查看: 926|回复: 1
NanoBoard+TL36WW050+A6ER+MAX3232CSE+MCP2551+SN74LVC00AD+OPA2340UA+原理图+PCB...
发表于 2019-9-11 12:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
NanoBoard+TL36WW050+A6ER+MAX3232CSE+MCP2551+SN74LVC00AD+OPA2340UA+原理图+PCB作品分享。# G$ S& J# J, H" I
AD画的,画的很不错,有需要的可以看看。
- p$ D- q9 \! e6 q
' _. S) L! I  V! y层数:2层
' B$ k( V+ }6 R4 x  A9 H用途:NanoBoard: U7 K7 |- v1 J. G8 A. Z, k
pcb作品截图:
( C' q# A# t2 r5 u
附件:
* U; \7 r( q2 y; @: q
游客,如果您要查看本帖隐藏内容请回复
( H3 K: B' G9 ^* I; h  tBOM:
7 ~) |. {1 J- p% J6 N, O
Comment
Quantity
Footprint
10uF14MCCT-B
100nF40CC2012-0805
470uF 16V4RB8/3.5
22nF2CC2012-0805
Do Not Install2CC2012-0805
470pF1CC2012-0805
4700pF2CC2012-0805
1uF2C3216-1206
220pF4CC2012-0805
100pF5CC2012-0805
1nF12CC2012-0805
QC49/SMD1QC49/SMD
BAS40-045SO-G3
BAS401SO-G3
SMBJ5341B1DO214
Header 29HDR1X2
Header 5X24HDR2X5
70246-26221HDR2X13_CEN_LP
70246-10222HDR2X5_LP
Header 7X21HDR2X7
Header 10X22HDR2X10
DB9 Female1DSUB1.385-2H9
D Connector 9_MALE1DSUB1.9_MALE
Dsub-15-Female-HD1DB15-VGA-Female
8918-P62PS2-6PIN
KLD-0202-B2KLD-0202
53751-1009253751
ST-3150-5N2ST-3150-5N
Header 2X21HDR2X2
Header 9X21HDR2X9
Header 2X23HDR2X2_B
330uH1CC4532-1812
162A1162A
HSMH-C17017SMD _LED
2N70023SO-G3
BSS841SO-G3
100R10CC2012-0805
15K1CC2012-0805
120R4CC2012-0805
270R2CC2012-0805
1K11CC2012-0805
680R3CC2012-0805
330R3CC2012-0805
47R4CC2012-0805
4K716CC2012-0805
0R3CC2012-0805
68R2CC2012-0805
10K6CC2012-0805
560R4CC2012-0805
5R62CC2012-0805
33R4CC2012-0805
470R1CC2012-0805
10R1CC2012-0805
18K1CC2012-0805
1K81CC2012-0805
4R71CC2012-0805
4K717MNR34
100R11MNR34
270R4MNR34
TL36WW0501TL36WW15050
A6ER-81041DIP-16-KEY
ABSM-1574-05 Transducer1ABSM-1574
DTSM-61-NR17B3FS_SWITCH
TS101TS2.54x10
MAX3232CSE1SO-G16
MCP25511SOIC8
SN74LVC00AD1SO-G14/Y2.2
SN74LVC244ADB1SSO-G20/P.65
XCF01SVO20C1VO20
M25P80-VMW62SO8_MW/SO8_MN
XC2S100E-6TQ144C1TQ144
LM1084IS-ADJ3TO-263
ICS307M-021SO-G16
QSMO_42001QSMO_4200
IDT71V124SA15Y2SO-J32
SN74LVC1G04DBV1SO-G5/P.95
SN74LVC245ADB1SSO-G20/P.65
OPA2340UA1SO-G8
MAX1104EUA1TSSO3x5-G8/X.35
MAX5841MEUB1USOP10
MAX1037EKA-T1SOT23_8
20K1POT4MM-2
100K1POT4MM-2
6 |8 [  r- B$ {" E" O
GMT+8, 2025-7-19 16:56 , Processed in 0.140625 second(s), 27 queries , Gzip On.
