画的一款Jlink带串口的板子文件给大家分享一下。& D5 @* M2 x' X
: z0 h, P( D: N& E$ W3 h+ f- O0 ^( N7 E
学习单片机使用,已发板验证没问题。有需要的可以看看。
% d% q* p7 E' q( r) M' Z2 }3 n" u
- A: M: l: L7 J, M- j8 o4 r- F作品截图: h7 D* `1 D4 q I$ u6 T
8 y! K0 F. L5 q5 [/ _
5 Z8 h7 z% b) o m/ o" Y
4 R# [3 H0 C' A7 l! M2 z; q
; ?4 S8 c/ Q/ }* |3 r
附件:
1 [' o6 _; w' Y5 X2 B5 M
- c# b3 |% t C- F: R7 ]7 i b3 ^0 k+ y H
' d3 m; T$ K Y/ V Z; J1 v6 G# i2 o2 c0 r( N% c
BOM:3 b3 Y+ L- K. y7 J0 U
$ k/ c8 G. U: f& |4 P! ZSYM_NAME | COMP_VALUE | 64HTQFP | TFP410PAP | AMP-787745-X | USB_TYPE_A_DUAL | BATT_MS | LICELL | BGA139_0P5_7X7MM | MC13892 | CASE403D_02 | 1SMA5935B | CASE_M | 47UF | CASE_P | 47uF | CC7343 | 22uF | CON2_FPC_1P25_SM | CON FPC 2 | CON5_AUD_JACK_RA_TH_SJ-43515TS | AUD_5 | CON5_MICROUSB | MICRO USB AB 5 | CON8_FH19_SM_SH | CON FPC/FFC 8 | CON8_RJ45_1P02 | RJ45-8 | CON19_SDCARD_28X16_SM | CONN CRD 19 | CON20_0P5_FPC | CON FPC 20 | CONN_RT_RA_30 | DVI-I_Dual_29 | CON_2X26_0P8_SMT | CON 2X26 MINI PCI EXPRESS | CON_4M_1MM_SM_RA | SM04B-SRSS-TB | CON_22_1P27_SMT_SATA | SATA 22 | CON_26_FH12_1MM_SM_RA | CON 1X26 FPC | CON_52F_8S_25_SM | CON SKT 52 | CON_120S_QSH_SM_05PITCH | QSH-060-01-L-D-A | CON_DB9P_190-009-263R001 | DB 9 | CON_DF_20F_1MM_SM_RA | CON 20 | CON_JACK_3F_RA_TH_PJ-047A | CON PWR 3 | CON_SIM_CD_2P54MM | CON 6 SIM CARD | DFN_6_0P65_2P1X2 | ISL29003IROZ | DIP10_1P27MM_SM | SW_DIP-10/SM | FBGA_84_0P8_8X12P5 | EDE1116AEBG | FUSE_1P6X0P8 | SF-0603F | H1102_XFMR16_SM | H1102NL | HDR104 | HDR 1X4 | HDR105 | HDR 1X5 | HDR204_TMM_SM | TMM-104-01-T-D-SM | HDR210_TST_RA | TST-110-05-T-D-RA | HTSSOP20_VIA | tpa6017a2 | IND_2P2X2 | 3.3UH | IND_2012 | 0.082uH | IND_DO1608 | 1.0UH | IND_ELLVGG | 3.3uH | IND_VLF4012 | 2.2UH | IND_VLS252012 | 1.5UH | LED_0603_C1 | RED | LQFP48 | GL830-MNGXX | LQFP48 | ADV7123 | PBGA529_0P8MM | iMX51 | QFN20_3X3MM_A | SI4702 | QFN24_4X4MM_SLUG | USB3317 | QFN24_4X4MM_SLUG | MC34713EP | QFN32 | SGTL5000 32QFN | QFN36 | LAN8700 | QFN56EP_0P5_8X8MM | SK5101 | QFN64_0P5_9X9B | USB2517 | RC0805_OV | 0 | RC0805_OV | 0.02 | RCA_8_10 | 10K | RCA_8_10 | 1.0K | SC70-5_A | NC7SP125P5X | SC-70 | NL17SZ126DF | SLP1616P6 | RCLAMP0504P.TCT | SO6_A | SN74LVC1T45 | SO8-25X75-200 | AT45DB321D-S | SO8_0P65_3X1P7 | Si5855DC | SO8 | MIC2075-2YM | SO8 | MIC2026-1YM | SO8-25X75 | AT93C46DN | SOD123 | MBR120LSFT1G | SOD123 | MBR140SFT | SOD-123 | 1N4148W | SOD-323-A | BAS16H | SOD-923 | | SOT23 | 2N7002 | SOT23 | MMBT3904LT1G | SOT23-8 | MAX3373E | SOT353 | NL17SZ07DFT2G | SOT-23 | BAT54S | SOT-23 | IRLML6401 | SOT-553-5P | NL17SZ06 | SOT-563 | NSS12100XV6T1G | SPACER_150T | .635" LONG | SSOP8_0P65_2P9X3P1 | TXS0102 | SSOP16 | SP3232 | SSOT6_1P7X3 | FDC6331L | SUPERSOT6 | FDC697P | SW4_PB_ESW_SM_P177 | SPST PB | TESTPOINT_39MIL | 1 mm | TEST_LOOP | TEST POINT WHITE | TSSOP14_A | SN74LVC06A | TSSOP56_0P5_14X6P1MM | DS90C385AMT | ULLGA6_1P45X1_0P5MM | NLX2G14 | ULLGA6_1P45X1_0P5MM | NLSV1T34 | WDFN3_2X2MM | NSS12100UW3 | XTAL4_5P2X3P4MM_SM | 24MHz | XTL2_4P2X1P6 | 32.768KHz | XTL4_2P5X2MM_SM | 22.5792MHZ | XTLOSC4_3P2X2P5MM_SM | 26MHz | XTLOSC4_3P2X2P5MM_SM | 24MHZ | XTLOSC4_5X3MM_SM | 25MHZ |
! \7 _/ c, t7 ?& ]& T7 q- |4 m* d, d0 J
. q( ?5 ]+ n7 o, ~: O' c6 f
