SC6800展讯智能手机SKY77547+CL6012X+BC6888A04+MM8430+AR6102+PCB文件* v' v, e+ x7 }- V
用padsVX画的6层板,有需要的可以看看。9 X8 c8 B0 _, V m9 W
" i$ U, C9 z( @8 P4 i0 k& W1 }' c7 x4 ?层数:6层
" [9 [- d- M. O8 ~* J% O5 F+ M/ G用途:行车记录仪
I" f" S T1 {0 @* y! G- {PCB作品截图:
) V5 ?2 N# V Y) B( V$ f! l0 _! o
5 ?# t4 S( w, h# y3 h9 S附件:
; {7 ^ q5 B- Z
3 h+ V) N* R1 V' m- U4 l7 a* t$ O: m$ K
BOM:ItemIndex | Description | Value | Decal | IC | | | | 1 | 26PIN SENSOR | 26PIN SENSOR | FPC-8PIN-1.5MM | 2 | A2S60 | A2S60 | BGA-404P-0.65 | 3 | AKM4633 | AKM4633 | A4633 | 4 | H5PS1G63EFR-S6C | H5PS1G63EFR-S6C | BGA84-DDR2-512M | 5 | K9F5608U0D | K9F5608U0D | TSOP48-P0.5 | 6 | LN1134B3.0MR | LN1134B3.0MR | SOT-25 | 7 | LN5068 | LN5068 | MSOP-10/LN5068 | 8 | LN6206P3VR | LN6206P3VR | SOT-23 | 9 | NL17SZ32DFT2G | NL17SZ32DFT2G | SC-70-5 | 10 | SN74AVC1T45DRL | SN74AVC1T45DRL | SOT-563 | 11 | mma8452q | mma8452q | MMA8452Q | Resistant | | | | 12 | 0R | 0R | 0402R | 13 | 0R | 0R | 0603R | 14 | .06R | R0.6 | TP0.6 | 15 | 44.2R | 44.2R | 0402R | 16 | 75R | 75R | 0402R | 17 | 100R | 100R | 0402R | 18 | 180R | 180R | 0402R | 19 | 220R | 220R | 0402R | 20 | 1KR | 1K | 0402R | 21 | 1.8KR | 1.8K | 0402R | 22 | 4.7KR | 4.7K | 0402R | 23 | 6.8KR | 6.8K | 0402R | 24 | 10KR | 10K | 0402R | 25 | 15KR | 15K | 0402R | 26 | 20KR | 20K | 0402R | 27 | 39KR | 39K | 0402R | 28 | 56KR | 56K | 0402R | 29 | 100KR | 100K | 0402R | 30 | 200KR | 200K | 0402R | 31 | 1MR | 1M | 0402R | 32 | 10MR | 10M | 0402R | 33 | ERROR | NC | 0402R | Capacity | | | | 34 | 12PF | 12PF | 0402C | 35 | 20PF | 20PF | 0402C | 36 | 33PF | 33PF | 0402C | 37 | 100PF | 100PF | 0402C | 38 | 560PF | 560PF | 0402C | 39 | 10000PF | 0.01UF | 0402C | 40 | 100000PF | 0.1UF | 0402C | 41 | 220000PF | 0.22UF | 0402C | 42 | 1UF | 1UF | 0402C | 43 | 2.2UF | 2.2UF | 0402C | 44 | 10UF | 10UF | 0805C | 45 | 22UF | 22UF | 0805C | 46 | ERROR | NC | 0402C | Inductance | | | 47 | 4.7UH | 4.7UH | L-SMD-4.4 | 48 | ERROR | BLUE | LED0603 | Diode | | | | 49 | B0530WS | B0530WS | D1206/AKA | 50 | BAT54C | BAT54C | SOT-23 | 51 | BAT54C | BAT54C | SOT23 | Triode | | | | 52 | AO3415 | AO3415 | SOT-23 | 53 | DTC114EUA | DTC114EUA | UMT3 | 54 | DTC143EUA | DTC143EUA | UMT3 | 55 | S8550 | S8550 | SOT-23 | Reluctivity | | | | 56 | ERROR | NC | 0402R | Crystal | | | | 57 | 27M | 27M | CYCLE_3A | 58 | 32.768KHz | 32.768KHz | CYCLE_3A | Jump | | | | 59 | 26PIN SENSOR | 26PIN SENSOR | FPC-13PIN-5.2M | 60 | Micro SD_GWT-CM-0248 | Micro SD_GWT-CM-0248 | T-FLASH | Unkown | | | | 61 | R0.6 | R0.6 | TP0.6 | 62 | R0.6 | R0.6 | TP1.8Y | 63 | F-CAP | F-CAP | F-CAP | 64 | ON/OFF | ON/OFF | K5-1 | 65 | KEY | KEY | KEY3X63 |. s* B7 R R6 r! F
' ~! d/ n' n1 R% K& W/ ? | 3 H! c1 }: F! |0 _+ Z5 J8 d$ Y) \) W2 M
, E X( a m7 |* l; ] a
- _ Q" u8 E' W, `! o, g
1 l$ }" Y& A1 ?" H) c1 W |
