(HDMI+RCA-H2V3+VIDEO_S)ZWT361 DAVINCI DM6446 DVR主板PCB设计作品文件分享
8 `4 G k* j$ E; h/ s5 u6 z. i8 z/ O+ \, [; K& u/ x
用pads Vx 画的6层板,板子很密,有一定难度,有需要的可以看看。
! n- V, N! I8 H) w/ I层数:6层
8 E% J l- b5 ` d$ W+ ~用途:主板4 v2 ~ H6 ^+ w* N4 Q
pcb作品截图如下:
) T7 A, U; l8 P3 P9 p; k+ V7 u
y# T6 X2 j9 i5 @
附件:
( [4 e+ n7 d: f- I
6 P+ j# A y1 h7 t8 L% v
]# r7 g" U; g* R: j
0 Z& W% J0 N# g
% X, ]/ C! d7 U; jBOM:
* y: S7 o: r z7 p' q) O. x) c: F ~8 Y+ y* L
Index | Decal | QTY | Top Layer | | 367 | Chips | | 24 | 1 | 48LQFP | 1 | 2 | DBV6-SOT-23 | 1 | 3 | FBGA-84-BALL | 2 | 4 | LQFP64/20A | 1 | 5 | QFN32 | 1 | 6 | QFP100-0.5 | 1 | 7 | QFP80-0.65 | 1 | 8 | RJ45-HFJ11-2450E | 1 | 9 | SC-70-6 | 1 | 10 | SOIC8 | 2 | 11 | SOP-8 | 1 | 12 | SOP8 | 3 | 13 | SOT-223 | 2 | 14 | TQFP-80-P | 1 | 15 | TQFP-80-P2 | 1 | 16 | TSSOP-DGG48 | 2 | 17 | TSSOP38-0.5 | 1 | 18 | ZWT361AA | 1 | Resisters | | 132 | 19 | R0603 | 127 | 20 | R1206 | 5 | Capacitors | | 92 | 21 | C0603 | 65 | 22 | C1210P | 17 | 23 | C2220P | 10 | Inductors | | 27 | 24 | 1210 | 1 | 25 | ACM0706 | 1 | 26 | INDUCTOR-8X8 | 3 | 27 | L0805 | 12 | 28 | L1206 | 10 | Diodes | | 11 | 29 | DIO_1210 | 1 | 30 | LED0805 | 3 | 31 | SC-76 | 4 | 32 | SCHOTTKY | 3 | Triodes | | 5 | 33 | SOT-23 | 2 | 34 | SOT23 | 3 | Crystals | | 5 | 35 | CRYSTAL-SMD | 3 | 36 | XTAL-RT | 1 | 37 | XTAL_SMD | 1 | Connectors | | 13 | 38 | CON_HDMI | 1 | 39 | FPC-S-10-20PIN | 1 | 40 | FPC-S-10-24PIN | 1 | 41 | JP26 | 1 | 42 | JTAG20 | 1 | 43 | RCA-H2V3 | 1 | 44 | SATA3A | 1 | 45 | SIP2X5-1.27 | 1 | 46 | SIP3 | 1 | 47 | SIP4 | 1 | 48 | SIP4-2.0 | 1 | 49 | USB_A_05 | 1 | 50 | VIDEO_S | 1 | Jumpers | | 18 | 51 | TESTPOINT_SMD | 18 | Unkowns | | 40 | 52 | BATTERY_SKYWORTH | 1 | 53 | CRYSTAL-SMD | 1 | 54 | FM40 | 8 | 55 | HOLE3.5-7.0 | 4 | 56 | RA0603-4P | 26. W5 a3 I+ s) P2 a& n0 z4 T
& X3 Z8 a) H" I$ p3 ]* x- }
| 1 M# u2 T9 p/ g5 a0 E. Z8 [( T, J
9 V% q1 ~% h! T
