREEN | LED6 | 1 | LED | BSS138 | Q201 | 1 | SOT-23P | 10K | R1, R2, R31, R32, R47, R48, R49, R50, R51, R52, R53, R54, R55, R56, R93 | 15 | R0603 | 4.7K | R5, R98, R100, R101 | 4 | R0603 | 75R(1%) | R6 | 1 | R0603 | 150R | R9 | 1 | R0603 | 470R | R23, R24 | 2 | R0603 | 75R | R25, R26, R27 | 3 | R0603 | 100 | R25_1, R26_1 | 2 | R0603 | 5.1K | R28 | 1 | R0603 | 120R | R29, R34 | 2 | R0603 | 3.3K | R32_1, R35 | 2 | R0603 | 20R | R33, R36 | 2 | R0603 | 100K | R37, R38, R204 | 3 | R0603 | 1K | R39, R57, R58, R97 | 4 | R0603 | 18K | R40, R43 | 2 | R0603 | 22R | R41, R42, R202 | 3 | R0603 | 330R | R92 | 1 | R0603 | 47K | R201, R207, R208 | 3 | R0603 | NC | R203 | 1 | R0603 | 680R | R205, R206, R209 | 3 | R0603 | 1M | R210, R211 | 2 | R0603 | 20K | R212, R213 | 2 | R0603 | 贴片排阻 10K | RP1, RP2, RP17, RP18 | 4 | RP4 | 贴片排阻 1K | RP3, RP4 | 2 | RP4 | 贴片排阻 22R | RP5, RP6, RP7, RP8, RP9, RP10, RP11, RP12 | 8 | RP4 | 双排自锁 按键开关 8*8 | SW | 1 | SWITCH | 8位拨码开关 贴片 2.54mm | SW1 | 1 | SW8-2.5MM | DC3-50P 2.0MM | U3 | 1 | REALLCD43 | P42 | U3_1 | 1 | PFC40P | P4 | U3_2 | 1 | touch | NJM2561F1 | U4 | 1 | SOT23-6 | MAGCOM HS9016/HR601680 | U11 | 1 | HS9016 | SN65HVD230DR | U12 | 1 | SO-8 | MCP2515-I/SO | U13 | 1 | TSSOP20 | MAX3485 | U14 | 1 | SO-8 | MAX3232 | U15 | 1 | SO-16 | FDC6331L | U16 | 1 | SOT23-6 | GM320 | U26 | 1 | GM320MODULE | LM1117-3.3 | U27, U31 | 2 | SOT-223 | WM9713 | U201 | 1 | QFN48P | XC6219B182MR | U202 | 1 | SOT23-5 | MICROHPONE | U203 | 1 | MIC2 | LM4871MM | U204 | 1 | SO-8 | 8M无源晶振 贴片 两脚 | X1 | 1 | SMDXT | 24.576MHz | X201 | 1 | SMDXTAL | . B- O4 E- R6 P6 I: `( v
| XS1 | 1 | YIXING | P3 | XS2 | 1 | YIXING |
0 ?& K) l+ u3 C8 X9 C" Z' v/ h: o, G) L: u J5 h1 z7 Z
3 j& J5 B3 S [& r6 A! q2 o0 i
! P9 m A0 T0 Y w3 e8 z r, u |
