SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE |
ALPS_SCHA4B0400_8P_2 | MICRO TF_ALPS_SCHA4B0400_8P_2_M | micro TF |
ANT_LDA312G4413H_MURATA | ANT_IV0182_ANT_LDA312G4413H_MUR | ANTENNA |
CC0805 | CAPACITOR_CC0805_10UF | 10uF |
CC0805 | CAP NP_2_CC0805_10UF | 10uF |
CC0805 | CAP NP_1_CC0805_10UF/10V | 10uF/10V |
CC0805 | CAPACITOR_0_CC0805_4.7UF/16V | 4.7uF/16V |
CNIO_R6191018_061_ASTRON | 18PIN CONNECTOR_1_CNIO_R6191018 | 18pin connector |
CNUSB_020133MR004S50AZR_SUYIN | USB-CON_1_CNUSB_020133MR004S50A | USB |
CNUSB_4758900001_MOLEX | CSS5305-4503F_0_CNUSB_475890000 | CNUSB_4758900001 |
ESD0402 | DIODE TVS LC_2_ESD0402_ESD-0402 | ESD-0402-LF |
FBGA96C80P9X13 | DDR3_0_FBGA96C80P9X13_DDR3 | DDR3 |
FBGA441C80P19X19 | BGA441-AW1623_13_FBGA441C80P19X | BGA441-APP |
HDMI_19_0_4MM | HDMI19_TYPE_C_HDMI_19_0_4MM_HDM | HDMI_TYPE_C |
IR | IR_MODULE_4_IR_IR_MODULE | IR_MODULE |
L0402 | INDUCTOR_L0402_2.7NH | 2.7nH |
L0805 | INDUCTOR_L0805_600R-100M | 600R-100M |
L0805 | INDUCTOR_2_L0805_47UH | 47uH |
LED0603 | LED_0_LED0603_POWER | POWER |
MIC_450X250 | MICPHONE_MIC_450X250_MICPHONE | Micphone |
QFN49E | AW1612_2_QFN49E_AXP209 | AXP209 |
R0603 | R_8_R0603_0_0603 | 0_0603 |
RCLAMP0524P | RRCLAMP0524P_RCLAMP0524P_RRCLAM | rRClamp0524P |
SC70_6N | AO7408_SC70_6N_AO7408 | AO7408 |
SC89X080_3N | L2SC4617_SC89X080_3N_L2SC4617_6 | L2SC4617 |
SML_LQH44P_N_MURATA | INDUCTOR_SML_LQH44P_N_MURATA_4. | 4.7uH@1.5A DCR<0.1R |
SML_LQH44P_N_MURATA | INDUCTOR_0_SML_LQH44P_N_MURATA_ | 4.7uH@1.5A,DCR<0.1R |
SM_MM8130_MURATA | CONN_0_SM_MM8130_MURATA_MM8130 | MM8130 |
SOD123 | DIODE_SCHOTTKY_1_SOD123_5819 | 5819 |
SOD-123LF | DIODE_SCHTKY_1_SOD-123LF_CRS06 | CRS06 |
SOD-723 | DIODE SCHOTTKY_6_SOD-723_LRB521 | LRB521G-30T1G |
SOT23-5 | RT9266PE_2_SOT23-5_SY6280 | SY6280 |
SOT23-5 | SGM804_0_SOT23-5_SGM804 | SGM804 |
SOT23-5 | RT9293B_0_SOT23-5_SY8008B | SY8008B |
SOT-23 | PMOS_SOT-23_AO3423 | AO3423 |
SOT-23 | PMOS_SOT-23_AO3415 | AO3415 |
SWNTC016-BA1G | SW PUSHBUTTON-SPST-2_5_SWNTC016 | NTC016-BA1G |
SW_EVQP7C_PANASONIC | SW_TACT-SPST-2_SM_0_SW_EVQP7C_P | SW_TACT-SPST-2_SM_0 |
TP_PAD | T_POINT_R_TP_PAD_T_POINT_R | T_POINT_R |
TP_SMD | T_POINT_R_TP_SMD_1V25 | 1V25 |
TP_SMD | T_POINT_R_TP_SMD_1V4 | 1V4 |
TP_SMD050 | T_POINT_R_TP_SMD050_VMIC | VMIC |
TSOP-48 | NAND_FLASH_X8_TSOP-48_NAND FLAS | NAND FLASH X8 |
USBWIFI | UM02BS-8188CUS_USBWIFI_UM02BS-8 | UM02BS-8188CUS |
USB_MINI_AB | USB_MINI_SOCKET_USB_MINI_AB_USB | USB-MINI-SOCKET |
Y12M | XTAL_13Y_Y12M_DSX321G_24MHZ | DSX321G_24MHz |
YCC7V-T1A | XTAL_3_YCC7V-T1A_FC-135_32.768K | FC-135_32.768Khz |
