查看: 506|回复: 1
MASWSS0130+MGA_412P8+XC61FN1812M+低功耗wifi soc G2C501开发板+原理图+PCB作品文...
发表于 2019-9-19 11:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
  v# S3 w: ]# p' Z, w" z' d: U9 _& }2 x8 [
MASWSS0130+MGA_412P8+XC61FN1812M+低功耗wifi soc G2C501开发板+原理图+PCB作品文件分享。
! i. @$ T  }+ h用AD画的4层板,板子很简单,时候入门,有需要的可以看看。
* g' [9 T6 b5 P0 N4 ~  C- j
: Y  e, e2 x4 J9 D( S) M
层数:4层
. p  _) i  x0 x/ T3 G; ?! ~用途:开发板1 `) e, O- B  g7 X. \# M
pcb作品截图如下:7 n& r9 f2 t0 k
6 |  M) b, g& o/ q  U' s9 t
% T0 e$ m* b3 Y. _# q
) p( O  S6 Y" _5 w: }1 z( }
附件:
; }" H, ]8 U4 ?" D# N4 [& W4 L/ _
游客,如果您要查看本帖隐藏内容请回复
* @, |: u- h" A( S
! h% c! k; k# {$ f$ S1 xBOM:
$ L7 X0 O5 Z: u1 y, z: a
" Z* Y) ]/ [6 |
Comment
Designator
Quantity
Footprint
Vertical Inverted F
ANT1, ANT3
ANT_PAD_1_5X1_5
Chip Antenna
ANT2
ACA7636
Battery Contact
BC1, BC2
BATT_CONTACT_2X5_5MM
0.01uF
C1, C45
8.2pF
C2, C11, C20, C44, C56, C57, C59, C60, C61, C62
10
0402
NS
C3, C29, C46, C63, C64, C65, C66, R12, R16, R19, R22, R24, R26, R27, R34, R35, R55, R56
18
0402
0.5pF
C4, C24
1.2pF
C5, C6, C9
1000pF
C7, C8
2.2uF
C10
1.5pF
C12
100pF
C13, C16, C17, C52
0.1uF
C14, C38, C39, C41, C42, C49, C51, C53
8
0402
10uF
C15, C30, C36, C54
0.15uF
C18
6.8pF
C19, C28
0.9pF
C22
18pF
C25, C26
27pF
C27, C32
180pF
C31
1uF
C33, C34, C35, C37, C40, C43, C47, C48, C50
9
0402
330pF
C55
100uF
C58
F95-T
SL12
D1
DO_214AC
Fiducial
FID1, FID2, FID3, FID4
FIDUCIAL_1MM
LFB322G45SN1A504
FIL1
LFB322G45
FTSH-108-01-F-MT
J1
FTSH_16MT
FTSH-108-01-F-DV-K
J2
FTSH_108_DV
2.2nH
L1
10nH
L2, L14
4.7nH
L3
5.6nH
L4, L6, L9
4308RV-335XGB
L5
COILCRAFT_4308RV
10uH
L7
COILCRAFT_WURTH_10UH_VER3
1uH
L8
1008PS
18nH
L10
1.2nH
L11
BRPY1211C
LED1
BRPY1211C
MM8430-2600B
P1
MM8430_2600B
Si2312SA
Q1, Q2
SOT_23
BSV236SP
Q3
SOT_363
2N7002
Q4
SOT_23
100K
R1, R2, R3, R41
100
R4, R7
68
R5
10K
R6, R10, R17, R54
22
R8
36K
R9, R11
220
R13, R14, R32, R42, R43, R44, R45, R46, R47, R48, R49, R50, R51, R52, R53
15
0402
0
R15, R18, R20, R23, R25, R28, R29, R30, R31, R33, R36, R37
12
0402
33
R21, R40
1.0M
R38
3.3M
R39
Thermistor
RT1
TL3301
S1
TL3301_J
TILT & VIBRATION
SEN1
SQ_SEN_200
TP
TP1
TP_0_6MM_SMT
TP
TP10
TP_0_55X0_3MM
TP
TP22
TP_0_6X0_3MM
5.5V
TS1, TS2, TS3, TS4, TS5, TS6, TS7, TS8, TS9, TS10, TS11, TS12
12
0402
G2C501
U1
G2C510_QFN_72
MASWSS0130
U2
MASWSS0130
MGA_412P8
U3
MGA_412P8
NL27WZ86
U4
US8
1Mbit FLASH
U5
SO_8_200MIL_COMBO
XC61FN1812M
U6
SOT-23
32.768KHz
Y1
CMR200T
44MHZ
Y2
SCX_290
: t& _# i+ M8 [0 _! a7 H
, W/ M, x9 G: g
  U5 g5 O! j$ S, y' S" Q$ _6 _
7 g' j4 T! n& n, O' L, X7 n8 p
# R' f& G, W# }; ^0 u' ~
发表于 2019-9-19 17:56 | 只看该作者
练手用用,谢谢分享。
GMT+8, 2025-7-19 13:33 , Processed in 0.140625 second(s), 27 queries , Gzip On.
