TA的每日心情 | 开心 2019-11-20 15:00 |
签到天数: 2 天 [LV.1]初来乍到
本帖最后由 Ferrya 于 2019-9-17 15:08 编辑 7 T" f$ R+ l. K1 O5 s
h( s+ i& e3 @- k, J" v7 h" A$ n
HC14AG+TL082CM+EPM7064S+MC14053B+电机高压驱动板PCB作品文件分享 a# Q0 n1 o) @2 P* ]5 a" C
用AD画的双层板,布局布线很清晰,也很漂亮,有需要的可以看看。1 w/ t: k* G4 p4 Z8 k+ ]0 t5 h
层数:2层( E2 y8 Y( V; n$ n) i/ ^. G
用途:驱动板
, f6 R' N$ V. K5 E$ Q) e: Q* Tpcb作品截图如下:
5 m' [* {% A! @
( M' n: w# t# w$ ~% S9 u
0 {) ?. N$ E9 X+ z8 W( [
附件:3 `3 m8 E5 f$ s# G$ A7 h \
; w7 F' z8 q# L& z& g# @' ?% A
BOM:0 l1 D. M& a# ]5 n6 j( c
4 c0 ~5 |6 ^$ `! w ?9 nComment | Designator | Quantity | Footprint | 4.7nF | C1, C48 | 2 | 1206Z | 0.47uF | C2 | 1 | ZLC3527 | 470pF | C3, C4, C6, C7, C41, C54, C62 | 7 | 1206Z | CBB 154nF/250v | C5 | 1 | ZLRD0.7 | 470uF/100V | C8 | 1 | ZLRD50 | 15uF | C9, C11, C14 | 3 | ZLC7423 | 6.8uF | C10 | 1 | ZLC3527 | CBB 684nF/250v | C12, C13 | 2 | ZLRD2.0 | 33nF | C15, C16, C18, C20, C28, C30, C31, C58, C60 | 9 | ZL1206 | 0.1uF | C17 | 1 | ZL1210 | 0.1uF | C19, C32, C33, C39, C47, C50, C51 | 7 | 1206Z | 100pF | C21 | 1 | ZL1206 | 33nF | C22, C23, C24, C25, C37, C42 | 6 | 1206Z | 0.1uF | C26, C34, C44, C55 | 4 | ZL1206 | 1nF | C27, C40 | 2 | 1206Z | 470pF | C29, C35, C59 | 3 | ZL1206 | 3.3nF | C36 | 1 | 1206Z | 15nF | C38 | 1 | 1206Z | 100pF | C43, C52, C53, C56, C57, C61 | 6 | 1206Z | 0.33uF | C45 | 1 | ZL1210 | 0.1uF/250V | C46 | 1 | 1210 | 2.2nF | C49 | 1 | 1206Z | 0.33uF | C63 | 1 | 1206Z | Fault | D1 | 1 | ZLLED | Power | D2 | 1 | ZLLED | Normal | D3 | 1 | ZLLED | DIODE | D4, D5, D13, D14, D15, D19 | 6 | ZLSOT-23 | 6 R& {9 C: L! Y* p: a: K" Q
| D6, D8 | 2 | ZLD6 | DIODE SCHOTTKY | D7 | 1 | ZLSOT-23 | 0.627V | D9 | 1 | ZLD6 | US1M | D10, D11 | 2 | ZLD3528 | DIODE | D12, D16, D18 | 3 | ZLD3528 | 6.8V | D17 | 1 | ZLSOT-23 | 20PIN | J1, J2 | 2 | SIP20 | CON5 | P1 | 1 | ZLP5X0 | CON16 | P2 | 1 | ZLP16 | CON6 | P3 | 1 | P6_1.25 | JFET P(6Y) | Q1, Q10 | 2 | ZLSOT-23 | PNP(2D) | Q2, Q11 | 2 | ZLSOT-23 | NPN(1D) | Q3 | 1 | ZLSOT-23 | NPN1 | Q4, Q7 | 2 | ZLSOT-23 | PNP1 | Q5 | 1 | ZLSOT-23(PNP) | MOSFET N(6Z) | Q6, Q9 | 2 | ZLSOT-23 | IR310 | Q8 | 1 | ZLIR310 | MOSFET N | Q12, Q13, Q14, Q15 | 4 | ZLFET01 | 3006P(50K) | R1, R3, R4, R5 | 4 | ZLRX3 | 3006P(500K) | R2 | 1 | ZLRX3 | 0.01R/3W | R6 | 1 | ZLRD2.0R | 100R | R7, R13, R16, R22, R24, R60 | 6 | 1206Z | 1.21K | R8 | 1 | 1206Z | 10K | R9, R26, R27, R28, R35, R40, R45, R52 | 8 | 1206Z | 6.19K | R10 | 1 | 1206Z | 499R | R11, R43 | 2 | 1206Z | 20R | R12, R15, R20, R21, R42 | 5 | 1206Z | 0R | R14, R17, R23, R25 | 4 | 1206Z | 0.01R/5W | R18, R19 | 2 | ZLRD3.0 | 100K | R29 | 1 | 1206Z | 1K | R30, R37 | 2 | 1206Z | 54.9K | R31 | 1 | ZL1206 | 4.99K | R32, R38, R51 | 3 | 1206Z | 34K | R33 | 1 | 1206Z | 2K | R34 | 1 | 1206Z | 20K | R36 | 1 | 1206Z | 169K | R39, R46 | 2 | 1206Z | 1R | R41 | 1 | 1206Z | 24.9K | R44 | 1 | 1206Z | 30.1K | R47 | 1 | ZL1206 | 1.2M | R48 | 1 | ZL1206 | 174K | R49 | 1 | 1206Z | 49.9K | R50 | 1 | 1206Z | 5.62K | R53 | 1 | 1206Z | 200K | R54, R55 | 2 | ZL1206 | 10R | R56 | 1 | 1206Z | 90.9K | R57, R58 | 2 | 1206Z | 200R | R59 | 1 | 1206Z | 10K | R61, R62 | 2 | ZL1206 | 221K | R63 | 1 | 1206Z | 2K | R64 | 1 | ZL1206 | 470R | R65 | 1 | 1812 | 20K | R66, R67 | 2 | ZL1206 | 1R | R68 | 1 | ZL1206 | 50K | R70 | 1 | 3313-3 | 1K | R71, R72, R73, R74, R75 | 5 | 0603ZL | 0R | R76 | 1 | 0603ZL | 100 | R77 | 1 | 0603ZL | 10K | RN1 | 1 | ZSOO16 | 47K | RN2 | 1 | ZSOO16 | 1K | RN3, RN6 | 2 | ZLRN4 | 2.2K | RN4 | 1 | ZLRN4 | 10K | RN5, RN9 | 2 | ZLRN8 | 470R | RN7 | 1 | ZLRN4 | 4.7K | RN8 | 1 | ZLRN4 | RES4 | RT1 | 1 | ZLLED | 3 B( G# G4 {( ]( `* t& A, ~$ G5 j
| S1 | 1 | ZLS4 | RM6 | T1 | 1 | ZLRM6 | HC14AG | U1 | 1 | SO-14 | TL082CM | U2 | 1 | so-8 | LF347 | U3, U10, U16 | 3 | SO-14 | EPM7064S | U4 | 1 | QFP44-2 | LM339DG | U5, U12 | 2 | SO-14 | MC14053B | U6 | 1 | SO-16 | LT1242 | U7 | 1 | so-8 | OP27 | U9 | 1 | SO-8 | LM311 | U11 | 1 | SO-8 | MC78M05ABDTG | U13 | 1 | ZL78M05 | IR2110S | U14, U15 | 2 | ZLIR2110 | , U* g! _) E3 d9 B3 k% O! h5 _
3 O" Z' J! b( y7 D* |+ k; j9 _; ^9 v0 ~- v, S
0 A7 [) V0 C2 I3 H' [% K9 f+ b2 M1 L! {: Z* ^. O7 N. N, A
