给我的Mac安装 genymotion。遇到关于安装Genymotion-ARM-Translation_v1.1.zip,插件的问题。
4 W; H2 d- Z* G) j, L$ a, X: a然后按照方法直接拖进去,但是我的Genymotion-ARM-Translation_v1.1.zip被当做文件复制到Sdcart/download目录下& {9 |8 h, ]* e \1 d
于是按照百度搜查的 要手动adb shell 我也成功了& [ b1 C6 Q8 C
解决办法:
7 _2 H4 h' t8 z1 H8 p* @4 h+ X( |2 M直接自己手动flash 这个archive.5 |5 i/ z! w/ [& \, u9 J
1. adb shell/ i1 ]- r) u. g& D8 |
2. cd /sdcard/Download/3 G* W a0 }7 P) S
3. sh /system/bin/flash-archive.sh /sdcard/Download/Genymotion-ARM-Translation_v1.1.zip
6 f A3 @ M$ e' ^命令行:
8 A1 h+ j% }3 @" d4 T2 {8 o+ k4 ~.................$ ^) ?- L R" e5 {
inflating: Genymotion-ARM-Translation_v1/system/lib/libhoudini.so
( O8 Q( V& {8 Linflating: __MACOSX/Genymotion-ARM-Translation_v1/system/lib/._libhoudini.so
* P+ ?) n/ o f, L' a- ^9 {inflating: __MACOSX/Genymotion-ARM-Translation_v1/system/._lib* {, h/ L* T5 y/ k6 J
inflating: __MACOSX/Genymotion-ARM-Translation_v1/._system
4 X" w5 @$ z6 d* R5 K9 o" vinflating: __MACOSX/._Genymotion-ARM-Translation_v19 l; H, {! Y7 Q" K- S/ g- I5 Q
[flash_archive] Remount /system/ in rw
' V) O; u* Y! [* o: e[flash_archive] Start file install
0 t/ Y+ E8 `) f3 r3 nfind: system/: No such file or directory
$ a$ F( s9 V3 @6 b: X* j[flash_archive] Remount /system/ in ro
5 D. T8 h' l* {: z( s[flash_archive] Delete tmp directory& r' |4 T& N5 `7 ?. w
rm failed for /data/local/tmp/sanitized.zip, No such file or directory$ U. ~( _3 M- [! P' r) @4 N4 b
[flash_archive] Done successfully !
% K2 T2 W' U2 g# ^{Result:OK};' y. T* s; x/ n. E4 ?4 I* ]2 @
这样子执行成功之后,运行带.so文件的依然报错:
% ~! K0 E8 I: ?$ f6 i+ o4 pFailure [INSTALL_FAILED_CPU_ABI_INCOMPATIBLE]# G" ]" P2 G* w5 Y% Z6 i7 d7 H
% L9 m' B7 G9 {! v+ e, H6 l! x$ m, R
2 k9 b( X- \! `+ A6 R5 L
$ M, o; j: [. \" f* z( z/ a) s' |( F. K
