PCA9535BS+ISL6236AIRZ+PCF8563T+TPS2034D+TLV803SDBZR+iMX6 处理器 底板PCB作品文件分享。0 C1 ?( j2 H S
6 Y% I7 C6 T8 a; W用AD画的,布局布线很清晰,也很漂亮,板子局部较密,有一定难度,有需要的可以看看
9 K+ V7 l A0 h$ f3 g) _3 D
- C/ d" D* e" b- o$ T# \6 w! U0 c层数:6层2 I o# f7 E! O" {$ {' o
用途:底板
# N$ }2 V" x: N$ i0 p& D2 Spcb作品截图如下:$ D' ?. R9 m! t2 L2 v" Z& X
% i3 z) i2 l1 s
6 G$ v3 f5 g W9 g6 }$ f5 T
. C' o( `& ~/ P" X
B; t7 c5 q% P4 P* F4 V# V
9 j( c# N0 r6 l9 m: ^8 R. `
附件:6 A U6 [, h* ^
8 I) l: v8 n+ ~% ~7 g
: u0 d2 m% I5 @& c4 s
2 P+ a9 {* I- M9 {% c4 pBOM:# V" U* l" g$ n* C- d( x
5 q* o! |; h, s2 C. F7 ^5 FComment | Quantity | Footprint | 100n | 90 | C0402 | 10uF | 8 | C1206 | 1u | 43 | C0402 | 22u | 4 | C0805 | 330u | 11 | C2917 | 4u7 | 14 | C0402 | 10u | 9 | C0603 | 2700pF | 6 | C0402 | 470nF | 5 | C0402 | 10n | 2 | C0402 | 270pF | 8 | C0402 | 2u2 | 1 | C0402 | 18p | 2 | C0402 | 1000pF, 2kV | 1 | C1206 | 100pF | 2 | C0402 | 220u, 4V | 2 | C1206 - TLN S Case Tantal | 220n | 1 | C0402 | 4x 220pF | 2 | 4X_CAP_CC0805_CKCL44 | 1uF | 1 | C0805 | 100μF | 6 | C1206 | 7E50-C016-00 | 1 | CFAST_LOCKER | Green | 4 | LED_0603 | BZA956A,115 | 2 | SOT665 | BAT54HT1G | 3 | SOD323 | BGX50AE6327 | 5 | SOT143 | Red | 2 | LED_0603 | BAT54C-7-F | 1 | SOT-23-3-123 | B560C-13-F | 3 | SMC | 553-0121F | 1 | 553-0121F | PGB1010603MR | 1 | C0603 | 220R, 2.5A | 5 | C0603 | BLM15AX601SN1D | 9 | C0402 | MPZ1608S601A 600OHM/1A | 10 | C0603 | 4x 220R | 2 | 4X0402_BLA2A_MURATA | QTH-030-01-L-D-A | 2 | QTH-030-01-L-D-A | 10018783-10010TLF | 1 | MINI_PCIE_36PIN | MM60-52B1-E1-R650 | 2 | MINI_PCIE_52PIN_CARD_CON | 0475531001 | 2 | SIM_CARD_PUSH | MM60-EZH059-B5-R650 | 2 | MINI_PCIE_52PIN_CARD_LATCH | 76384-302LF | 3 | HDR_1X2_2.54MM_SHDR | 76384-303LF | 1 | HDR_1X3_2.54MM_SHDR_V2 | 0471554001 | 1 | SATA_VERTICAL | N7G24-A0B2RB-10-0HT | 1 | CFAST10 | 47151-0001 | 1 | HDMI | HDR 1x3 | 2 | HDR_1X3_2.54MM | HDR 2X3, BOXED | 1 | HDR_2X3_2.54MM_BOXED | 76384-304LF | 2 | HDR_1X4_2.54MM_SHDR | USB MICRO AB | 1 | USB_MICRO_AB | 5787617-1 | 1 | USB-2A | 2-406549-1 | 1 | RJ45LED | SJ1-3535NG | 1 | SJ1-3535NG | SJ1-3535NG-BE | 1 | SJ1-3535NG | SJ1-3535NG-GR | 1 | SJ1-3535NG | SJ1-3535NG-PI | 1 | SJ1-3535NG | DM3AT-SF-PEJM5 | 1 | USD_DM3AT | 1734351-1 | 1 | DBA9_M_RA | HDR 2x5, BOXED | 2 | HDR_2X5_2.54MM_BOXED | BA2032 | 1 | BA2032 | HDR 2x7, BOXED | 1 | HDR_2X7_2.54MM_BOXED | Hdr 4x2mm BOXED | 1 | HDR_1X4_2MM_SHDR | 5103308-5 | 1 | HDR_2x10_2.54mm_BOXED | PJ-002AH | 1 | POWER_JACK_5.5_2.1MM_NS | 0015244449 | 1 | 015244449 | DM3C-SF | 1 | USD_DM3CS | 0532610471 | 1 | 0532610471 | FI-SE20P-HFE | 1 | FI-SE20P-HFE | HDR 1x2 | 3 | HDR_1X2_2.54MM | ACM2012-900-2P-T002 | 7 | ACM2012 | 4μ7 | 2 | IHLP_255MILX270MIL | 2N7002BKW,115 | 7 | SC70_SOT323 | SI4816BDY-T1-GE3 | 2 | 8_SOIC_3.9MM | 0R | 65 | R0402 | 10k | 42 | R0402 | 200k | 11 | R0402 | 2k1 | 1 | R0402 | 330R | 5 | R0402 | 2k4 | 2 | R0402 | 1M | 1 | R0402 | 3k | 1 | R0402 | 2k2 | 4 | R0402 | 100k | 14 | R0402 | 1k | 4 | R0402 | 15k | 3 | R0402 | 4k99 | 5 | R0402 | 27k | 1 | R0402 | 365R | 1 | R0402 | 1k8 | 1 | R0402 | 3k3 | 1 | R0402 | 12k | 1 | R0402 | 75R | 4 | R0402 | 33R | 5 | R0402 | 100R | 3 | R0402 | 562 | 2 | R0402 | 47k5 | 2 | R0402 | 10R | 1 | R0402 | 1R | 2 | R0402 | 240R | 4 | R0402 | FSMRA2JH | 1 | FSMRA2JH | FSMRA3JH | 2 | FSMRA3JH | H5007NL | 1 | H5007NL | TPS74801DRCR | 2 | DRC (S-PVSON-N10) | TSC2007IPWR | 1 | PW (R-PDGO-G16) | TPA6041A4RHBR | 1 | VQFN32 5X5X0.85 | MAX9867ETJ+ | 1 | QFN32 5X5X0.85 | PCA9306DCTR | 1 | DCT_8 | CM2020-00TR | 1 | TSSOP_38 | SN74AHC1G09DBVR | 2 | DBV_SOT_23_5 | TPS2034D | 1 | 8_SOIC_3.9MM | LM358AMX | 1 | 8_SOIC_3.9MM | MIC2026-1YM TR | 2 | 8_SOIC_3.9MM | USB2514BI-AEZG | 1 | QFN36_6MMX6MM | SGTL5000XNAA3R2 | 1 | QFN32 5X5X0.85 | TLV803SDBZR | 1 | DBZ | ISL4245EIRZ | 1 | QFN32 5X5X0.85 | PCF8563T | 1 | 8_SOIC_3.9MM | BR24L02FVM-WTR | 1 | MSOP8 _SMALLER | PCA9535BS | 1 | HVQFN24_4X4MM | SN74LVC1G08DCKR | 3 | SC70_5 | ISL6236AIRZ | 1 | 32_VFQFN_EXPOSED_PAD | 12.288MHz | 1 | ASFLMB | 24MHz | 1 | ABM7_V1_1 | 32.768kHz | 1 | ABS06 | - i: J+ N! q7 A: n
; G7 l; t2 R; J* i( t0 H8 ~6 H# j8 j1 J! }9 O0 g! m' u
: z" _+ a0 a7 M& U: c |
