XC3S400A+FM24CL64+MAX1951+SN74ACT00DR+MAX803+ARM控制板PCB作品文件分享
B5 r3 |" I$ i, I用AD画的,布局布线很清晰,有需要的可以看看。( B& ]/ t* _5 v7 K' c$ }+ l: m
层数:6层/ K/ C7 E. D2 s3 ~
用途:控制板
5 w, h( z+ x/ `/ O4 Spcb作品截图如下:
& x y$ I# X+ F, m+ e
5 O) @1 ]- N; g" W# A7 u; K4 T2 T. L4 C
9 r/ S, s* G6 J' c4 {/ E4 c' ?
; ~5 X6 V& T' `4 J附件:3 @7 D w6 c: V! u R
! A K, U# j8 P5 n, C; f
( P7 M1 {# B2 u8 J# n& C. `
# q0 V* Y z6 r6 F2 f$ e+ YBOM:; x2 ^8 J+ @8 I' J4 L5 z
Comment | Quantity | Footprint | 2.2uF | 8 | 0805 | 0.1uF | 26 | 0805 | 0.001uF | 8 | 0805 | 10uF | 11 | 0805 | 1uF | 3 | 0805 | 16V/10uF | 2 | 3528 | 220pF | 5 | 0805 | 0.01uF | 18 | 0603 | 10uF | 8 | TANB | 0.1uF | 7 | 0603 | 100uF | 4 | C | 0.01uF | 4 | 0805 | 100uF | 2 | CSOF8 | 100uF | 1 | CSOA5 | 10V 10uF | 1 | 0805 | TMP36 | 1 | SOIC-8 | ADS7830 | 1 | TSSOP-16 | MAX803 | 1 | SC70-3 | MAX823_T | 1 | SOT23-5 | SP3002 | 1 | SOT23-6 | SN74LVC1G17DBVR | 1 | SOT23-5A | AFBR-24x8xZ | 1 | HFBR-1414 | XC3S400A-4FTG256I | 1 | FT256 | XCF02SVO20C | 1 | VO20 | FM24CL64 | 1 | SO-8 | MAX743 | 1 | DIP16\SOL | MAX1951 | 2 | SO-8 | SN74ACT00DR | 2 | SO-14 | HFBR-1414 | 2 | HFBR-1414 | 20MHz | 1 | JZ\SOA | CBW3225U310T | 5 | 1210 | 1.8uH | 1 | CR43NP | 120uH 0.5A | 2 | CR75 | 22uH 0.5A | 2 | CR32 | 1.8uH | 1 | L5X5\SOAA | 5uH | 1 | CDRH6D38 | 3.3K | 4 | 0805 | 1K | 13 | 0805 | 10k | 2 | 0805 | 0R | 1 | 0805 | 15k | 8 | 0805 | 4.7k | 11 | 0805 | 20K | 1 | 0805 | 33R | 17 | 0805 | 100R | 4 | 0805 | 510R | 1 | 0805 | 2.2K | 2 | 0805 | 10R | 4 | 0805 | 75k%1 | 1 | 0805 | 24k%1 | 1 | 0805 | 41.2k%1 | 2 | 0805 | 28k%1 | 1 | 0805 | 56.2k%1 | 1 | 0805 | SMBJ5.0CA | 1 | SMBJ | SMBJ12CA | 9 | SMBJ | LED | 1 | LED\0805 | RB160L | 2 | SMA | CON20x2 | 2 | HDR2X20 | CON5 | 1 | SMD\5PA | CON2X7 | 1 | HDR2X7 | Header 2 | 1 | HDR1X2 | 0923-232-6825 | 1 | YJ-330-CPU | $ E$ c( q6 ~8 L7 l, K. i: S
3 ?3 E, h+ B$ @, K* b, F v6 U: t
0 y; t1 P. A' E/ w |
