查看: 848|回复: 1
CON136+MAX3232ESE+DS1337+HR911105+飞凌335X开发板原理图+PCB作品文件分享。
发表于 2019-9-16 13:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
5 ]7 @3 H- H+ q  C  l) a
# b0 S" W8 L* A7 Q5 oCON136+MAX3232ESE+DS1337+HR911105+飞凌335X开发板原理图+PCB作品文件分享。% n0 U4 B( j% T6 a7 N' b4 J2 X
用AD画的两层板,画的很漂亮,有需要的可以看看。
- d+ l. y2 [1 n* ?2 W
$ d3 |3 S( `, _/ i: F0 |( L+ e$ w
/ R: P4 t7 |  u2 A$ ?
层数:2层4 o3 Q: m4 b) _) @2 ~
用途:开发板
; ~* x' l  ]( J! U( O
pcb作品截图如下:/ ?% H4 C& D; e+ v$ h
8 A( ^! p$ `6 f3 Q
  i+ c  b3 m7 |
( M' ?5 u1 e0 _, q
1 X2 \. X* ?9 l6 o8 O- p; ~* h附件:
' @) ?' e/ b* L0 ~, h5 ^
游客,如果您要查看本帖隐藏内容请回复
- J8 a4 F6 v6 x* q
8 b1 Y" L% E7 D, k6 ^BOM:4 \( x! ^+ A+ b0 h- I) }
. W3 d+ `: }+ a
Comment
Designator
Quantity
Footprint
BH1220-SMD
BT1
BH-1220 BATTERY
Cap
C1, C2, C3, C5, C6, C14, C16, C17, C18, C22, C23, C24, C25, C26, C27, C28, C29
17
C0603_M1608
C0603
C4, C7, C8, C9, C12, C13, C15, C31, C33, C34, C35
11
C0603_M1608
Cap Pol3
C10, C20, C21
TC3216A
82pF
C11
C0603_M1608
C1210
C30, C32
C1210_M3225
COM0-DEBUG
CON1
DSUB1.385-2H9-M
BAT54C
D1
SOT23-3D-C95P280X100
SMBJ6.0A SMB(DO-214AA)
D2
DIODE-SK34A
MBR0540 SOD123-NC
D3
D1206
LCTVS
D4, D5, D6, D7, D8, D9, D10, D11, D12
9
SOT-523
SMD1210P110TFT,2A
F1
C1210_M3225
SDCARD-KMSD18
J1
TF-CARD
LCD
J2
FPC54
+5V
J3
JACK-2.5MM_B
miniUSB
J4
MINIUSB
6*6*5卧式2脚带支架
K1, K2, K3, K4, K5
SW-01
150R@100Mhz
L1
L0603_M1608
LED0603
LED1, LED2
LED0603_M1608
POWER_LED
LED3
LED0603_M1608
Speaker
LS1
BEEL-9*5.5
UART
P1
IDC10S
SDIO-WIFI/I2C/CODEC
P2
IDC20S
P3
HX2.54_2P
ADC/SPI
P5
IDC10S
GPIO
P6
IDC10S
CAN/PWM
P9
IDC10S
S9013-SOT23
Q1
SOT23
R0603
R1, R2, R3, R4, R5, R6, R7, R8, R9, R14, R18, R19, R20, R21, R22, R26, R28, R30, R31, R32, R33, R34, R36, R37, R38, R39, R41, R42, R43, R44, R46, R48, R49, R54, R56, R57, R58, R59, R60, R61, R62, R63, R64, R65
44
R0603_M1608
22R
R10, R11, R12, R13, R15, R16, R23, R24, R25, R45
10
R0603-8P4R
10K
R17
R0603_M1608
22R
R27
R0603_M1608
1K_NC
R29
R0603_M1608
Res3
R35, R47, R50, R51, R52, R53, R55
R0603_M1608
VR-3296W
RP1
3296W
POWER SW
S1
SW01
CON136-1.27MM-SMT
U1
FET335S_V1.1
MAX3232ESE
U2
SOIC-16N
DS1337
U3
SOIC-8N
DP83848K
U4
QFN40P-6*6
HR911105A
U5
RJ-45A12
TPS2051BD
U6
SOIC-8N
LM1117
U7
LM1117
USB-B
USB-1
USB-C
32.768K
X1
CRYSTALS_3215_2PIN
50M
X2
Y7050
( Y  Q1 I" S7 m( U! J- h8 Z
0 g  L) [0 q( e
8 p8 j' a- C8 f: {7 _
0 e% L* E: t" O) b4 E
- p! p7 Q& x8 Z3 H$ p) ^
+ {+ e6 N( _8 ^: v0 |5 P; k
, H3 H  b9 f2 p3 J
发表于 2019-9-17 21:34 | 只看该作者
画的很漂亮。
GMT+8, 2025-7-19 20:30 , Processed in 0.125000 second(s), 27 queries , Gzip On.
