- //linux下ALSA播放声音的源程序
- //@note 编译的时候,使用到了asound 的lib 所以要添加-lasoud库
- #include <stdio.h>
- /* Use the newer ALSA API */
- #define ALSA_PCM_NEW_HW_PARAMS_API
- 9 R$ c' U* ~" L' A
- #include <alsa/asoundlib.h>
- 3 p$ a" |$ B& z/ j5 i/ A
- int main()
- long loops;
- int rc;
- int size;
- snd_pcm_t *handle;
- snd_pcm_hw_params_t *params;
- unsigned int val;
- int dir;
- snd_pcm_uframes_t frames;
- snd_pcm_uframes_t periodsize;
- char *buffer;
- FILE *fp = fopen("play.wav", "rb");
- if(fp == NULL)
- return 0;
- fseek(fp, 100, SEEK_SET);
- /* Open PCM device for playback. */
- rc = snd_pcm_open(&handle, "default",
- SND_PCM_STREAM_PLAYBACK, 0);//SND_PCM_NONBLOCK);
- if (rc < 0) {
- fprintf(stderr,
- "unable to open pcm device: %s\n",
- snd_strerror(rc));
- exit(1);
- 2 l! C$ f5 f. M
- /* Allocate a hardware parameters object. */
- snd_pcm_hw_params_alloca(¶ms);
3 S$ r5 T% ]& z1 D2 _. y8 e- /* Fill it in with default values. */
- snd_pcm_hw_params_any(handle, params);
- % R9 S' C6 V+ ]8 K! a! s& g
- /* Set the desired hardware parameters. */
) G5 ?8 k" P2 t, o0 C, w% V) z- /* Interleaved mode */
- snd_pcm_hw_params_set_access(handle, params,
- SND_PCM_ACCESS_RW_INTERLEAVED);
, [% u# ?. k& j0 ?" g3 M- /* Signed 16-bit little-endian format */
- snd_pcm_hw_params_set_format(handle, params,
- SND_PCM_FORMAT_S16_LE);
% n) Z! F+ P/ s; ^9 z S9 C3 [- /* Two channels (stereo) */
- snd_pcm_hw_params_set_channels(handle, params, 1);
" T" v& L6 C( D6 T9 ]3 f2 @' m- /* 44100 bits/second sampling rate (CD quality) */
- val = 8000;
- snd_pcm_hw_params_set_rate_near(handle, params,
- &val, &dir);
- . L! }' w0 Z/ C
- /* Set period size to 32 frames. */
- frames = 32;
- periodsize = frames * 2;
- rc = snd_pcm_hw_params_set_buffer_size_near(handle, params, &periodsize);
- if (rc < 0)
- printf("Unable to set buffer size %li : %s\n", frames * 2, snd_strerror(rc));
- periodsize /= 2;
- rc = snd_pcm_hw_params_set_period_size_near(handle, params, &periodsize, 0);
- if (rc < 0)
- printf("Unable to set period size %li : %s\n", periodsize, snd_strerror(rc));
- /* Write the parameters to the driver */
- rc = snd_pcm_hw_params(handle, params);
- if (rc < 0) {
- fprintf(stderr,
- "unable to set hw parameters: %s\n",
- 3 V' g0 }0 Z' u0 d( M
- /* Use a buffer large enough to hold one period */
- snd_pcm_hw_params_get_period_size(params, &frames, &dir);
- size = frames * 2; /* 2 bytes/sample, 2 channels */
- buffer = (char *) malloc(size);
- fprintf(stderr,
- "size = %d\n",
- size);
- /* We want to loop for 5 seconds */
- //snd_pcm_hw_params_get_period_time(params,
- // &val, &dir);
- //snd_pcm_start(handle);
- while (1)
- rc = fread(buffer, 1, size, fp);
- if(rc == 0)
- fprintf(stderr, "end of file on input\n");
- break;
- else if (rc != size)
- J& U; i" w1 ?6 V/ R' |3 Y- while(rc = snd_pcm_writei(handle, buffer, frames)<0)
- usleep(2000);
- if (rc == -EPIPE)
- /* EPIPE means underrun */
- fprintf(stderr, "underrun occurred\n");
- snd_pcm_prepare(handle);
- else if (rc < 0)
- fprintf(stderr,
- "error from writei: %s\n",
- //snd_pcm_drain(handle);
- //usleep(7000);
- //printf("#\n");
- snd_pcm_drain(handle);
- snd_pcm_close(handle);
- free(buffer);
- fclose(fp);
- return 0;
- }/ d. y/ \) T4 @3 f/ F: B% y
% h1 w J. c" K) W3 D7 z p" R; I. w8 `
1 m) O: T/ I& W' y7 z5 y
/ T9 q: |' I- @) n* ^ |
