查看: 291|回复: 1
S3C2440的Linux SPI驱动移植
发表于 2019-8-27 15:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Linux内核版本:2.6.30.4, N- o3 H6 B; b  U6 ?8 D, L' U! c
测试平台:EmbedSky TQ2440
7 d4 \$ |1 @+ F4 f
! p, }+ Q6 Z  ]# Z7 `在2.6.30.4内核源码中,已经给出了S3C2440的SPI驱动,但是TQ2440并没有启用这个驱动,因此要在arch/ARM/mach-s3c2440/mach-tq2440.c中加入SPI的支持。网上参考的文章只将S3C2440的SPI0进行了配置,如果需要使用到两个SPI Master,就需要进行进一步配置。首先增加如下结构定义:
  w4 v: x4 y0 O/ H: I' W% d8 j4 ]1 t7 X
static struct spi_board_info s3c2410_spi0_board[] = {$ [" ~* H/ k! U! M
        [0] = {1 y: F7 N' i! i6 E
                 .modalias = "spidev",
& v3 r5 R1 p5 Q6 E4 J; R; u                .bus_num        = 0,
, n1 d' |4 F7 s( o2 w- y% p                .chip_select        = 0,9 y6 a# q& C( T' O7 |7 e  J
                .irq = IRQ_EINT10,5 s2 N/ R* p: e. {4 A: @
                .max_speed_hz         = 500*1000,7 H5 \/ B) S# M% C1 D+ N  K8 v
        },. x5 w( K" X0 L% M
};7 P! Y5 ~1 Z- H5 Q
  x$ |% p! H  G3 n; K3 ~
static struct s3c2410_spi_info s3c2410_spi0_platdata = {
% S: k9 _7 m2 `( F        .pin_cs = S3C2410_GPG2,
3 b& _9 |7 k5 }* k( T        .num_cs = 1,
/ d) q7 i) E3 S9 u. G& u        .bus_num = 0,, ~3 e0 m3 _( [% d
};% v' p4 `6 n  U- g+ s( d
& N* f. D( L1 A& P
static struct spi_board_info s3c2410_spi1_board[] = {. `* L; ?" h/ h' e7 t& `7 A
        [0] = {
4 B3 t* ~, T! V; T1 ]: O                 .modalias = "spidev",0 F: p7 Y4 ^; j( y8 C5 B  ]
                .bus_num        = 1,
* n' i: J4 y8 a  Q$ A                .chip_select        = 0,+ ]7 [! N' K* S6 i
                .irq = IRQ_EINT11,
1 @8 i2 e8 Z1 _; Y6 p/ Z                .max_speed_hz         = 500*1000,
: f  A4 z  E  b) G& [6 @0 D        }," u0 _- q' a) P4 a: g8 `- I. n
% ~3 n7 z: m: E6 m8 u6 ~
& d9 ~) i* l- ?/ Pstatic struct s3c2410_spi_info s3c2410_spi1_platdata = {) V5 k& B$ {9 R: G0 @
        .pin_cs = S3C2410_GPG3,2 I4 s- ^" A4 |) ~6 v* N
' W9 f: ?9 C8 r" X8 S# W* M& G3 C% z  N4 M1 v1 |
: T9 v/ A8 T8 P
$ Q0 n% z) [1 [, e" {  b+ t% w
GMT+8, 2025-8-23 08:12 , Processed in 0.109375 second(s), 23 queries , Gzip On.
