- /**alsa play test
- *ALSA用户空间编译,ALSA驱动的声卡在用户空间,不宜直接使用
- *文件接口中,而应使用alsa-lib
- *打开---->设置参数--->读写音频数据 ALSA全部使用alsa-lib中的API
- *交叉编译
- *export LD_LIBRARY_PATH=$PWD:$LD_LIBRARY_PATH
- *ARM-linux-gcc -o alsa_play alsa_play_test.c -L. -lasound
- *需要交叉编译后的libasound.so库的支持
- #include <stdio.h>
- #include <stdlib.h>
- #include "alsa/asoundlib.h"
- 9 }2 o8 P1 S7 V g2 q0 T* ]
- int main(int argc, char *argv[])
- int i;
- int ret;
- int buf[128];
- unsigned int val;
- int dir=0;
- char *buffer;
- int size;
- snd_pcm_uframes_t frames;
- snd_pcm_uframes_t periodsize;
- snd_pcm_t *playback_handle;//PCM设备句柄pcm.h
- snd_pcm_hw_params_t *hw_params;//硬件信息和PCM流配置
- if (argc != 2) {
- printf("error: alsa_play_test [music name]\n");
- exit(1);
- printf("play song %s by wolf\n", argv[1]);
- FILE *fp = fopen(argv[1], "rb");
- if(fp == NULL)
- return 0;
- fseek(fp, 100, SEEK_SET);
- //1. 打开PCM,最后一个参数为0意味着标准配置
- ret = snd_pcm_open(&playback_handle, "default", SND_PCM_STREAM_PLAYBACK, 0);
- if (ret < 0) {
- perror("snd_pcm_open");
- exit(1);
- //2. 分配snd_pcm_hw_params_t结构体
- ret = snd_pcm_hw_params_malloc(&hw_params);
- if (ret < 0) {
- perror("snd_pcm_hw_params_malloc");
- exit(1);
- //3. 初始化hw_params
- ret = snd_pcm_hw_params_any(playback_handle, hw_params);
- if (ret < 0) {
- perror("snd_pcm_hw_params_any");
- exit(1);
- //4. 初始化访问权限
- ret = snd_pcm_hw_params_set_access(playback_handle, hw_params, SND_PCM_ACCESS_RW_INTERLEAVED);
- if (ret < 0) {
- perror("snd_pcm_hw_params_set_access");
- exit(1);
- //5. 初始化采样格式SND_PCM_FORMAT_U8,8位
- ret = snd_pcm_hw_params_set_format(playback_handle, hw_params, SND_PCM_FORMAT_U8);
- if (ret < 0) {
- perror("snd_pcm_hw_params_set_format");
- exit(1);
- //6. 设置采样率,如果硬件不支持我们设置的采样率,将使用最接近的
- //val = 44100,有些录音采样频率固定为8KHz
- , c7 G, Q: ^ U
- val = 8000;
- ret = snd_pcm_hw_params_set_rate_near(playback_handle, hw_params, &val, &dir);
- if (ret < 0) {
- perror("snd_pcm_hw_params_set_rate_near");
- exit(1);
- //7. 设置通道数量
- ret = snd_pcm_hw_params_set_channels(playback_handle, hw_params, 2);
- if (ret < 0) {
- perror("snd_pcm_hw_params_set_channels");
- exit(1);
- /* Set period size to 32 frames. */
- frames = 32;
- periodsize = frames * 2;
- ret = snd_pcm_hw_params_set_buffer_size_near(playback_handle, hw_params, &periodsize);
- if (ret < 0)
- printf("Unable to set buffer size %li : %s\n", frames * 2, snd_strerror(ret));
- periodsize /= 2;
- # N% t# q! @4 l% Z% o/ \4 B1 {
- ret = snd_pcm_hw_params_set_period_size_near(playback_handle, hw_params, &periodsize, 0);
- if (ret < 0)
- printf("Unable to set period size %li : %s\n", periodsize, snd_strerror(ret));
- //8. 设置hw_params
- ret = snd_pcm_hw_params(playback_handle, hw_params);
- if (ret < 0) {
- perror("snd_pcm_hw_params");
- exit(1);
- /* Use a buffer large enough to hold one period */
- snd_pcm_hw_params_get_period_size(hw_params, &frames, &dir);
- size = frames * 2; /* 2 bytes/sample, 2 channels */
- buffer = (char *) malloc(size);
- fprintf(stderr,
- "size = %d\n",
- size);
- while (1)
- ret = fread(buffer, 1, size, fp);
- if(ret == 0)
- fprintf(stderr, "end of file on input\n");
- break;
- else if (ret != size)
- //9. 写音频数据到PCM设备
- while(ret = snd_pcm_writei(playback_handle, buffer, frames)<0)
- usleep(2000);
- if (ret == -EPIPE)
- /* EPIPE means underrun */
- fprintf(stderr, "underrun occurred\n");
- //完成硬件参数设置,使设备准备好
- snd_pcm_prepare(playback_handle);
- else if (ret < 0)
- fprintf(stderr,
- "error from writei: %s\n",
- snd_strerror(ret));
- //10. 关闭PCM设备句柄
- snd_pcm_close(playback_handle);
- return 0;
5 h' N" Y5 t0 S: a
* Q P3 D0 n2 `' f' [$ `/ C6 M+ h! ?( t8 G. K& `" l
