AT45DB041D+MT48LC16M16A2TG+HR911130A+88E1111+XC3S250E开发板原理图+PCB作品文件分享。3 }- C0 d m7 P' V( Z/ c5 T
AD画的,画的很不错,布局布线很清晰,有需要的可以看看。1 c: V; w X% E/ ]" A5 P7 c
# V5 R$ E9 f& n D9 ^
0 b9 ]% n1 Z) K2 |+ S$ _, b
层数:4层- Z/ |" l& j) C! D. l5 x& B$ P
用途:开发板
2 E+ n# e3 I: o# Mpcb作品截图:
3 u5 M- W4 Y2 P X1 O+ c" Q
8 L6 M, x2 P) M+ S
( M4 {; c; M5 l* c1 i& c8 t! H附件:6 s6 n7 f/ h' l- G# W0 \% o# i j( E
- n9 U. J+ t9 X
BOM:
" Q, U2 A% }9 h' H& l$ C6 z: x- t* _$ \& a& w( o
Comment | Designator | Footprint | Quantity | LibRef | 1000pF | C1, C42 | C0603 | 2 | CAP, CAP 0603 | 0.047μF | C2, C3, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C37, C38, C39, C40 | C0603 | 18 | CAP, CAP 0603 | 10uF/16V | C4 | 3528 | 1 | CAP_E | 104 | C17, C18, C19, C23, C25, C29, C30, C35, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C60, C66, C67, C68, C69, C70, C71, C72, C73, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87 | C0603 | 40 | CAP | 22UF/10V | C20, C21, C22, C24, C26, C32, C33, C36 | 3528 | 8 | CAPDIP | 1uF/16V | C27, C28 | C1206-POLAR | 2 | CAPACITOR POL | 0.1uF | C41 | C0603 | 1 | CAP | 22P | C43, C44 | C0603 | 2 | CAP | 10UF/6.3V | C45, C47, C62, C63 | 3528 | 4 | CAPDIP | 1000P | C46, C48, C49, C64, C65 | C0603 | 5 | CAP | LED | D1, D2, D3, D4, D5, D6, D7, D8, D9, D10 | LED0805 | 10 | LED | Header 20X2 | J1, J4 | HDR2X20 | 2 | Header 20X2 | Header 7X2 | J3 | HDR2X7 | 1 | Header 7X2 | POWER_OUTLET | J5 | POWER_OUTLET | 1 | POWER_OUTLET | SWITCH | J6 | SWITCH | 1 | SWITCH | HR911130A | JA1 | HR911130A | 1 | HR911130A | 1UH | L1 | L0805 | 1 | INDUCTOR | Header 2 | P2, P3, P4 | HDR1X2 | 3 | Header 2 | 4.7K | R1, R3, R7, R8, R9, R11, R14, R15, R16, R18, R28, R40, R52, R53, R61 | R0603 | 15 | RES, RES2 | 150 | R2, R12, R13, R22, R23, R24, R25, R26, R27 | R0603 | 9 | RES | 0 | R4, R45, R47, R48, R49, R50, R55, R62 | R0603 | 8 | RES | DNP | R5, R54, R60 | R0603 | 3 | RES | 51 | R6 | R0603 | 1 | RES | 330 | R10 | R0603 | 1 | RES | 10K | R17 | R0603 | 1 | RES | 240 | R19 | R0603 | 1 | RES2 | 1K | R20 | R0603 | 1 | RES | 720 | R21 | R0603 | 1 | RES2 | 49.9 | R29, R30, R31, R32, R33, R34, R35, R36 | R0603 | 8 | R | 4.99K/1% | R37 | R0603 | 1 | RES | 120 | R38, R39 | R0603 | 2 | R | XC3S250E | U1 | PQFP-208-XILINX | 1 | XC3S250E | AT45DB041D | U2 | SO-8-AT45DB041B | 1 | AT45DB041D | AS1117-3.3V | U3, U7 | SOT-223 | 2 | AS1117 | AS1117-1.2V | U4, U8 | SOT-223 | 2 | AS1117 | AS1117-2.5V | U5 | SOT-223 | 1 | AS1117 | LM317 | U6 | TO-220 - VERTICAL | 1 | LM317 | 88E1111 | U9 | 88E1111-RCJ | 1 | 88E1111 | HY57V561620BT-H | U10 | TSOP54 | 1 | MT48LC16M16A2TG | 50M | X1 | 7050 | 1 | OSC | 25MHz_+/-50ppM | Y1 | XL200 | 1 | CRYSTAL |
7 _; u, { r3 I* [- h% R: Y6 l0 `* H# w6 T" M
# c: p0 l2 P) n& g% r f% Z6 E8 g9 ?) o/ n% A/ l
8 H+ k8 Y d1 b3 M& V- a
% y; T5 k+ ], _" q/ Z7 B3 a
