在前面推文的介绍中,我们知道STM32系统复位后首先进入SystemInit函数进行时钟的设置,然后进入主函数main。那么我们就来看下SystemInit()函数到底做了哪些操作,首先打开我们前面使用库函数编写的LED程序,在system_stm32f10x.c文件中可以找到SystemInit()函数,SystemInit()代码如下:
6 O: v& J0 `. J" P' @3 r& w void SystemInit (void)* O9 S7 C- ~4 [; x, i
! H7 B2 b4 [# o/ W( B5 m$ N+ F /* Reset the RCC clock configuration to the default reset state(for debug purpose) /0 a; T S3 y' P' _& n# D6 }
/ Set HSION bit /
$ ?& Z3 c3 f' ?8 A8 Y4 Y5 f RCC->CR |= (uint32_t)0x00000001;
8 r: r; [: p5 u' O H8 M" _ / Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits // c" y" {6 A# C* V
#IFndef STM32F10X_CL7 N" V8 D+ B! V; P& L" X+ Q
RCC->CFGR &= (uint32_t)0xF8FF0000;8 R# g" V; B; t( f3 Z
#else* {( q0 A: c3 m5 B$ y) i4 l. D3 Q
RCC->CFGR &= (uint32_t)0xF0FF0000;
) h$ K" m9 o8 _ #endif / STM32F10X_CL /
2 ~; U, b9 c5 q! U$ G / Reset HSEON, CSSON and PLLON bits /) r* ~8 x( k. u, ~; u: O
RCC->CR &= (uint32_t)0xFEF6FFFF;* h9 r4 c, B3 A$ C+ @4 I+ f
/ Reset HSEBYP bit // t" g/ {- w- V5 k$ s( J
RCC->CR &= (uint32_t)0xFFFBFFFF;' m% j) \% P; N5 p
/ Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits /
0 i5 B! G% k% P/ n7 s RCC->CFGR &= (uint32_t)0xFF80FFFF;: c* J8 o: N! h9 k8 h
#ifdef STM32F10X_CL
9 L9 x8 f, R) Z8 M; `# Q / Reset PLL2ON and PLL3ON bits */
8 K; E# r1 w. V5 z RCC->CR &= (uint32_t)0xEBFFFFFF;+ l& k1 h" i: M% H, b# S# s* z- K5 \# U
/* Disable all interrupts and clear pending bits /7 x+ ?" X' i/ c! M& T
RCC->CIR = 0x00FF0000;
0 E9 W8 A. m3 a, J6 \ ` / Reset CFGR2 register /( F$ j1 `9 k5 d* E
RCC->CFGR2 = 0x00000000;
1 P+ s0 O+ Q9 e9 i3 Z2 S #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined! A9 g h8 ]. z+ ^/ c$ K. I
STM32F10X_HD_VL)
0 \' Q; q& f# j6 ?' F / Disable all interrupts and clear pending bits /9 P, @0 V- ? n0 C w
RCC->CIR = 0x009F0000;
Y" y* B" y* t / Reset CFGR2 register /4 _( n) Q, p: ^/ y9 ^, A
' {/ r; z1 D% q l' ]3 } #else
; y0 ~% h) _' j8 e; J; G/ y9 ] / Disable all interrupts and clear pending bits /1 }+ y, t, s* B: g% ] k7 m* D
RCC->CIR = 0x009F0000;8 j. S$ e3 X; k( u0 W, R w
+ W& C$ a; p! n #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined
+ d2 D7 b8 l, ]# g4 N STM32F10X_HD_VL)$ L% b% f& m2 f- L2 g; G1 r
#ifdef DATA_IN_ExtSRAM$ R! I! M7 }7 g8 y" V
SystemInit_ExtMEMCtl();
& f# D8 h4 K0 o4 j$ ~; M #endif / DATA_IN_ExtSRAM /5 j2 o: r/ g" W+ @+ X
#endif; g1 X, q: k7 l
/ Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers /; z6 I3 J/ m, o t! R& x
/ Configure the Flash Latency cycles and enable prefetch buffer /
, Z8 Z1 i/ N. v* i* f8 I- y SetSysClock();' U, @$ z, D. x1 }
#ifdef VECT_TAB_SRAM7 c! P8 }6 a' u
SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; / Vector Table Relocation in Internal SRAM. /5 p* ]8 @, _: W' c
#else5 E$ o( [( D8 L$ b# [5 @& ]: A
SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; / Vector Table Relocation in
7 g8 q1 ^; X6 `5 _) L+ S1 s Internal FLASH. */
/ ~; M+ }$ _5 o3 S! J #endif
# d M& k+ W3 b5 e* ?8 K" B }- g- H% A3 z2 Q
SystemInit函数开始通过条件编译, 先复位RCC寄存器,同时通过设置CR寄存器的HSI时钟使能位来打开HSI时钟。默认情况下如果CR寄存器复位,是选择HSI作为系统时钟,这点大家可以查看RCC->CR寄存器相关位描述可以得知,当低两位配置为00的时候(复位之后),会选择HSI振荡器为系统时钟。也就是说,调用SystemInit函数之后,首先是选择HSI作为系统时钟。在设置完相关寄存器后才换成HSE作为系统时钟,接下来SystemInit函数内部会调用SetSysClock()函数。这个函数内部是根据宏定义设置系统时钟频率。函数如下:
& m) O7 _; \2 q4 H static void SetSysClock(void)
# N2 H P: s- c" n( d7 ] {
2 D% _5 @9 \. H2 q, [" f6 `# m #ifdef SYSCLK_FREQ_HSE# s& ?; ~, o+ w
SetSysClockToHSE();% @! U2 o' Z; F2 {. z, L
#elif defined SYSCLK_FREQ_24MHz
# D/ \% M6 U/ X+ @ SetSysClockTo24();
9 v/ k7 R; s- s, ~ #elif defined SYSCLK_FREQ_36MHz
; l4 Y1 j4 c, A; m# ?0 Y6 k SetSysClockTo36();6 m/ `, i# ?: j+ l& G6 p
#elif defined SYSCLK_FREQ_48MHz8 v0 h. T3 M3 V( G6 {* R
SetSysClockTo48();% \4 Z2 D4 y( Z' m/ C
#elif defined SYSCLK_FREQ_56MHz
# W/ L% g2 W q SetSysClockTo56();1 ]+ E$ ]) D% H0 _6 c
#elif defined SYSCLK_FREQ_72MHz8 h0 `+ F$ f, J; ]$ V
SetSysClockTo72();
/ a7 R7 U5 P Y4 I- b3 c& ` #endif
, E% V8 N1 Q. H' D }
Q' w( w" y, _! P$ U 在system_stm32f10x.c文件的开头就有对此宏定义,系统默认的宏定义是72MHz,如下:
. Q" N, t. f7 m* T) a% o8 W #define SYSCLK_FREQ_72MHz 72000000
2 o* ~" ]7 j. `& Y; ^# z3 j 如果你要设置为36MHz,只需要注释掉上面代码,然后加入下面代码即可:2 o( o3 w5 h! v/ D- @
#define SYSCLK_FREQ_36MHz 36000000
2 }7 v- l+ w) z$ Z 根据该函数内部实现过程可知,直接调用SetSysClockTo72()函数,此函数功能是将系统时钟SYSCLK设置为72M,AHB总线时钟设置为72M,APB2总线时钟设置为72M,APB1总线时钟设置为36M,PLL时钟设置为72M。函数具体实现大家可以打开库函数查看,这里我们就不截取出来。如果SystemInit内实现过程看不懂没有关系,大家只要知道SystemInit函数执行完,时钟大小设置如下:
% G- {- s/ `$ k' a SYSCLK(系统时钟) =72MHz
0 a+ B# e) T( z5 f AHB 总线时钟(HCLK=SYSCLK) =72MHz
/ c/ X2 q' ~3 H( N2 w8 o$ a APB1 总线时钟(PCLK1=SYSCLK/2) =36MHz6 G- |5 ]/ y$ D
APB2 总线时钟(PCLK2=SYSCLK/1) =72MHz) [# f) a* O8 \
PLL 主时钟 =72MHz
4 {# t' T6 a3 C2 h5 d+ V9 T 在STM32中,这些时钟值是要熟悉的。( ^+ N& J; F' J2 i8 r/ k
' b8 j: w& K2 Y, T, q% p6 K9 F. a; Y7 O) g6 g( ^1 N4 N
