查看: 274|回复: 2
从linux内核中抽取的crc16的算法,值得学习
发表于 2019-9-18 13:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • // crc16.cpp : Defines the entry point for the console application.
  • 0 p. O% m8 ^! E
  • #include "stdafx.h"
  • #include "stdlib.h"
  • #include "math.h"
  • ! W) x+ F6 r$ H
  • *      crc16.c
  • * This source code is licensed under the GNU General Public License,
  • * Version 2. See the file COPYING for more details.
  • % `1 k4 x  b" p, c" Z6 y
  • " y  W7 ?, c3 b# [
  • /** CRC table for the CRC-16. The poly is 0x8005 (x^16 + x^15 + x^2 + 1) */
  • unsigned short const crc16_table[256] = {
  •         0x0000, 0xC0C1, 0xC181, 0x0140, 0xC301, 0x03C0, 0x0280, 0xC241,
  •         0xC601, 0x06C0, 0x0780, 0xC741, 0x0500, 0xC5C1, 0xC481, 0x0440,
  •         0xCC01, 0x0CC0, 0x0D80, 0xCD41, 0x0F00, 0xCFC1, 0xCE81, 0x0E40,
  •         0x0A00, 0xCAC1, 0xCB81, 0x0B40, 0xC901, 0x09C0, 0x0880, 0xC841,
  •         0xD801, 0x18C0, 0x1980, 0xD941, 0x1B00, 0xDBC1, 0xDA81, 0x1A40,
  •         0x1E00, 0xDEC1, 0xDF81, 0x1F40, 0xDD01, 0x1DC0, 0x1C80, 0xDC41,
  •         0x1400, 0xD4C1, 0xD581, 0x1540, 0xD701, 0x17C0, 0x1680, 0xD641,
  •         0xD201, 0x12C0, 0x1380, 0xD341, 0x1100, 0xD1C1, 0xD081, 0x1040,
  •         0xF001, 0x30C0, 0x3180, 0xF141, 0x3300, 0xF3C1, 0xF281, 0x3240,
  •         0x3600, 0xF6C1, 0xF781, 0x3740, 0xF501, 0x35C0, 0x3480, 0xF441,
  •         0x3C00, 0xFCC1, 0xFD81, 0x3D40, 0xFF01, 0x3FC0, 0x3E80, 0xFE41,
  •         0xFA01, 0x3AC0, 0x3B80, 0xFB41, 0x3900, 0xF9C1, 0xF881, 0x3840,
  •         0x2800, 0xE8C1, 0xE981, 0x2940, 0xEB01, 0x2BC0, 0x2A80, 0xEA41,
  •         0xEE01, 0x2EC0, 0x2F80, 0xEF41, 0x2D00, 0xEDC1, 0xEC81, 0x2C40,
  •         0xE401, 0x24C0, 0x2580, 0xE541, 0x2700, 0xE7C1, 0xE681, 0x2640,
  •         0x2200, 0xE2C1, 0xE381, 0x2340, 0xE101, 0x21C0, 0x2080, 0xE041,
  •         0xA001, 0x60C0, 0x6180, 0xA141, 0x6300, 0xA3C1, 0xA281, 0x6240,
  •         0x6600, 0xA6C1, 0xA781, 0x6740, 0xA501, 0x65C0, 0x6480, 0xA441,
  •         0x6C00, 0xACC1, 0xAD81, 0x6D40, 0xAF01, 0x6FC0, 0x6E80, 0xAE41,
  •         0xAA01, 0x6AC0, 0x6B80, 0xAB41, 0x6900, 0xA9C1, 0xA881, 0x6840,
  •         0x7800, 0xB8C1, 0xB981, 0x7940, 0xBB01, 0x7BC0, 0x7A80, 0xBA41,
  •         0xBE01, 0x7EC0, 0x7F80, 0xBF41, 0x7D00, 0xBDC1, 0xBC81, 0x7C40,
  •         0xB401, 0x74C0, 0x7580, 0xB541, 0x7700, 0xB7C1, 0xB681, 0x7640,
  •         0x7200, 0xB2C1, 0xB381, 0x7340, 0xB101, 0x71C0, 0x7080, 0xB041,
  •         0x5000, 0x90C1, 0x9181, 0x5140, 0x9301, 0x53C0, 0x5280, 0x9241,
  •         0x9601, 0x56C0, 0x5780, 0x9741, 0x5500, 0x95C1, 0x9481, 0x5440,
  •         0x9C01, 0x5CC0, 0x5D80, 0x9D41, 0x5F00, 0x9FC1, 0x9E81, 0x5E40,
  •         0x5A00, 0x9AC1, 0x9B81, 0x5B40, 0x9901, 0x59C0, 0x5880, 0x9841,
  •         0x8801, 0x48C0, 0x4980, 0x8941, 0x4B00, 0x8BC1, 0x8A81, 0x4A40,
  •         0x4E00, 0x8EC1, 0x8F81, 0x4F40, 0x8D01, 0x4DC0, 0x4C80, 0x8C41,
  •         0x4400, 0x84C1, 0x8581, 0x4540, 0x8701, 0x47C0, 0x4680, 0x8641,
  •         0x8201, 0x42C0, 0x4380, 0x8341, 0x4100, 0x81C1, 0x8081, 0x4040
  • ! D' t) w. J0 g) S
  • static unsigned short crc16_byte(unsigned short crc, const unsigned char data)
  •         return (crc >> 8) ^ crc16_table[(crc ^ data) & 0xff];
  • % Y3 E% p; N& u. y# b4 R7 [
  • * crc16 - compute the CRC-16 for the data buffer
  • * @crc:        previous CRC value
  • * @buffer:        data pointer
  • * @len:        number of bytes in the buffer
  • * Returns the updated CRC value.
  • unsigned short crc16(unsigned short crc, unsigned char const *buffer, size_t len)
  •         while (len--)
  •                 crc = crc16_byte(crc, *buffer++);
  •         return crc;
  • ! h: S  \2 {5 n
  • int main(int argc, char* argv[])
  •         unsigned char temp[1024]={0};
  •         for (int i=0;i<sizeof(temp);i++)
  •                 temp=rand()%0xff;
  • //                printf("%03d\n",temp);
  •         printf("0x%04x\n",crc16(0,temp,sizeof(temp)));
  • //        printf("Hello World!\n");
  •         getchar();
  •         return 0;
  • ' g. {% V) D- ^& m& x' `" B
    ; a' Z6 _5 \# v8 S# _
$ s  h: L4 H) F9 C9 l
发表于 2019-9-18 17:31 | 只看该作者
谢谢楼主分享。
发表于 2019-9-19 09:14 | 只看该作者
不错,值得学习!
GMT+8, 2025-8-23 22:21 , Processed in 0.140625 second(s), 23 queries , Gzip On.
